Windows 10 Anyone else having issues with Edge ????
brkkab
I'm curious if anyone else besides me has been having issues with Edge, since last night?
For me all of a sudden as of last night when I open Edge it loads and then crashes/disappears from the desktop where it was opened at.
No homepage loading or anything, just a almost immediate crash.
I look in Settings > Updates & Security > Troubleshoot and Microsoft has no Edge troubleshooter there.
Does anyone know of them having a downloadable Edge troubleshooter on their website ?
kemical: No, what command for it ?
There you go Keith:
File scans
Right click on the Start menu icon and from the revealed list choose 'admin command prompt'. Type:
sfc /scannow
press enter and await results
Bitdefender Total Security & Windows Defender both found no threats on my pc.
Check Disk found no errors on my ssd's or hdd either.
After posting I ran the Windows Defender Offline Scan. It only runs a quick scan on restart. No malware found.
I then ran Bitdefender Total Security's Rescue Scan and it also found nothing.
Weird, I had Edge as the default and it was working fine until around 8:00 P,M. lsat night.
I've tried it nymerous times today and it still crashes before the home page (Bing) show's anything.
IE, Chrome, Firefox, Opera, Windows Update, Store, Steam, Uplay, Origin, GOG Galaxy and anything else that uses the internet all work fine.
It's just Edge that doesn't.
Switched back to IE as default until Edge works again.
Is there a way I can try Edge in Private Mode from the start and see if maybe it's some sort of Edge Extension bug that just started ?
There you go Keith:
File scans
sfc /scannow
kemical: sfc/scannow found no issues.
dism /online /cleanup-image /restorehealth gave a error seen in the screenshot.
An image from 'Anyone else having issues with Edge ????'. Windows system scan completed with no issues, but DISM restorehealth failed due to missing source files.
I put my flash drive in with the Windows 10 17134 files that the Media Creation Tool made.
No clue how to point dism /online /cleanup-image /restorehealth to it.
On my pc the flash drive is drive G:.
