Creative has released a Link Removed driver specifically designed to provide support for the X-Fi Titanium series under Windows 7 Beta.
If you own a SoundBlaster Audigy SE or another version of the basic Audigy model then used Windows Update to attain your driver. Creatives vista driver will cause blue-screens when used in conjunction with 7.
More links for Drivers:
I'll update this thread as and when new drivers are released..
Soundmax ad1888 driver problem solved!!
HI !! You all must be having problem that windows 7 is not detecting soundmax driver on asus board. On installing from cd that came with motherboard it says OPERATING SYSTEM NOT SUPPORTED!! :mad:
So the solution for this problem is.:D
Download this zipfile from the link Link Removed - Invalid URL
Extract the contents.
Findsetup.exe in it. Now, right click on the setup and choose option Troubleshoot compatibilty.
It will detect issues and search programs and you will be presented with a set of options.
Choose option it ran with previous versions and also choose need special permissions.
click next . And your setup should start.
Let the driver install . restart when...
kalleklovn
@Kemical: thanks, but it did not help. I'm not shoure, but I think I need winamp, WMP, games... to work through ASIO4ALL. Is this possible?
@Athlonite: But it worked superb on XP 32 bit, why not on 7 32 bit? must be something I can do or download to make it work? Its an superb sound card for me and I dont want to sell it.
I found this driver after doing some googling (see screenshot):
animesector
No sound on ACER TRAVELMATE 4220
I installed WINDOWS 7, and now I have No sound on ACER TRAVELMATE 4220! :( Does anyone know of a driver that will fi it? In device manager it states drivers are working and installed propertly.....but nada
The Acer support section has downloads here: Link Removed
If you can't see any drivers for 7, use the vista ones.. If they don't work, try these drivers:
Realtek
jarboy808
Updating
Hey all,
With regards to the Creative Soundblaster 5.1 external surround card & Win 7 I was in contact with Creative & this was the official response;
"With regards to your enquiry, there are no driver update for the X-Fi
Surround 5.1 to run on windows 7. I would advice you to wait for the
latest driver for the X-Fi Surround 5.1 on windows 7. You can check for
latest update from our support site."
http://support.creative.com
So ahh...as always 3 months after a new OS hits Creative has no drivers for its products & the solution is "wait - then maybe".
Freshjms
No sound on Gateway MX6450
Just recently installed Windows 7 Ultimate to find I have no sound! :frown: I then installed the updated Realtek AC97 sound drivers for Window 7 and that didn't help at all. Any advice?
linuxist
I installed driveres and codecs and I stil don't have sound when I want to see a movie .But speakers work when I test it.Please a little help
I have realtek
I know Realtek have recently updated their driver so it might be worth trying the new driver..
Athlonite
looks like you maybe SOL tryin to find win7 drivers for that as gateway don't even list a sound driver when you choose any OS other than winxp on their site hmmm have tries the latest realtek drivers which are at Version: 6305
nickauger
Hi! I just installed window 7 32 bit on my mother computer and have a code 10. The motherboard is a Ga-8i915g pro and I tryed many driver and no one works great. I have always no sound. Here is the link of the motherboard: Link Removed
If some one can help me, I'll apreciate a lot !
Due to the age of the motherboard, try running the 7 advisor: Link Removed
nielsfeddema
Just like everyone else here, my soundcard doesn't seem to be working.
I've got an 'Asus P5GL-MX' motherboard.
Could you help me out with this?
thanks in advance.
Athlonite
just once i'd like to see a post that actually tells you what piece of hardware they are actually lookin for take the above post for example so we know you've got an Asus P5GL-MX mobo:confused: but you failed to say that the sound chip on it is an ADI SoundMax AD1986A:redface: i mean how are we supposed to help if you don't even tell us what actual piece hardware your lookin for is and end rant.....
now as for a driver as far as i know Analogue Devices has no plans to update the drivers for this chip anytime soon so unless an oem is going to do so you may be SOL time to look at getting an add-in pci sound card like and SB audigy 2 or better
nielsfeddema
Got myself a new soundcard, this time it's an ICIDU soundcard with a C-Media chipset.
When connected to the normal line plug it's working, but as I connect it to the 7.1 channels it doesn't.
Athlonite
Operating system/software Compatible operating systems Windows 98SE/2000/XP/Vista
yup i wouldn't have touched a card that says anything about win98\win2k support what you should be looking for is XP\Vista\Win7 support
does the speaker system you use have and SPDIF input
