Windows 7 gadgets not refreshing
polarizeme
is anyone else suddenly having a problem getting the weather gadget to refresh?
it tells me the correct time of day via the background image, but that's about it. it gives me the incorrect temperature, incorrect representation of the conditions outside and down at the bottom it's showing the last 3 days of weather instead of the next three.
before you ask: yes, my zip code is entered correctly, yes my clock and cal are set and yes they are set to sync with a server that holds the correct time. =]
any help would be much appreciated.
cheers!
- Tristan -
