Windows 7 something really strange and i need help
weker
May not be improtant that you know about crysis.
Okay I am not a tech wiz, but im learning slowly I was busy trying to mod crysis by merging level files.
When out of the blue my block thing (that bar that goes at the top i dont know what its called but it looks cool and pop up when i move my cursor up) is gone and also basicaly all my icons for programs on the taskbar, shortcuts on desktop and all programs have been swaped with a pieces of paper and a picture of crysis.
Why did this happen and how can i solve it???
also to add when i clicked on any of them it would try launch the game even though when i inspected the link there was no hint other then the icon that suggested it had any connection with crysis.
i have now uninstalled the game and the problem persist but also the picture of crysis on the paper is now gone and when i click on them the ask what program to use.
and another thin when i went onto my guest account there was no hint of any of these problems at all
As far as the icons, can you right click on one and set the default program back to want it needs to be?
Task Manager has a small footprint mode. I think you need to double click somewhere on the window to get it back to normal.
Thanks for your question, I did not know I could set the drag arrow on the top or bottom then click, rather than dragging, and get the window to go full vertical mode.
2010-04-10 20:04:03, Info CBS Scavenge: Begin CSI Store
2010-04-10 20:04:03, Info CSI 0000000a Performing 1 operations; 1 are not lock/unlock and follow:
Scavenge (8): flags: 00000017
2010-04-10 20:04:03, Info CSI 0000000b Store coherency cookie matches last scavenge cookie, skipping scavenge.
2010-04-10 20:04:03, Info CSI 0000000c ICSITransaction::Commit calling IStorePendingTransaction::Apply - coldpatching=FALSE applyflags=7
2010-04-10 20:04:03, Info CSI 0000000d Creating NT transaction (seq 2), objectname [6]"(null)"
2010-04-10 20:04:03, Info CSI 0000000e Created NT transaction (seq 2) result 0x00000000, handle @0x228
2010-04-10 20:04:03, Info CSI 0000000f@2010/4/10:19:04:03.875 CSI perf trace:
CSIPERF:TXCOMMIT;39900
2010-04-10 20:04:03, Info CBS Scavenge: Completed, disposition: 0X1
2010-04-10 20:04:03, Info CSI 00000010@2010/4/10:19:04:03.876 CSI Transaction @0x1615b0 destroyed
2010-04-10 20:04:03, Info CBS Reboot mark refs: 0
2010-04-10 20:04:03, Info CBS Idle processing thread terminated normally
2010-04-10 20:04:03, Info CBS Ending the TrustedInstaller main loop.
2010-04-10 20:04:03, Info CBS Starting TrustedInstaller finalization.
2010-04-10 20:04:03, Info CBS Ending TrustedInstaller finalization.
2010-04-10 23:29:41, Info CBS Starting TrustedInstaller initialization.
2010-04-10 23:29:41, Info CBS Loaded Servicing Stack v6.1.7600.16385 with Core: C:\Windows\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7600.16385_none_655452efe0fb810b\cbscore.dll
2010-04-10 23:29:41, Info CSI 00000001@2010/4/10:22:29:41.361 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7fef380e9a1 @0x7fef62e8755 @0x7fef62b2ac7 @0xff2ee94c @0xff2ed769 @0xff2edaff)
2010-04-10 23:29:41, Info CSI 00000002@2010/4/10:22:29:41.361 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7fef380e9a1 @0x7fef633500e @0x7fef6301504 @0x7fef62b2b9d @0xff2ee94c @0xff2ed769)
2010-04-10 23:29:41, Info CSI 00000003@2010/4/10:22:29:41.361 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7fef380e9a1 @0x7fefae18728 @0x7fefae18856 @0xff2ee444 @0xff2ed7ae @0xff2edaff)
2010-04-10 23:29:41, Info CBS Ending TrustedInstaller initialization.
2010-04-10 23:29:41, Info CBS Starting the TrustedInstaller main loop.
2010-04-10 23:29:41, Info CBS TrustedInstaller service starts successfully.
2010-04-10 23:29:41, Info CBS SQM: Initializing online with Windows opt-in: False
2010-04-10 23:29:41, Info CBS SQM: Cleaning up report files older than 10 days.
2010-04-10 23:29:41, Info CBS SQM: Requesting upload of all unsent reports.
2010-04-10 23:29:41, Info CBS SQM: Failed to start upload with file pattern: C:\Windows\servicing\sqm\*_std.sqm, flags: 0x2 [HRESULT = 0x80004005 - E_FAIL]
2010-04-10 23:29:41, Info CBS SQM: Failed to start standard sample upload. [HRESULT = 0x80004005 - E_FAIL]
2010-04-10 23:29:41, Info CBS SQM: Queued 0 file(s) for upload with pattern: C:\Windows\servicing\sqm\*_all.sqm, flags: 0x6
2010-04-10 23:29:41, Info CBS SQM: Warning: Failed to upload all unsent reports. [HRESULT = 0x80004005 - E_FAIL]
2010-04-10 23:29:41, Info CBS No startup processing required, TrustedInstaller service was not set as autostart, or else a reboot is still pending.
2010-04-10 23:29:41, Info CBS NonStart: Checking to ensure startup processing was not required.
2010-04-10 23:29:41, Info CSI 00000004 IAdvancedInstallerAwareStore_ResolvePendingTransactions (call 1) (flags = 00000004, progress = NULL, phase = 0, pdwDisposition = @0xcafdb0
2010-04-10 23:29:41, Info CSI 00000005 Creating NT transaction (seq 1), objectname [6]"(null)"
2010-04-10 23:29:41, Info CSI 00000006 Created NT transaction (seq 1) result 0x00000000, handle @0x1f8
2010-04-10 23:29:41, Info CSI 00000007@2010/4/10:22:29:41.361 CSI perf trace:
CSIPERF:TXCOMMIT;807
2010-04-10 23:29:41, Info CBS NonStart: Success, startup processing not required as expected.
