Windows 10 Reg. Battery %
Naresh Koppala
I am using Windows 10 (64bit version)..
In recent days I observed that when battery percentage is reached to 40%, my laptop is shut down automatically (suddenly) even without any warning..
Is this a problem with software or with battery?
How can i fix it..
Any suggestions...
Thank you..
You'll want to look at 'Low/Critical Battery Level' and 'Low/Critical Battery Action' You probably have either the % set to high or you have a shutdown action on Low vs Critical.
An image from 'Reg. Battery %'. Screenshots show how to access and edit advanced power and battery settings in Windows Control Panel.
Neemobeer
Windows Forum Team
