The thread is about badly rendered browser tab favicons in Microsoft Edge. The main troubleshooting steps were to test for extension/profile issues, then disable hardware acceleration; the user confirmed that turning off “Use hardware acceleration when available” and restarting Edge resolved the problem. Overall sentiment is friendly and positive, with the assistant offering multiple fixes and the original poster thanking contributors after the fix.
This step solved it:You’re welcome — glad it’s sorted and thanks for the screenshot (Zkurvené ikony karet MS Edge - vyřešeno.webp). If you like, post which step fixed it so others can follow, or I can add a short how-to to the thread. Mark the thread as solved when you’re ready. Have a nice day — Jan.
2) Disable hardware acceleration (fast test for rendering glitches)
- Go to edge://settings/system and turn off “Use hardware acceleration when available”, then restart Edge.
Thanks
- Joined
- Mar 14, 2023
- Messages
- 113,541
I can see the screenshot you attached — thanks. That looks like favicons (tab icons) are rendering badly in Edge. A few quick checks and fixes usually get this sorted. (I noticed your original post here on the forum. order:
1) Quick checks
1) Quick checks
- Open an InPrivate window (Ctrl+Shift+N). If the icons look normal there the problem is likely an extension or profile cache.
- Disable all extensions and reload Edge to check if one of them is the culprit.
- Settings > Privacy, search and services > “Choose what to clear” > Cached images and files. Restart Edge.
- Close Edge completely (check Task Manager).
- Open File Explorer and navigate to:
%localappdata%\Microsoft\Edge\User Data\Default - Find files named Favicons and Favicons-journal (and optionally Web Data / Top Sites). Move them to a backup folder (or rename to Favicons.old).
- Restart Edge — it will rebuild the favicon database.
- Create a new Edge profile (Settings > Profiles > Add profile) and open the same sites — if favicons are fine, your profile’s cache is at fault.
- Close Edge. Run from Run dialog or a shortcut:
msedge --disable-gpu
If that fixes it, update/rollback your GPU driver or leave hardware acceleration off.
- Settings > Reset settings > Restore settings to their default values. Or in Windows Settings > Apps find Microsoft Edge and choose Repair (or Reset) if available.
- Make sure Edge and Windows are up to date, and get the latest GPU driver from your vendor (Intel/NVIDIA/AMD).
- If nothing helps, export bookmarks, remove/rename the entire %localappdata%\Microsoft\Edge\User Data\Default folder (back it up first) and let Edge create a fresh profile. Reinstall Edge only if necessary.
- Edge version (edge://settings/help) and Windows version,
- whether the same issue appears in Chrome/Firefox,
- whether the problem is only with certain sites or all tabs.
Jan Dousa
Member
- Joined
- Aug 10, 2025
- Messages
- 3
1) Quick checks
3) Clear browsing cache
4) Delete Edge’s favicon cache (safe; Edge will rebuild it)
5) Test with a fresh profile
%localappdata%\Microsoft\Edge\User Data\Default- Find files named Favicons and Favicons-journal (and optionally Web Data / Top Sites). Move them to a backup folder (or rename to Favicons.old).
6) Run Edge without GPU (if disabling acceleration helped)
7) Reset or repair Edge
8) Update Edge, Windows and GPU drivers
9) Last resort: rebuild profile or reinstall Edge
If you want, tell me:
If you want the step-by-step commands for deleting the favicon files or rebuilding the Windows icon cache (if you also see broken system icons), I can post exact commands — the forum archives include the usual icon-cache rebuild steps if needed.
Thank you
Have a nice day
Jan Douša
- Joined
- Mar 14, 2023
- Messages
- 113,541
Jan Dousa
Member
- Joined
- Aug 10, 2025
- Messages
- 3
Thanks
- Joined
- Mar 14, 2023
- Messages
- 113,541
Perfect — glad that fixed it. I saw your follow‑up in the thread. ecommendations you can add to the thread (optional):
- Update your GPU driver (Intel/NVIDIA/AMD) before re‑enabling hardware acceleration.
- After updating, re‑enable acceleration at edge://settings/system to confirm the fix — if the icons break again, leave it off until you can do a clean driver reinstall/rollback.
- If it recurs in other browsers too, suspect the GPU driver or Windows graphics stack; a clean driver install (DDU + vendor driver) usually helps.
