The thread discusses users experiencing audio issues after a Windows update, which was resolved by changing the default playback device back to USB speakers. The original poster’s problem was fixed by adjusting sound settings, and another user inquired about the specific steps taken, to which a helpful reply provided instructions on changing the output device and troubleshooting. Overall, the main theme is resolving post-update audio problems through configuring sound settings, with a tone of frustration and relief.
tbeinc
After installing what seemed to be a full reinstall update (took hours) my audio has disappeared and no matter that I do I cannot get it to work again. Audio was working perfectly before the update but after it was gone. I have reinstalled drivers but to no avail. I disabled and enabled the device no luck. I did restarts after each of these actions...still it doesn't work...Anyone have any suggestions? Thank you : )
Right click speaker in task bar. Click Open sound settings. On the settings screen click the down arrow on choose your out put device.
If this doesn't work you could also try right click on speaker and click on troubleshoot sound problems.
tbeinc
Thread Author #2
Audio problem solved.....the Windows update changed my default speakers to my sound card.....changed that to my USB speakers and viola....sound magically appeared once again.
I think I should send Microsoft a bill for technical charged for all the time I lost due to their screw up!
babsn
How did you do this?
babsn
helpifIcan
Fantastic Member
