POASign
I purchased my current PC via Digital Storm (I'm not bashing, I love my PC other than this little annoyance it seemed to have shipped with) a couple of months ago, and ever since then, I've been having these random BSoD pop up. It first started happening after I shutdown my PC for the first time. I powered it up, I was on it for maybe 15~20min, and then it stuttered, and crashed. After that, it seemed to be okay. I made note that if I just didn't restart my PC, it wouldn't crash. Needless to say, that wasn't a fix.
At a certain point, I decided to downgrade my graphics drivers, and for some reason, that seemed to have helped my machine quite a bit. The crashes became sparse, and happiness ensued.
After returning to an old game I played many years ago (FFXI) I found out that with my drivers downgraded, my GTX 480 was failing at a game game over 6 years ago. I discovered that I had to update my drivers to the latest version, which did indeed fix my FPS issues as I know run the game on max settings with perfect FPS, but of course, the BSOD have returned with a vengeance. I've had 4 of them just today.
I have attached the 4 DMP files generated today in the hopes that someone can help me with this issue.
Thanks in advance. :)
EDIT: Sorry, didn't see the "Important" thread.
Link Removed due to 404 Error
CRITICAL_OBJECT_TERMINATION (f4)
A process or thread crucial to system operation has unexpectedly exited or been
terminated. Several processes and threads are necessary for the operation of the
system; when they are terminated (for any reason), the system can no
longer function.
Probably caused by : csrss.exe <--- Client Server Runtime Process
Something's not right with your system configuration, or bad drivers.
Update drivers:
Sonic Solutions driver part of CD/DVD software
PxHlpa64.sys Mon Jul 24 20:18:43 2006
Realtek LAN
Rt64win7.sys Thu Feb 26 04:04:13 2009
Logitech GamePanel
LGVirHid.sys Mon Nov 23 20:36:48 2009
Logitech SetPoint...
longer function.
Update drivers:
Realtek LAN
Logitech GamePanel
Logitech SetPoint
LUsbFilt.Sys Wed Jun 17 12:49:46 2009
XBox 360 driver
xusb21.sys Wed Apr 08 10:28:44 2009
Motherboard driver for NEC USB 3.0
nusb3hub.sys Thu Jan 21 22:22:18 2010
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\020311-17097-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`0304d000 PsLoadedModuleList = 0xfffff800`0328ae50
Debug session time: Fri Feb  4 02:13:10.267 2011 (UTC - 5:00)
System Uptime: 0 days 0:36:40.407
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck F4, {3, fffffa80079c3880, fffffa80079c3b60, fffff800033c85d0}
Followup: MachineOwner
6: kd> !analyze -v
terminated.
longer function.
Arguments:
Arg1: 0000000000000003, Process
Arg2: fffffa80079c3880, Terminating object
Arg3: fffffa80079c3b60, Process image file name
Arg4: fffff800033c85d0, Explanatory message (ascii)
Debugging Details:
PROCESS_OBJECT: fffffa80079c3880
IMAGE_NAME:  csrss.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  0
MODULE_NAME: csrss
FAULTING_MODULE: 0000000000000000
PROCESS_NAME:  csrss.exe
EXCEPTION_RECORD:  fffff880060c1b78 -- (.exr 0xfffff880060c1b78)
ExceptionAddress: 0000000076e4592d
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000001
   Parameter[1]: 0000000002780f18
Attempt to write to address 0000000002780f18
CUSTOMER_CRASH_COUNT:  1
CURRENT_IRQL:  0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_PARAMETER1:  0000000000000001
EXCEPTION_PARAMETER2:  0000000002780f18
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff800032f50e0
 0000000002780f18
FOLLOWUP_IP:
+6435656463326366
00000000`76e4592d ??              ???
