The thread discusses a persistent echo issue with audio on an MSI GE62 laptop. The original poster seeks help, and various contributors suggest checking sound effects, driver reinstallation, and hardware testing. Ultimately, the consensus indicates that if software fixes fail, the problem might be hardware-related, with some advice to reinstall drivers from the MSI website or test hardware via Ubuntu.
Well I would start by completely removing the driver and re-install and verify it is the latest driver.
- Open an elevated command prompt and type pnputil -e
- Locate your Realtek audio driver it will probably look like this
- Make note of the oem#.inf name
- Type pnputil -d oem10.inf in my case
- Download and reinstall the latest driver from the computer manufacturer site
- Reboot and test
Erday
- Joined
- Feb 22, 2016
- Messages
- 6
I notice it in games, youtube videos and twitch streams.Is this audio from something like a game, or music or is it echoing when using the mic?
bochane
- Joined
- Oct 18, 2012
- Messages
- 1,403
Check whether there is a soundeffect active:
Right click on the Speaker icon on the taskbar > Select 2nd option Playback devices > Right click the device you are using and select properties > Select 4th tab Effects
And uncheck all effects
I am on a non English version of windows you will see diffrent names from what I used in my answer, sorry for that
Henk
Henk
Erday
- Joined
- Feb 22, 2016
- Messages
- 6
I don't have a 4th tab. I only have General, Levels, Advanced.Check whether there is a soundeffect active:
Henk
Erday
- Joined
- Feb 22, 2016
- Messages
- 6
Yes I'm using Realtek High Definition Audio device and I clicked "restore defaults" but the echo is still there. Thanks for you help.Is it a Realtek High Definition Audio device?
Try under 'Advanced' something like 'Back to standard settings'
And if you have no sound effects, they can't be causing it.
I am out of options, anybody else?
- Joined
- Jul 4, 2015
- Messages
- 8,995
- Reboot and test
Erday
- Joined
- Feb 22, 2016
- Messages
- 6
Where would I download the driver from? Would it be from the MSI website for me?Well I would start by completely removing the driver and re-install and verify it is the latest driver.
If it still has the echo I would suggest ruling out hardware. Download Download Ubuntu Desktop | Download | Ubuntu and use a tool like Rufus - Create bootable USB drives the easy way to create a bootable usb. Boot into the Ubuntu installer and select Try. This will boot into a live version of Ubuntu. Go to Youtube and see if the echo is there. If it is then I'd say it's a hardware problem with your speakers.
- Locate your Realtek audio driver it will probably look like this View attachment 31914
- Reboot and test
