Frankieanime158
- Joined
- Oct 13, 2014
- Messages
- 7
I've been having the biggest issues with my computer as of late, and need help fast.. Basically, my audio driver fails to work, and won't play sound. After digging around, I found out it was AVG quarantining files with Realtek drivers. I had AVG, but uninstalled deleting all of the stuff in the vault, since I've been having issues with malware like crazy (conduit, trovi). So avg is gone, and so is whatever file it deleted. I reinstalled my exact systems audio driver from the Asus webpage, and it didn't fix. Also, control panel no longer loads, and just freezes up. When I try to run sfc /scannow, it just goes to the next line, and the cursor continues to blink away for ages and won't do anything. I also don't have any restore points to go back too (no idea why that's turned off). I'm trying to install bitdefender free trial, hoping to find something bad that it can get rid of, and magically fix my issue. But its just sitting at the "0%" installing, and has been for about 20 minutes. Malwarebyes won't complete a scan either. I've restarted multiple times, and restart time is ridiculously slow now. I have no idea what to do. But I can't reinstall windows because I have very important files with no physical backup. So I'd lose absolutely everything. My laptop is an Asus K53TK, and has been working perfectly fine since the year I've had it. No physical damage, and have always kept it clean, sorted and whatnot. But any idea what is wrong with my computer? There's got to be a better way than just reinstalling :/ there also isn't a Windows Audio service running. There was earlier, but it wasn't running, and when I tries to start it, it said something like the specified path could not be found. But now the windows audio service is just gone from the list. Although the others that I need are running fine :/