FAULTING_IP:
+6435656463326366
FAILED_INSTRUCTION_ADDRESS:
+6435656463326366
BUGCHECK_STR:  0xF4_C0000005
STACK_TEXT:
fffff880`060c10f8 fffff800`03449652 : 00000000`000000f4 00000000`00000003 fffffa80`079c3880 fffffa80`079c3b60 : nt!KeBugCheckEx
fffff880`060c1100 fffff800`033f23e3 : ffffffff`ffffffff fffffa80`085f9560 fffffa80`079c3880 fffffa80`079c3880 : nt!PspCatchCriticalBreak+0x92
fffff880`060c1140 fffff800`0337a80c : ffffffff`ffffffff 00000000`00000001 fffffa80`079c3880 fffff6fb`00000008 : nt! ?? ::NNGAKEGL::`string'+0x17946
fffff880`060c1190 fffff800`030bc993 : fffffa80`079c3880 fffff800`c0000005 ffffe7cd`34d009dc fffffa80`085f9560 : nt!NtTerminateProcess+0x20c
fffff880`060c1210 fffff800`030b8f30 : fffff800`030f7dbc fffff880`060c1b78 fffff880`060c18e0 fffff880`060c1c20 : nt!KiSystemServiceCopyEnd+0x13
fffff880`060c13a8 fffff800`030f7dbc : fffff880`060c1b78 fffff880`060c18e0 fffff880`060c1c20 00000000`027821a0 : nt!KiServiceLinkage
fffff880`060c13b0 fffff800`030bcd82 : fffff880`060c1b78 00000000`000116e4 fffff880`060c1c20 00000000`02781c78 : nt!KiDispatchException+0x53b
fffff880`060c1a40 fffff800`030bb8fa : 00000000`00000001 00000000`000116e4 00000000`76f59001 00000000`76e7fcb8 : nt!KiExceptionDispatch+0xc2
fffff880`060c1c20 00000000`76e4592d : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x23a
00000000`02780f20 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x76e4592d
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
FAILURE_BUCKET_ID:  X64_0xF4_C0000005_IMAGE_csrss.exe
Drivers:
fffff880`042ce000 fffff880`0430c000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00ee6000 fffff880`00f3d000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02cd8000 fffff880`02d62000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04332000 fffff880`04348000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`00dd6000 fffff880`00de1000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`0a8f6000 fffff880`0a901000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00feb000 fffff880`00ff4000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00e00000 fffff880`00e2a000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`0191e000 fffff880`01925000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`02ca9000 fffff880`02cba000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`05392000 fffff880`053b0000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`006a0000 fffff960`006c7000   cdd      cdd.dll      unavailable (00000000)
fffff880`018eb000 fffff880`01915000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00cba000 fffff880`00d7a000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`00c5c000 fffff880`00cba000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01000000 fffff880`01073000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`04322000 fffff880`04332000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`01e5d000 fffff880`01e6b000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`02c8b000 fffff880`02ca9000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`02c7c000 fffff880`02c8b000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`0443d000 fffff880`0445f000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`01e6b000 fffff880`01e77000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`01e82000 fffff880`01e95000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`01e77000 fffff880`01e82000   dump_msahci dump_msahci.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`044c1000 fffff880`044cd000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`10af6000 fffff880`10bea000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`0fe00000 fffff880`0fe46000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`0112e000 fffff880`01142000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`010e2000 fffff880`0112e000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01200000 fffff880`0120a000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01833000 fffff880`0186d000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`015a9000 fffff880`015f3000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`0430c000 fffff880`04319000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`03004000 fffff800`0304d000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`0fe46000 fffff880`0fe6a000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`04465000 fffff880`044c1000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`01fd5000 fffff880`01fee000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`01fee000 fffff880`01ff6080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`01fc7000 fffff880`01fd5000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`052ca000 fffff880`05392000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`0149d000 fffff880`014a6000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`02cba000 fffff880`02cd0000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`04200000 fffff880`0420f000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`01e4f000 fffff880`01e5d000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bb8000 fffff800`00bc2000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`044d9000 fffff880`0451c000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`013d3000 fffff880`013ed000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01460000 fffff880`0148b000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`0445f000 fffff880`04464200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`0451c000 fffff880`0451fd80   LGBusEnum LGBusEnum.sys Mon Nov 23 20:36:48 2009 (4B0B38B0)
fffff880`05bf3000 fffff880`05bf5480   LGVirHid LGVirHid.sys Mon Nov 23 20:36:48 2009 (4B0B38B0)
fffff880`01e1b000 fffff880`01e2e000   LHidFilt LHidFilt.Sys Wed Jun 17 12:49:39 2009 (4A391EA3)
fffff880`01ec6000 fffff880`01edb000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`01e3b000 fffff880`01e4f000   LMouFilt LMouFilt.Sys Wed Jun 17 12:49:43 2009 (4A391EA7)
fffff880`01f73000 fffff880`01f96000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`01f96000 fffff880`01fa6000   LUsbFilt LUsbFilt.Sys Wed Jun 17 12:49:46 2009 (4A391EAA)
fffff880`00c04000 fffff880`00c48000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`0a901000 fffff880`0a91d000   MijXfilt MijXfilt.sys Fri Oct 01 22:34:10 2010 (4CA69A22)
