FairCold
as the title mention, my viewsonic LCD is not working with my copy of window 7. i dont know why. i have tried with my old samsung CRT, both of the DVI (using DVI-VGA converter) and VGA outout is working perfectly, but i cant get my LCD working. when i boot from safe mode, the LCD working. here is my system spec. hope to solved this problem soon.
OS: MS window 7 ultimate 64bit
window version: 6.1.7600 build 7600
processor: Q6600
mobo: gigabyte GA-P35-DS3
mobo bios: F14 (latest)
GFX card: palit HD 4870 sonic dual version (512mb)
GFX driver: 9.12
RAM: CORSAIR DOMINATOR 4G DDR2
HDD: WD 320G
PSU: CM 650W
OUTPUT:
1.VIEWSONIC VX1935WM
2.SAMSUNG 107T
thanks in advance..
If you are trying to run two monitors, you might turn one off until you get the viewsonic working. What type of connection are you using for the LCD? Is it a DVI input, or something else?
Saltgrass
