OneDrive issues since Sept. Patch Tuesday
brkkab
Honorable Member
Has anyone else been having a issue with OneDrive since installing update KB3081455 on September 8, 2015. Ever since this update OneDrive say's it can't find my OneDrive folder's and I have to relog into OneDrive every time I restart or turn on my pc. Extremely annoying, especially as my OneDrive folder is whereever Windows 10 Pro x64 keep's it.
BIGBEARJEDI
Fantastic Member
Sorry, haven't seen it. But, I don't use OneDrive all that much except for testing. There are several recent bugs reported in the last couple of weeks on Win10, as you can read here on our Win10 forum, but this is not one of them. I'll check with my colleagues and see if anyone else has run into it and if there is a solution or not.
Cheers!
<<<BIGBEARJEDI>>>
brkkab
Honorable Member
I don't really use it either. It's just annoying. The only thing I use it for is settings Windows saves, my drivers and paid software.
ussnorway
Windows Forum Team
Not onedrive as such but Microsoft is working on their email server problems... is your Microsoft id an old @hotmail perhaps?
brkkab
Honorable Member
It sure is a old Hotmail account.
ussnorway
Windows Forum Team
So is mine...(its up to you but) as a work around I recommend you disable the auto-boot. This doesn't remove the program but just stops it booting until you want it.
[windows key] + [x] the press [t] and go to the start up tab
brkkab
Honorable Member
#7
*SOLVED*Will do ussnorway. Thanks