fffff880`01f48000 fffff880`01f56000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`0420f000 fffff880`0421e000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`01e2e000 fffff880`01e3b000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00fd1000 fffff880`00feb000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`053b0000 fffff880`053c8000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`053c8000 fffff880`053f5000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`05200000 fffff880`0524e000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`0524e000 fffff880`05271000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`00ff4000 fffff880`00fff000   msahci   msahci.sys   Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`01983000 fffff880`0198e000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f46000 fffff880`00f50000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`0114e000 fffff880`011ac000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`02c71000 fffff880`02c7c000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`0148b000 fffff880`0149d000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`014b7000 fffff880`015a9000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`0436c000 fffff880`04378000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`04378000 fffff880`043a7000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`045a4000 fffff880`045b9000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02dd6000 fffff880`02de5000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02d62000 fffff880`02da7000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01400000 fffff880`01460000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`0198e000 fffff880`0199f000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02c65000 fffff880`02c71000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`0304d000 fffff800`03629000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`01230000 fffff880`013d3000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`01915000 fffff880`0191e000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`04532000 fffff880`0454a000   nusb3hub nusb3hub.sys Thu Jan 21 22:22:18 2010 (4B5919EA)
fffff880`01800000 fffff880`01830000   nusb3xhc nusb3xhc.sys Thu Jan 21 22:22:21 2010 (4B5919ED)
fffff880`10af4000 fffff880`10af5180   nvBridge nvBridge.kmd Fri Jan 07 20:57:22 2011 (4D27C482)
fffff880`045b9000 fffff880`045e2000   nvhda64v nvhda64v.sys Thu Nov 11 18:10:36 2010 (4CDC77EC)
fffff880`0fe99000 fffff880`10af3d00   nvlddmkm nvlddmkm.sys Fri Jan 07 21:07:22 2011 (4D27C6DA)
fffff880`02db0000 fffff880`02dd6000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00f90000 fffff880`00fa5000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f50000 fffff880`00f83000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00fba000 fffff880`00fc1000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00fc1000 fffff880`00fd1000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`013ed000 fffff880`013fe000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`05a9c000 fffff880`05b42000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`04400000 fffff880`0443d000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c48000 fffff880`00c5c000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`01142000 fffff880`0114d2c0   PxHlpa64 PxHlpa64.sys Mon Jul 24 20:18:43 2006 (44C56363)
fffff880`04348000 fffff880`0436c000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`043a7000 fffff880`043c2000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`043c2000 fffff880`043e3000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`043e3000 fffff880`043fd000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`02c14000 fffff880`02c65000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`01968000 fffff880`01971000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01971000 fffff880`0197a000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0197a000 fffff880`01983000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`011ac000 fffff880`011e6000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`01edb000 fffff880`01ef3000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0429c000 fffff880`042ce000   Rt64win7 Rt64win7.sys Thu Feb 26 04:04:13 2009 (49A65B0D)
fffff880`05b42000 fffff880`05b4d000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`015f3000 fffff880`015fb000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`05a00000 fffff880`05a96000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`05b8c000 fffff880`05bf3000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`05b4d000 fffff880`05b7a000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`0421e000 fffff880`0421f480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01602000 fffff880`017ff000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`05b7a000 fffff880`05b8c000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`019bd000 fffff880`019ca000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`0199f000 fffff880`019bd000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02c00000 fffff880`02c14000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`004a0000 fffff960`004aa000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`019ca000 fffff880`019f0000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`01ef4000 fffff880`01f48000   udfs     udfs.sys     Mon Jul 13 19:23:37 2009 (4A5BC1F9)
fffff880`04520000 fffff880`04532000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`01e00000 fffff880`01e1ac00   usbaudio usbaudio.sys Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`01f56000 fffff880`01f73000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`02cd0000 fffff880`02cd1f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`0428b000 fffff880`0429c000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`0454a000 fffff880`045a4000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04235000 fffff880`0428b000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`0fe6a000 fffff880`0fe77000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00f83000 fffff880`00f90000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01925000 fffff880`01933000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01933000 fffff880`01958000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00fa5000 fffff880`00fba000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00d7a000 fffff880`00dd6000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01073000 fffff880`010bf000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`02de5000 fffff880`02e00000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`01958000 fffff880`01968000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e33000 fffff880`00ed7000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00ed7000 fffff880`00ee6000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02da7000 fffff880`02db0000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00070000 fffff960`00380000   win32k   win32k.sys   Tue Oct 19 23:08:46 2010 (4CBE5D3E)
fffff880`04319000 fffff880`04322000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f3d000 fffff880`00f46000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`01fa6000 fffff880`01fc7000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`01e95000 fffff880`01ec6000   WUDFRd   WUDFRd.sys   Mon Jul 13 20:06:06 2009 (4A5BCBEE)
fffff880`0a91d000 fffff880`0a92dd80   xusb21   xusb21.sys   Wed Apr 08 10:28:44 2009 (49DCB49C)
Unloaded modules:
fffff880`01883000 fffff880`018b3000   CLASSPNP.SYS
    Checksum:  00000000
    ImageSize:  00030000
fffff880`0186d000 fffff880`01883000   disk.sys
    Checksum:  00000000
    ImageSize:  00016000
fffff880`0a885000 fffff880`0a8f6000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`05a96000 fffff880`05a9c000   RTCore64.sys
    Checksum:  00000000
    ImageSize:  00006000
fffff880`018b3000 fffff880`018c1000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`018c1000 fffff880`018cd000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`018cd000 fffff880`018d8000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`018d8000 fffff880`018eb000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`04481000 fffff880`044b2000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`04496000 fffff880`044c7000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
