lsusuperstar
- Joined
- Jan 29, 2011
- Messages
- 6
- Thread Author
- #1
So here is the story:
I had Win XP on my desktop and wanted to upgrade to a copy of Win 7 that I was able to get through school. I got an external hard drive and backed up all my important data. I burned a Win 7 disc from an iso. When I tried to run it from Win XP, I got an error that there wasn't enough room to make a new partition on my hard drive (it was just a single partition made when XP was installed). So I tried to restart and boot from the disc, but after I told it to boot from cd/dvd drive, the computer would just sit there with a black screen. Then I made a huge mistake and deleted the existing partition from inside administrative tools in the control panel. Now I get a BSOD when it tries to load Win XP and just sits there with a black screen when it tries to boot from the Win 7 install disc. I hope I was clear enough about my troubles. Any help would be greatly appreciated. Thanks.
Nibiru2012
- Joined
- Dec 16, 2009
- Messages
- 465
So I assume you set your DVD drive as the "First Boot Device" in the BIOS?
Sometimes a bad burn can occur with ISO images, especially when doing an OS ISO burn.
That seems to be what it is to me, as I have had clients and friends have the same thing occur.
What speed did you burn the ISO image at? I tell most folks to burn no faster than 8X, I myself burn at 4X for ISO image install burns.
Use ImgBurn, it's free and has a "Verify" feature which will check the burned disc against the ISO image to verify a good burn.
lsusuperstar
- Joined
- Jan 29, 2011
- Messages
- 6
- Thread Author
- #3
Nibiru2012
- Joined
- Dec 16, 2009
- Messages
- 465
lsusuperstar
- Joined
- Jan 29, 2011
- Messages
- 6
- Thread Author
- #5
Nibiru2012
- Joined
- Dec 16, 2009
- Messages
- 465
Similar threads
- Replies
- 2
- Views
- 2K
- Replies
- 1
- Views
- 2K
- Replies
- 41
- Views
- 5K
- Replies
- 10
- Views
- 11K
- Solved
- Replies
- 7
- Views
- 2K
