Windows 7 BSOD - ntoskrnl.exe, ntsf.sys -- System Service Exception and IRQL Not less or equal.
Malifex
I had some issues with ATI catalyst and AOD drivers when I first unpackaged this computer, but once I disabled them, the computer worked fine for a long time. Now all of a sudden, I get random BSOD's with no rhyme or reason as to why. Attached are all the requested files from the sticky. Thanks in advance for any help on what could be causing this.
Hi Malifex and Welcome to The Forum. Apologies for the seemingly long wait for a reply, sometimes posts just slip by....
STOP 0x0000003B: SYSTEM_SERVICE_EXCEPTION
Usual causes:
System service, Device driver, graphics driver, ?memory.
Your latest dump file lists memory_corruption as the probable cause which usually indicates out of date Drivers, Bad Memory or incorrectly configured Memory Timings.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes can often indicate hardware issues.
As a Priority:
McAfee is known to be a cause of BSOD's on some Windows 7 systems. I suggest that you uninstall McAfee using the McAfee Removal Tool . Download Link Removed due to 404 Error as its replacement. Make sure your Windows firewall is enabled! Once your BSOD issues are resolved, feel free to try the latest version of McAfee.
Run Memtest86+ overnight, after your computer has been off for about an hour or two so it has a cold start. Ideally let it run for at least 7 passes / 6-8 hours. If errors appear before that you can stop that particular test.
Note!! Any time Memtest86+ reports errors, it can be either bad RAM or a bad Mobo slot. Test RAM sticks individually. When you find a good one then test it in all slots. Post back with the results.
Drivers with Updates:
atikmdag.sys Thu Mar 31 07:45:51 2011
atikmpag.sys Thu Mar 31 07:15:03 2011
AMD Graphics Drivers
nusb3hub.sys Fri Jan 22 03:22:18 2010
nusb3xhc.sys Fri Jan 22 03:22:21 2010
Go to your Motherboard Mfr. Support website (or Link Removed - Invalid URL) and update your USB 3.0 drivers. A June 2011 set are available Here.
RTKVHD64.sys Tue Mar 15 10:27:07 2011 Realtek HD Audio R2.66
After updating the drivers above and confirming your ram is OK you might need to run Driver Verifier to force some crashes.
I'd suggest that you first backup your stuff and then make sure you've got access to another computer so you can contact us if problems arise. Then make a System Restore point (so you can restore the system using the Windows 7 Startup Repair feature).
You can make a Startup Repair disk by going to Start >> All Programs >> Maintenance >> Create a System Repair Disc.
To start Driver Verifier:
- GoTo Start and in the Search or a Run... Window type verifier and press Enter.
- Select Create custom settings (for code developers) and click Next.
- Select Select individual settings from a full list and click Next.
- Select every option EXCEPT for Low Resource Simulation and click Next.
- Select Select driver names from a list and click Next.
- Select all drivers listed that are NOT provided by Microsoft and click Next.
- Select Finish on the next page.
Reboot the system and wait for it to crash to the Blue Screen. If this happens as soon as Windows tries to start then try it in Safe Mode. Continue to use your system normally, if you know what causes the crash, do that repeatedly. The objective is to get the system to crash because Driver Verifier is stressing the drivers out and hopefully create a pattern.
On the extremely rare occasion that you can't get into Safe Mode, use System Restore from your installation DVD / Restore Disc to set the system back to the previous restore point that you created.
If it doesn't crash for you, then let it run for at least 36 hours of continuous operation (an estimate on my part).
To turn off Driver Verifier when finished, Open a Command Prompt or Run... window and type verifier /reset and press Enter/OK.
or
GoTo Start and in the Search or a Run... Window type verifier. Select Delete existing settings and press "Finish".
