The thread discusses an issue with disabled audio in Windows 10 build 10130, with the original poster seeking a simple fix or downgrade options. A responder suggests reinstalling audio drivers in compatibility mode, which successfully resolves the issue. The overall tone is positive, concluding with the original poster thanking the helper for the solution.
Adder719
With windows 10's latest build, version 10130, it has completely disabled audio, i had an issue back when i first started, but that had some sounds, this has none at all. i have tried a number of different things. Is there some stupidly easy fix, or would i have to downgrade? and if i have to downgrade, may i have a link the the previous version? thanks!
Operating System
Windows 10 Pro Insider Preview 64-bit
CPU
AMD Phenom II X2 555 52 °C
Callisto 45nm Technology
RAM
4.00GB Single-Channel DDR2 @ 399MHz (5-5-5-18)
Motherboard
ASUSTeK Computer INC. M4A785-M (AM2) 55 °C
Graphics
PANASONIC-TV (1366x768@60Hz)
1792MB NVIDIA GeForce GTX 260 (NVIDIA) 47 °C
Storage
223GB SSD2SC240G1SA754D117-820 ATA Device (SSD)
Optical Drives
No optical disk drives detected
Audio
VIA HD Audio
