Windows 7 Hama Bluetooth adapter
Marios
Active Member
I have Hama USB Bluetooth Adapter model 00049218 and the driver is not installing. The icon of bluetooth dissappeared and bluetooth not working.
It seems like you are experiencing issues with installing the driver for your Hama USB Bluetooth Adapter model 00049218, which has resulted in the Bluetooth icon disappearing and Bluetooth not functioning properly on your system. Here are some steps you can try to troubleshoot and resolve this issue:
Troubleshooting Steps for Bluetooth Adapter Driver Installation Issue:​
  • Check Device Manager:
  • Press Windows + X and select "Device Manager" from the menu.
  • Look for any entries related to Bluetooth or the Hama Bluetooth adapter.
  • If you see any yellow exclamation marks or red crosses, it indicates an issue with the driver.
  • Uninstall and Reinstall Driver:
  • Right-click on the Bluetooth device...
  • Right-click on the Bluetooth device in Device Manager and select "Uninstall device."
  • Disconnect the Bluetooth adapter.
  • Restart your computer.
  • Reconnect the Bluetooth adapter and try reinstalling the driver.
  • Download the Latest Driver:
  • Visit the official Hama website or the manufacturer's website and download the latest driver for your specific model (00049218).
  • Install the driver following the manufacturer's instructions.
  • Update Windows:
  • Make sure your Windows system is up to date by checking for any pending updates.
  • Sometimes, Windows updates include driver updates that could resolve compatibility issues.
  • Bluetooth Troubleshooter:
  • Run the built-in Windows Bluetooth Troubleshooter to diagnose and fix common Bluetooth issues.
  • Press Windows + I to open Settings, then go to "Update & Security" > "Troubleshoot" > "Bluetooth" and run the troubleshooter.
  • Check Antivirus/Firewall:
  • Temporary disable any antivirus or firewall software that may be blocking the Bluetooth connection or driver installation.
  • Try Different USB Port:
  • Plug the Bluetooth adapter into another USB port on your computer to rule out any hardware issues with the current port.
  • System Restore:
  • If the issue started recently, you can try performing a System Restore to revert your system to a previous working state.
  • Contact Support:
  • If none of the above steps resolve the issue, contact Hama customer support for further assistance.
    Following these steps should help in diagnosing and resolving the driver installation issue with your Hama USB Bluetooth Adapter. Let me know if you need any further assistance!​