Bugcheck Analysis:
BugCheck 3B, {c0000005, fffff80002f3645f, fffff880066f1da0, 0}
Probably caused by : memory_corruption ( nt!MiRelinkStandbyPage+8f )
Followup: MachineOwner
0: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff80002f3645f, Address of the instruction which caused the bugcheck
Arg3: fffff880066f1da0, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
FAULTING_IP:
fffff800`02f3645f 440fb6421b      movzx   r8d,byte ptr [rdx+1Bh]
CONTEXT:  fffff880066f1da0 -- (.cxr 0xfffff880066f1da0)
rax=0000000000000002 rbx=0000000000000002 rcx=00000000001625bc
rdx=002ffa80042746d0 rsi=000000000000000a rdi=fffffa8004274490
rip=fffff80002f3645f rsp=fffff880066f2780 rbp=0000000000000001
 r8=fffff880066f27b0  r9=0000000000000002 r10=fffffa800605e1b0
r11=00010000001626cf r12=fffff800030c4c40 r13=0000000000000000
r14=0000058000000000 r15=0000000000000000
iopl=0         nv up ei pl nz na pe nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010202
nt!MiRelinkStandbyPage+0x8f:
fffff800`02f3645f 440fb6421b      movzx   r8d,byte ptr [rdx+1Bh] ds:002b:002ffa80`042746eb=??
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x3B
PROCESS_NAME:  svchost.exe
CURRENT_IRQL:  2
LAST_CONTROL_TRANSFER:  from 0000000000000000 to fffff80002f3645f
STACK_TEXT:
fffff880`066f2780 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!MiRelinkStandbyPage+0x8f
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!MiRelinkStandbyPage+8f
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP:  4e02aaa3
STACK_COMMAND:  .cxr 0xfffff880066f1da0 ; kb
IMAGE_NAME:  memory_corruption
FAILURE_BUCKET_ID:  X64_0x3B_nt!MiRelinkStandbyPage+8f
Drivers:
fffff880`00ee2000 fffff880`00f39000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`01600000 fffff880`01689000   afd      afd.sys      Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`06e00000 fffff880`06e16000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`01200000 fffff880`0120b000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`013c8000 fffff880`013d1000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`013d1000 fffff880`013fb000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`07059000 fffff880`072a3000   athrx    athrx.sys    Fri Oct 29 01:29:03 2010 (4CCA154F)
fffff880`0762d000 fffff880`07e65000   atikmdag atikmdag.sys Thu Mar 31 07:45:51 2011 (4D94231F)
fffff880`00da8000 fffff880`00df5000   atikmpag atikmpag.sys Thu Mar 31 07:15:03 2011 (4D941BE7)
fffff880`01448000 fffff880`01452000   atitray64 atitray64.sys Sun Mar 27 11:29:33 2011 (4D8F118D)
fffff880`00faa000 fffff880`00fb6000   BATTC    BATTC.SYS    Tue Jul 14 00:31:01 2009 (4A5BC3B5)
fffff880`0424f000 fffff880`04256000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`0101e000 fffff880`0102f000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`03efb000 fffff880`03f19000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff880`073d7000 fffff880`073e2000   btath_bus btath_bus.sys Thu Jun 24 07:17:43 2010 (4C22F887)
fffff960`006e0000 fffff960`00707000   cdd      cdd.dll      unavailable (00000000)
fffff880`043cc000 fffff880`043f6000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`01aa5000 fffff880`01ad5000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00d4a000 fffff880`00da8000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`06fb2000 fffff880`06fb6500   CmBatt   CmBatt.sys   Tue Jul 14 00:31:03 2009 (4A5BC3B7)
fffff880`016da000 fffff880`0174c000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`00fa1000 fffff880`00faa000   compbatt compbatt.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`06fe6000 fffff880`06ff6000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`09ad9000 fffff880`09ae7000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`01000000 fffff880`0101e000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`01439000 fffff880`01448000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`01a8f000 fffff880`01aa5000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`09200000 fffff880`09222000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`04200000 fffff880`04246000   dtsoftbus01 dtsoftbus01.sys Fri Jun 17 08:38:37 2011 (4DFB047D)
fffff880`093e6000 fffff880`093f9000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`04264000 fffff880`043b8000   dump_iaStor dump_iaStor.sys Thu Jan 13 01:50:12 2011 (4D2E5A54)
fffff880`09a6a000 fffff880`09a76000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`07e65000 fffff880`07f59000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`08400000 fffff880`08446000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`09158000 fffff880`0918e000   fastfat  fastfat.SYS  Tue Jul 14 00:23:28 2009 (4A5BC1F0)
fffff880`01257000 fffff880`0126b000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`0120b000 fffff880`01257000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`0175d000 fffff880`01767000   Fs_Rec   Fs_Rec.sys   unavailable (00000000)
