The thread discusses methods to retrieve saved Wi-Fi passwords on Windows computers. Neemobeer provides a manual, command-line approach suitable for Windows 7 through 10, while patcooke suggests using a free third-party utility called WirelessKeyView. The overall tone indicates a preference for built-in solutions over third-party tools, but both options are presented as viable ways to recover Wi-Fi passwords.
Thread Author
*NOTE* Please note this only works if you have at least one Windows computer that is able to connect to the wireless access point.
*NOTE* This works on Windows 7, 8, 8.1, 10
  • Press the WinKey and type cmd
  • Right click Command Prompt and select Run as Administrator
  • Type netsh wlan show profiles
  • You should get output similar to this
User profiles
All User Profile : Starbucks WiFi
All User Profile : attwifi
All User Profile : D&B_Guest
  • Now type netsh wlan export profile name="D&B_Guest" folder="C:\" key=clear (replace name="<yournetwork>"
  • Now go to the folder location and open the the file <NetworkAdaptername - WirelessProfileName.xml> in this case Wi-Fi 2 - D&B_Guest.xml and look at the entry labeled KeyMaterial and you should see the wireless pass-phrase
Neemobeer
Windows Forum Team
Thread Author #3
Of course there are a bunch of free utilities, I was just highlighting how to accomplish it without any 3rd party tools
