android27
im trying to connect to the internet at a motel and originally I got the unknown error occurred message so I used the trouble shooter then ran the fix it provided. No improvement just anew message about the checking the network adapter so I did that then the message change to contact your service provider. So I undid that fix and ran the network diagnostic. I did this several times and it came back with couldn't find the problem so I clicked on look for additional options which directed me to online/offline help/support well obvious I could only use the offline help search. nothing there but 100 or so "similar" topics which were not even close to my problem mainly suggestions to reset the modem which I obviously can't do because I don't have physical access to the damn thing. I should also mention that my girlfriend has been working online problem free this entire time using the same network but with windows 8 and ie 10. Two days later with four days of my stay here left I still can connect to every network on the block but have no internet access and now the message consistantly reads server not responding. I've tried disabling firewalls on both windows and my additional internet security software, I've reconfigured internet settings and restored the whole damn computer, I ran IPconfig. you name it I think I've tried it. I recently went back to the diagnostic logs and the ipconfig reports and everything looks good until I come to the last two lines
connected: no
reason:0x00028001
I searched the code from my phones browser and came up with jack what is it and how the hell can I fix it. please somebody help me because my laptop is not gonna survive the next four days I almost threw the damn thing off the balcony yesterday.
Please go to programs, accessories, command prompt and enter this command:
ipconfig /all
Post the output on here if you need help interpreting it.
Windows IP Configuration
Host Name . . . . . . . . . . . . : Andrew-HP
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : hotel
Ethernet adapter Local Area Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) Centrino(R) WiMAX 6250
Physical Address. . . . . . . . . : 64-D4-DA-24-E7-BD
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . : hotel
Description . . . . . . . . . . . : Intel(R) Centrino(R) Advanced-N 6250 AGN
Physical Address. . . . . . . . . : 64-80-99-07-6B-40
IPv4 Address. . . . . . . . . . . : 192.168.8.128(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Saturday, March 02, 2013 4:26:07 PM
Lease Expires . . . . . . . . . . : Saturday, March 02, 2013 6:35:32 PM
Default Gateway . . . . . . . . . : 192.168.8.1
DHCP Server . . . . . . . . . . . : 192.168.8.1
DNS Servers . . . . . . . . . . . : 8.8.8.8
8.8.4.4
NetBIOS over Tcpip. . . . . . . . : Enabled
Wireless LAN adapter Wireless Network Connection 3:
Description . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter #2
Physical Address. . . . . . . . . : 64-80-99-07-6B-41
Wireless LAN adapter Wireless Network Connection 2:
Tunnel adapter isatap.hotel:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 12:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter
Tunnel adapter isatap.{45AB4EB4-B856-4382-B10D-40DCEAA78A99}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter isatap.{16B9E59F-556B-4EEB-93F7-021713E503B2}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Tunnel adapter isatap.{F37A1CDC-1502-46A6-87FB-BA3444524A4A}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Go to the wireless adapter, properties, DNS server address. Manually set both addresses to 192.168.8.1
I tried to but it won't let me submit those changes and tells me the two dns servers must have different addresses
This thread is more than 6 years old. I suspect te OP May have checked out by now!
reason:0x00028001
this error code = blocked at the router and is common when the network is not set up correct... in other words the router sees you but for [insert reason] isn't allowing you past the firewall
