The thread details a user's struggle with installing Windows 7 after deleting all hard drive partitions. Initially, they encounter issues with partition recognition and GPT partition style errors, but after deleting the existing partitions and creating a new one during the installation process, the user proceeds with the installation. Throughout the discussion, guidance is provided on booting from the CD, setting the correct boot order, and managing disk partitions, leading to the successful start of Windows installation.
- Joined
- Aug 28, 2007
- Messages
- 36,163
K, i changed a usb setting in bios and its now letting me use my usb
Pheeew.. I'm so glad you got this working. I was thinking 'omg I've helped this guy ruin his laptop!'
Hmm... That's not really a good app especially for laptops. The reason being is laptop drivers are supplied by the laptop manufacturer and other versions may cause bsod as well as instability.I am using driver booster so hopefully i get all the needed drivers.
I had already used driver booster before seeing your post but everything seems to be working now.
Im now ready to copy my os to my external hard drive if your ready but i would like to have other os on my external hard drive as well. i have to leave around 5:15Pm UTC-06:00 Central time and i wont be able to do anything with my computer until tomorrow after that time.
Edit: I want to thank you for all the help you have given me so far.
Edit2: Basically what i need help with now is copying my os and all its contents to a external usb hard drive but have enough room to have a couple other os on it. I have clonezilla on a usb.
- Joined
- Aug 28, 2007
- Messages
- 36,163
Ok try this app to do the back up with:
Review: Easeus Todo Backup Free is the most comprehensive free backup
(it's free)
This guide should be all you need:
The absurdly simple guide to backing up your PC
(it's free)
- Joined
- Aug 28, 2007
- Messages
- 36,163
I've never used it personally.K, do you know if clonezilla would be able to do what I'm wanting?
One last question and if you dont know the answer then i will create another thread.
Have you ever used Windows Vista/2008/7/2008 R2 Fast Installer?
If so can you please help me get it working? It creates the windows files on my usb but it wont boot.
- Joined
- Aug 28, 2007
- Messages
- 36,163
To be honest no i haven't although have you tried either this:
Or this:
Rufus - Create bootable USB drives the easy way
Or this:
I have an idea but i need you to tell me if it would work. I want to get a hard drive and then connect it to a desktop pc and install windows 7 with my cd and then connect the hard drive to my laptop with a hard drive enclosure. Would that work or would there be some problems?
- Joined
- Aug 28, 2007
- Messages
- 36,163
If it was plugged into USB then no as you cannot boot off external drives. If it was connected to a SATA port then maybe but I doubt Windows would be happy you may find your plagued with bsod's. Usually moving an HDD directly to another machine means a re-install.