2010-04-10 23:29:41, Info CBS Startup processing thread terminated normally
2010-04-10 23:29:41, Info CSI 00000008 CSI Store 3763248 (0x0000000000396c30) initialized
2010-04-10 23:29:41, Info CBS Session: 30071037_1342275192 initialized by client WindowsUpdateAgent.
2010-04-10 23:29:43, Info CBS Trusted Installer signaled for shutdown, going to exit.
2010-04-10 23:29:43, Info CBS Ending the TrustedInstaller main loop.
2010-04-10 23:29:43, Info CBS Starting TrustedInstaller finalization.
2010-04-10 23:29:43, Info CBS Ending TrustedInstaller finalization.
2010-04-10 23:36:08, Info CBS Starting TrustedInstaller initialization.
2010-04-10 23:36:08, Info CBS Loaded Servicing Stack v6.1.7600.16385 with Core: C:\Windows\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7600.16385_none_655452efe0fb810b\cbscore.dll
2010-04-10 23:36:08, Info CSI 00000001@2010/4/10:22:36:08.820 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7fee977e9a1 @0x7fee9aa8755 @0x7fee9a72ac7 @0xffb0e94c @0xffb0d769 @0xffb0daff)
2010-04-10 23:36:08, Info CSI 00000002@2010/4/10:22:36:08.820 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7fee977e9a1 @0x7fee9af500e @0x7fee9ac1504 @0x7fee9a72b9d @0xffb0e94c @0xffb0d769)
2010-04-10 23:36:08, Info CSI 00000003@2010/4/10:22:36:08.820 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7fee977e9a1 @0x7fef0a88728 @0x7fef0a88856 @0xffb0e444 @0xffb0d7ae @0xffb0daff)
2010-04-10 23:36:08, Info CBS Ending TrustedInstaller initialization.
2010-04-10 23:36:08, Info CBS Starting the TrustedInstaller main loop.
2010-04-10 23:36:08, Info CBS TrustedInstaller service starts successfully.
2010-04-10 23:36:08, Info CBS SQM: Initializing online with Windows opt-in: False
2010-04-10 23:36:08, Info CBS SQM: Cleaning up report files older than 10 days.
2010-04-10 23:36:08, Info CBS SQM: Requesting upload of all unsent reports.
2010-04-10 23:36:08, Info CBS SQM: Failed to start upload with file pattern: C:\Windows\servicing\sqm\*_std.sqm, flags: 0x2 [HRESULT = 0x80004005 - E_FAIL]
2010-04-10 23:36:08, Info CBS SQM: Failed to start standard sample upload. [HRESULT = 0x80004005 - E_FAIL]
2010-04-10 23:36:08, Info CBS SQM: Queued 0 file(s) for upload with pattern: C:\Windows\servicing\sqm\*_all.sqm, flags: 0x6
2010-04-10 23:36:08, Info CBS SQM: Warning: Failed to upload all unsent reports. [HRESULT = 0x80004005 - E_FAIL]
2010-04-10 23:36:08, Info CBS No startup processing required, TrustedInstaller service was not set as autostart, or else a reboot is still pending.
2010-04-10 23:36:08, Info CBS NonStart: Checking to ensure startup processing was not required.
2010-04-10 23:36:08, Info CSI 00000004 IAdvancedInstallerAwareStore_ResolvePendingTransactions (call 1) (flags = 00000004, progress = NULL, phase = 0, pdwDisposition = @0xbcfb50
2010-04-10 23:36:08, Info CSI 00000005 Creating NT transaction (seq 1), objectname [6]"(null)"
2010-04-10 23:36:08, Info CSI 00000006 Created NT transaction (seq 1) result 0x00000000, handle @0x1f8
2010-04-10 23:36:08, Info CSI 00000007@2010/4/10:22:36:08.867 CSI perf trace:
CSIPERF:TXCOMMIT;690
I do not see anything on this readout that looks like you ran a System File Check...
Are you sure you ran it from an Administrative command prompt? When you ran it, did it go from 0% to 100% verifying integrity and took several minutes?
reinstalling did not work i will try the scan again and this time i will copy more
i rescaned now and it says its fine what is this problem caused by
this is mental
could it be something i cilked while i was mod
or something could have happend if i was in files
god dam this is a evil mystery
What do you mean reinstalling did not work? Are you saying you did a repair install and it did not fix your problems?
How about attaching a snipping tool picture of your Disk Management Window.
To be truthful, I am running out of ideas...unless you have a bad drive or setup corrupting your system....
i put the windows 7 disk in and ran it, clicked upgrade and just let it run
how do i get "snipping tool picture of your Disk Management Window"
one thing i have picked up on other then my guest account is still fine is the fact that i can open file fine in the documents and computer but it is only the things in the taskbar and desktop shotcuts, could this be a problem with the computer trying to navigate to the correct file (i have no idea how much of that could be possible)
i will contact dell and see if they can enlighten me
since talking to dell they seem reluctant to tell me but they think it is a software problem so my warrent does not cover it so i would have to fork out 59 pound to fix and if the problem occurs again
however antechs say they will have a look for around 30 pounds and they think it may be due to the tojan virus they i saw
meanwhile my friend thinks that the problem lies in my computer documents some where, eg some miss click or file cahnge or something to cause this, he dismisses the trojan could cause the problem due to something like they dont do that.
Weker, have you tried pressing F8 whilst booting and then choosing 'last good known config'?