fffff880`01a55000 fffff880`01a8f000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01cf9000 fffff880`01d43000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff800`033fb000 fffff800`03444000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`07f59000 fffff880`07f7d000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`0934d000 fffff880`093a9000   HdAudio  HdAudio.sys  Sat Nov 20 10:44:23 2010 (4CE7A687)
fffff880`07f7d000 fffff880`07f8e000   HECIx64  HECIx64.sys  Wed Oct 20 00:33:43 2010 (4CBE2AD7)
fffff880`090aa000 fffff880`090b2080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`03e32000 fffff880`03efb000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`01a4c000 fffff880`01a55000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`072e2000 fffff880`07300000   i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01274000 fffff880`013c8000   iaStor   iaStor.sys   Thu Jan 13 01:50:12 2011 (4D2E5A54)
fffff880`08446000 fffff880`08ff7bc0   igdpmd64 igdpmd64.sys Sat Mar 26 01:17:43 2011 (4D8D3EB7)
fffff880`06fd0000 fffff880`06fe6000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`07300000 fffff880`0730f000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff800`00bbc000 fffff800`00bc6000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`07394000 fffff880`073d7000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`01400000 fffff880`0141b000   ksecdd   ksecdd.sys   Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`01860000 fffff880`0188b000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`09222000 fffff880`09227200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`07600000 fffff880`07615000   L1C62x64 L1C62x64.sys Mon Sep 27 07:36:23 2010 (4CA03B67)
fffff880`09279000 fffff880`0928e000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`09256000 fffff880`09279000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00ce7000 fffff880`00d36000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`0903f000 fffff880`0905ad00   mfeapfk  mfeapfk.sys  Wed Mar 02 16:38:39 2011 (4D6E728F)
fffff880`09d95000 fffff880`09dc1980   mfeavfk  mfeavfk.sys  Wed Mar 02 16:39:02 2011 (4D6E72A6)
fffff880`09a00000 fffff880`09a69980   mfefirek mfefirek.sys Wed Mar 02 16:42:01 2011 (4D6E7359)
fffff880`010cf000 fffff880`0114e100   mfehidk  mfehidk.sys  Wed Mar 02 16:38:02 2011 (4D6E726A)
fffff880`016c5000 fffff880`016d5980   mfenlfk  mfenlfk.sys  Wed Mar 02 16:38:26 2011 (4D6E7282)
fffff880`01d43000 fffff880`01d86380   mfewfpk  mfewfpk.sys  Wed Mar 02 16:38:16 2011 (4D6E7278)
fffff880`091bf000 fffff880`091cd000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`06fa3000 fffff880`06fb2000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`010b5000 fffff880`010cf000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`03f19000 fffff880`03f31000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`0905b000 fffff880`09083000   mrxdav   mrxdav.sys   Sat Nov 20 09:26:42 2010 (4CE79452)
fffff880`03f31000 fffff880`03f5e000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`03f5e000 fffff880`03fac000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`03fac000 fffff880`03fd0000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`018c2000 fffff880`018cd000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00f42000 fffff880`00f4c000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`0114f000 fffff880`011ad000   msrpc    msrpc.sys    unavailable (00000000)
fffff880`0142e000 fffff880`01439000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01a3a000 fffff880`01a4c000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`043f6000 fffff880`043ff000   mwlPSDFilter mwlPSDFilter.sys Tue Aug 17 04:34:50 2010 (4C6A035A)
fffff880`017f6000 fffff880`017fe000   mwlPSDNServ mwlPSDNServ.sys Tue Aug 17 04:34:51 2010 (4C6A035B)
fffff880`0141b000 fffff880`0142e000   mwlPSDVDisk mwlPSDVDisk.sys Tue Aug 17 04:34:55 2010 (4C6A035F)
fffff880`018eb000 fffff880`019de000   ndis     ndis.sys     Wed Dec 29 06:16:18 2010 (4D1AD232)
fffff880`06e3a000 fffff880`06e46000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`0928e000 fffff880`092a1000   ndisuio  ndisuio.sys  Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`0730f000 fffff880`0733e000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`09338000 fffff880`0934d000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`017ac000 fffff880`017bb000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`01767000 fffff880`017ac000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`01800000 fffff880`01860000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`018cd000 fffff880`018de000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`017ea000 fffff880`017f6000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`02e12000 fffff800`033fb000   nt       ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`01458000 fffff880`015fb000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`06fbf000 fffff880`06fc7000   NTIDrvr  NTIDrvr.sys  Tue Apr 20 02:37:59 2010 (4BCD0577)
fffff880`04246000 fffff880`0424f000   Null     Null.SYS     unavailable (00000000)
fffff880`09320000 fffff880`09338000   nusb3hub nusb3hub.sys Fri Jan 22 03:22:18 2010 (4B5919EA)
