- Thread Author
- #1
So a couple of weeks ago I built a new desktop for personal purposes. Originally I loaded XP on the system and it ran fine with no problems for the first week, then after getting a copy on Win7 Ultimate I upgraded the system and all seemed fine. Then I would get the BSOD at really random times. I was not able to narrow down specific processes or tasks that were being performed to really narrow down why it was being caused. I unplugged all USB peripherals but still got it and again at random times. Sometimes I could have a 2 day uptime and then at one point I got it 3 times in 20mins. So I blew the system away did a fresh install, started applying some updates, (I do know the that a .NET 4 update got fffd due to 1 BSOD, and did another fresh install). FED on/off, I tried a bunch of combinations to try to figure out where the error was originating from. Anyway here I am now, day and half in, finally got my system up and running with my desired progs and services and randomly I get the BSOD again.... At this point I've trouble shot everything I could, switching between onboard and PCI-E video cards, BIOS settings @ fail-safe, optimal, and custom where I just tweak my own parts, but after this last BSOD, I just can't take it anymore. Also to note after the BSOD that prompted me to consult the forum, there was not a dump file created. but since the last dump file, there have been no additional hardware added or removed from the system. Any software added was non hardware driver dependent, specifically JDK7 with NetBeans and Eclipse.
Any help anyone can give is much appreciated. I'm wondering if maybe I have a defective DIMM or something, but I pulled them out and reseated them just to be sure also. Anyways, I've attached all the necessary files a more advanced dump analyst would need to try to tell me where the problem might lie. One piece of info that may not be in there in that I have a MSI 760GM-P23 (FX) mainboard. Everything else should be found in my zip file. Thanks for your help in advance and God bless you if you can help me.
Bests
Bests
