Windows 8 extended Display Not working properly
chathuranga8887
I have connected a display as extended monitor .but after i hibernate the laptop it diplay like this
Is there anyway to correct this issue .
just to clarify do you mean the browser repeating as there looks like several browsers open all with the same tabs open?
Have you checked for malware? Try running Malwarebytes
Are you running any extensions or plug-ins with the browsers? If so try disabling anything new or not wanted.
This because i hibernate the pc.if i shutdown the pc this will not appear again .but after the hibernate this appear again after the pc on