fffff880`072b0000 fffff880`072e0000   nusb3xhc nusb3xhc.sys Fri Jan 22 03:22:21 2010 (4B5919ED)
fffff880`07000000 fffff880`07053000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`01689000 fffff880`016af000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00f8c000 fffff880`00fa1000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00f4c000 fffff880`00f7f000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`0174c000 fffff880`0175d000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`058de000 fffff880`05984000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`093a9000 fffff880`093e6000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00d36000 fffff880`00d4a000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`06e16000 fffff880`06e3a000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`0733e000 fffff880`07359000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`07359000 fffff880`0737a000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`0737a000 fffff880`07394000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`011ad000 fffff880`011fe000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`01df2000 fffff880`01dfb000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`018b0000 fffff880`018b9000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`018b9000 fffff880`018c2000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01a00000 fffff880`01a3a000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`092a1000 fffff880`092b9000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`09ae7000 fffff880`09d94980   RTKVHD64 RTKVHD64.sys Tue Mar 15 10:27:07 2011 (4D7F3EFB)
fffff880`05984000 fffff880`0598f000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`01de8000 fffff880`01df2000   speedfan speedfan.sys Fri Mar 18 16:08:46 2011 (4D83838E)
fffff880`01de0000 fffff880`01de8000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`090c0000 fffff880`09158000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`05800000 fffff880`05869000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`0598f000 fffff880`059c0000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`06e46000 fffff880`06e47480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`06e4a000 fffff880`06fa3000   SynTP    SynTP.sys    Fri Jul 30 04:26:57 2010 (4C524681)
fffff880`01af5000 fffff880`01cf9000   tcpip    tcpip.sys    Thu Sep 29 04:43:04 2011 (4E83E948)
fffff880`059c0000 fffff880`059d2000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`01d87000 fffff880`01d94000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`019de000 fffff880`01a00000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`017d6000 fffff880`017ea000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`005d0000 fffff960`005da000   TSDDD    TSDDD.dll    Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`0102f000 fffff880`01055000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`092b9000 fffff880`092c0000   TurboB   TurboB.sys   Mon Nov 29 23:02:31 2010 (4CF43107)
fffff880`06fb7000 fffff880`06fbf000   UBHelper UBHelper.sys Tue Jul 06 05:19:26 2010 (4C32AECE)
fffff880`09a84000 fffff880`09ad9000   udfs     udfs.sys     Sat Nov 20 09:26:11 2010 (4CE79433)
fffff880`073e2000 fffff880`073f4000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`09dc2000 fffff880`09ddf000   usbccgp  usbccgp.sys  Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`072e0000 fffff880`072e1f00   USBD     USBD.SYS     Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`07f8e000 fffff880`07f9f000   usbehci  usbehci.sys  Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`092c6000 fffff880`09320000   usbhub   usbhub.sys   Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`07f9f000 fffff880`07ff5000   USBPORT  USBPORT.SYS  Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`09083000 fffff880`0909e000   USBSTOR  USBSTOR.SYS  Fri Mar 11 04:37:16 2011 (4D79A6FC)
fffff880`09228000 fffff880`09255280   usbvideo usbvideo.sys Sat Nov 20 10:44:34 2010 (4CE7A692)
fffff880`00f7f000 fffff880`00f8c000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`04256000 fffff880`04264000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`0188b000 fffff880`018b0000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00fb6000 fffff880`00fcb000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`01059000 fffff880`010b5000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01d94000 fffff880`01de0000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`072a3000 fffff880`072b0000   vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`016af000 fffff880`016c5000   vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`06ff6000 fffff880`07000000   vwifimp  vwifimp.sys  Tue Jul 14 01:07:28 2009 (4A5BCC40)
fffff880`017bb000 fffff880`017d6000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`01ae3000 fffff880`01af3000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e2f000 fffff880`00ed3000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00ed3000 fffff880`00ee2000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`018de000 fffff880`018e7000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00020000 fffff960`00334000   win32k   win32k.sys   Thu Sep 29 05:03:02 2011 (4E83EDF6)
