Cory
I am running Windows 10 Technical Preview on my laptop currently on build 9926. Whenever I try to run Windows Update it either fails or installs the updates but I get BOSD System Thread Exception not handled in an infinite bootloop. I am able to run System Restore but it fails but it allows me to be able to boot into the OS and use the computer however I can no longer access the start menu or do a search using the search bar. It doesn't doesn't work. I have tried using my Windows 8 restore disks to go back to Windows 8 but the computer won't read them and in will only allow me to boot from a special USB Drive and the Windows Rollback option screen no longer shows up. Is there anything I can do? Can I reinstall Windows 10 again over the current Windows 10 or is that not possible? Or does anyone have any other options of what I can do to fix this?
options if the machine will boot to desktop;
1. press [windows key] + [x] and then press [k] to open the disc manager... take a screen shot of this page and post it.
options if the machine will NOT boot to desktop;
2. yes you can install another windows 10 but that doesn't fix the issue
Have you got a bios lock running on this laptop... most of them do... has it been disabled?
p.s make and model of the laptop... any mods you have done to the parts?
ussnorway
Windows Forum Team
