Hi all,
Hopefully you all can help me, as I've tried everything I can think of and my C: drive is running at 100% for the first 10 minutes after boot,, then sometimes goes back to 0 and is completely unresponsive or very slow. I've downloaded multuple virus scanners, malaware, spyware, and found pretty much nothing..I tried taking off microsft essentials and it didn't completely uninstall. I tried reinstalling and get an error that the wizard can't start.. I followed all the suggestions from forums and frrom Microsoft and nothing. The error code it gives is:
'0x80070643'. I've made sure thal only programs I want to start are starting. I also tried to get uninstall 'MS Live', and for whatever reason half of the software didn't install...That's why I only install MS updates and software that I want, as I don't need or want MS Live or MS Security Essentials. I got rid of all my other anti spyware, malaware, virus scanner, as that's what Microsoft said to do with that eorror code I got from trying to reinstalling MSE. Only reason I wanted to reinstall iit is so I could try and uninstall it completely. I looked at the performance monitor and found these two files/directorys doing a ton of R/W on my drive.
C:\Windows\System32\config\RegBack\COMPONETS
c:\$Logfile
I don't use 'System Restore' as I've found over the years it doesn't work most of the time..My old HD was giving me read errors, so I bought 'EasyToDo Back' software to help me image my HD on the new..That was cake.This software comes with a 'snapshot' componet like system restore, but works 99% of the time and brings back everything, files, etc. .I now have a WD Black Scorpio that's being beaten up by 'something' on my machine. I'm pretty well versed with Windows, but I can't figure it out..If I had my Vista CD, I'd do a complete wipe and rieinstall.This problem started before the new drive. At this momment my cursor is now jumping around every 1-2 minutes while I type screwing up what I wrote. No virus's or malaware last time I checked, but I'm running wide open as of now to try to uninstall MSE..I also have 3 serivces that I can't get ride of..I can't control them, but they are listed after I uninstalled the program..Not sure what the 'Andrea' service came with...I even used 'Recuva Uninstaller' that helps with deleting reg keys left over, but they are still there..'Amazon Unbox', Andrea ST Filer Service, and Microsoft Antimalaware Service...I've taken out the battery, memory and let it still..I've done everything that I've know and suggestions from others.My laptop is a Dell Inspiron 1525 and all the hardware is solid. I did do some dell updates for my service tag a few months back and remember having some 'hanging' issues, so I rolled back those installs. I also deleted 2 profiles, as one got corrupted and other was having issues, so I wanted to try a new profile to see if that fixed my problems..Admin rights of course..I've also going into the 'hidden' admin acct..I'm glad I found about it as most don't know it's there and it has no pword..Big security issue.. Sorry for the long post, but I wanted to give you all the details. I uploaded a log file from Hijack this that I ran right before I posted here.
Thanks for reading....jc
c:\$Logfile
and take your laptop to a local Computer Pro who is licensed and can do this for you. This process is for the Advanced User only. I'm not saying you are not; but, if you haven't done this many times before you might be looking at a $200-$300 repair on an 8 year old laptop--probably not worth it since you can buy a brand new Chromebook for $249. The other thing you haven't addresses is the state of your internal hardware, Mobo, RAM, Hard Drive, and CPU/GPU. Those should all be tested before you attempt this upgrade, as reinstalling from Recovery Media Set or from a Boxed Windows Vista CD will still not operate correctly if you have a faulty hardware component. In a second-hand laptop of that age, the likelyhood is statistically significant there is at least 1 failing or faulty component. And once again I am back to taking it to a Pro if you are not comfortable with or know how to run all the complex tests I'm talking about.
