The thread discusses a user experiencing connection issues (error 651) when setting up a new TP-Link TD-8817 modem with an ADSL service after switching providers. Several contributors suggest troubleshooting steps, including proper use of filters, correct configuration of PPPoE credentials, driver updates, and network diagnostics. Overall, the exchange reflects a constructive effort to identify and resolve the connectivity problem through technical guidance.
aussiejake
Okay, not even sure where to start. Moving from Australian providers Optus to Telstra based Exetel.
The brand new TP-Link 8817 modem is connected to the phone line (with the filter on), the computer via ethernet and the power source.
Four lights on the modem are lit (power, internet, lan, adsl).
I've gone into the web GUI settings for the modem and done the quick set up. Username/password input, PPPoE connection, 8/35 on the VPI/VCI, connection type PPPoe LLC.
All saved. Now I go to set up my connection using the connection wizard. Input password/username. Connect...... doesn't get past the 'connecting through WAN Miniport (PPPOE)'.
Now I'm getting 'error 651'.
Previously I've tried with another modem and bridged it, using a TP-Link TL-WR1043ND as the router. This didn't work, Windows saying it was a 'DNS server isn't responding'.
I'm at a loss with what the problem is, two different forums have been unable to help.
Any thoughts guys? Need any more information?
Update the driver for your Realtek adapter from here Link Removed using the following manual update method
Driver Install - Manual Method
  1. Download the driver and extract it to a folder.
  2. Open the Device Manager.
  3. Right click the device you wish to change the drivers for. You can select Properties > Driver > Driver Details to check you have the right device.
  4. Choose Update Driver Software.
  5. Select Browse My Computer For Driver Software.
  6. Select Let me pick from a list of device drivers on my computer.
  7. Select Have disk...
  8. Select Browse..
  9. Navigate to the extracted folder and double click on the .inf file
  10. Hit OK...
Saltgrass
I have to ask, are you using an ADSL filter on the Modem connection?
ADSL connections can be very susceptible to noise on a phone line. Have you tried other outlets?
Saltgrass
Well, I may be a little confused, or something has changed since I had ADSL. The filters were normally put on phones to block the ADSL signal. If you have it on the modem, would it not block the signal you need?
Trouble
Noob Whisperer
Clark is correct you do not use the noise filter on the DSL line, only on the actual line that goes to the phones using the same line.
Second usually you;
A. Don't configure your username and password in two places for a PPPoE connection. Either on the WAN side of the Router if a router is being used or on the PC in the connection properties not both.
and
B. You don't connect nor configure the connection on the WAN MiniPort device but rather on the ethernet adapter itself.... are you maybe connecting using a USB connection or something?
So can you explain your network just a bit more. Which TP-Link 8817 it seems there are a few different ones.
Assuming you have only a single ethernet cable running from the TP Link to the computer's network adapter can you share with us the Manufacturer Name, Model Name, Model Number, Revision Number, Driver version and Driver date for that adapter?
Can you open a command prompt and type
ipconfig /all and paste the results into your next post.
aussiejake
Thread Author #6
Second usually you;
and
The filter has a section for ADSL and for phone. Maybe it's called a splitter.
Modem is a TP-Link TD-8817, that's all it says on the box. What other things do you want to know about my network?
As for network adapter, this is from device manager: Realtek PCIe GBE Family Controller. Driver version: 7.26.902.2010. Driver date: 2/09/2010.
C:\Windows\system32>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Jakes-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection 3:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : SAMSUNG Mobile USB Remote NDIS Network De
vice
Physical Address. . . . . . . . . : 02-53-6D-6B-61-32
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::85ad:4600:95e7:44ca%17(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.42.7(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Monday, 23 July 2012 10:23:23 AM
Lease Expires . . . . . . . . . . : Monday, 23 July 2012 11:23:23 AM
Default Gateway . . . . . . . . . : 192.168.42.129
DHCP Server . . . . . . . . . . . : 192.168.42.129
DHCPv6 IAID . . . . . . . . . . . : 402805613
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-13-86-7C-B5-6C-F0-49-75-28-93
DNS Servers . . . . . . . . . . . : 192.168.42.129
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 6C-F0-49-75-28-93
Link-local IPv6 Address . . . . . : fe80::f413:9432:5be6:8c4c%15(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.100(Preferred)
Lease Obtained. . . . . . . . . . : Monday, 23 July 2012 10:21:41 AM
Lease Expires . . . . . . . . . . : Thursday, 26 July 2012 10:21:42 AM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 325906505
DNS Servers . . . . . . . . . . . : 192.168.1.1
Tunnel adapter isatap.{C9397D01-87F1-4B45-8C5C-16C88BEB9582}:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fb:408:2ed9:3f57:d5f8(Prefe
rred)
Link-local IPv6 Address . . . . . : fe80::408:2ed9:3f57:d5f8%10(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.{C5FBD8E9-5D75-4D00-91F6-43BE6BC5CE21}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Trouble
Noob Whisperer
  8. Select Browse..
  10. Hit OK, then Next and the driver(s) will then begin to install.
  11. After it has installed, GoTo C:\Windows\System32\Drivers. Locate the driver you've just updated, right click it and check the dates under its properties.
Remove the USB connection from the equation (disconnect or disable).
Disable IPv6 by unchecking the box in the properties of the Realtek Network adapter.
With only the Realtek adapter connected to your network, see what you can ping.
Open a command prompt and type
ping 192.168.1.1
hit enter (post back the results)
then type
ping 209.85.145.105 (post back the results)
open a browser and in the address (URL) bar (not search box) type
209.85.145.105
and hit enter (post back the results