fffff880`06fc7000 fffff880`06fd0000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00f39000 fffff880`00f42000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`09ddf000 fffff880`09e00000   WudfPf   WudfPf.sys   Sat Nov 20 10:42:44 2010 (4CE7A624)
fffff880`0918e000 fffff880`091bf000   WUDFRd   WUDFRd.sys   Sat Nov 20 10:43:32 2010 (4CE7A654)
Unloaded modules:
fffff880`09000000 fffff880`09031000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`091cd000 fffff880`091e8000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  0001B000
fffff880`091ef000 fffff880`091fd000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0918e000 fffff880`091bf000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`09000000 fffff880`0901b000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  0001B000
fffff880`0918e000 fffff880`091a4000   LHidFilt.Sys
    Checksum:  00000000
    ImageSize:  00016000
fffff880`091cd000 fffff880`091e1000   LMouFilt.Sys
    Checksum:  00000000
    ImageSize:  00014000
fffff880`09091000 fffff880`090aa000   HIDCLASS.SYS
    Checksum:  00000000
    ImageSize:  00019000
fffff880`09083000 fffff880`09091000   hidusb.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`091a4000 fffff880`091b1000   mouhid.sys
    Checksum:  00000000
    ImageSize:  0000D000
fffff880`091e1000 fffff880`091ef000   kbdhid.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`091bf000 fffff880`091cd000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`09000000 fffff880`0903f000   RtsUStor.sys
    Checksum:  00000000
    ImageSize:  0003F000
fffff880`0bf7b000 fffff880`0bf97000   mfeapfk.sys
    Checksum:  00000000
    ImageSize:  0001C000
fffff880`0bf97000 fffff880`0bfa5000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0bfa5000 fffff880`0bfe4000   RtsUStor.sys
    Checksum:  00000000
    ImageSize:  0003F000
fffff880`091e0000 fffff880`091ee000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0be14000 fffff880`0bf68000   hiber_iaStor
    Checksum:  00000000
    ImageSize:  00154000
fffff880`0bf68000 fffff880`0bf7b000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`09000000 fffff880`0901c000   mfeapfk.sys
    Checksum:  00000000
    ImageSize:  0001C000
    Checksum:  00000000
    ImageSize:  00031000
fffff880`09083000 fffff880`0909e000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  0001B000
fffff880`0901c000 fffff880`0905b000   RtsUStor.sys
    Checksum:  00000000
    ImageSize:  0003F000
fffff880`0b6d7000 fffff880`0b6f3000   mfeapfk.sys
    Checksum:  00000000
    ImageSize:  0001C000
fffff880`0b74e000 fffff880`0b75c000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0b740000 fffff880`0b74e000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0b6f3000 fffff880`0b701000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0b6a6000 fffff880`0b6d7000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`0b65a000 fffff880`0b675000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  0001B000
fffff880`0b701000 fffff880`0b740000   RtsUStor.sys
    Checksum:  00000000
    ImageSize:  0003F000
fffff880`0b7a6000 fffff880`0b7c2000   mfeapfk.sys
    Checksum:  00000000
    ImageSize:  0001C000
fffff880`0b7f0000 fffff880`0b7fe000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0b675000 fffff880`0b6a6000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`0b63f000 fffff880`0b65a000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  0001B000
fffff880`0b600000 fffff880`0b63f000   RtsUStor.sys
    Checksum:  00000000
    ImageSize:  0003F000
fffff880`0b63f000 fffff880`0b793000   hiber_iaStor
    Checksum:  00000000
    ImageSize:  00154000
fffff880`0b793000 fffff880`0b7a6000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`0b7d4000 fffff880`0b7f0000   mfeapfk.sys
    Checksum:  00000000
    ImageSize:  0001C000
    Checksum:  00000000
    ImageSize:  0003F000
fffff880`0b66d000 fffff880`0b7c1000   hiber_iaStor
    Checksum:  00000000
    ImageSize:  00154000
fffff880`0b7c1000 fffff880`0b7d4000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`091d2000 fffff880`091e0000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`09185000 fffff880`091a1000   mfeapfk.sys
    Checksum:  00000000
    ImageSize:  0001C000
fffff880`09000000 fffff880`09071000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`091a1000 fffff880`091d2000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`09a76000 fffff880`09a84000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0907d000 fffff880`09098000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  0001B000
    Checksum:  00000000
    ImageSize:  00031000
fffff880`09062000 fffff880`0907d000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  0001B000
fffff880`09031000 fffff880`09062000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
Top Bottom
