Windows 7 Standard VGA Graphics Adapter
quadcake
Hi guys. I need help.
I upgraded my Windows XP to windows 7 and now my video driver is screwed up.
It was a nVidia driver, I believe. I used to play games on my computer, but now I can't since my video driver is messed up. Also, my aero is disabled.
I remember it being a GeForce4 MX 420 (or 440) with AGP8X.
That is a windows xp driver, and I cannot download it since it's not compatible with my hardware. I tried scanning for drivers that can match up with my computer, but it's not compatible with the hardware either.
Thanks.
Oops, my bad, the download I gave you was the standard vga. The nvidia one shows the same thing but it's compatible with my hardware.
Just letting you know. I'll try getting a update right now.
Oh and I have code 43 on my driver, so if you can help me out with that, it would be great. I'm sure that's the one last step I need to fix to get my driver working :)
Ok I have it on good authority that this driver will work if 'manually installed'
WinXP/2k 32-bit - (81.85)
If it doesn't work then your could continue the search but your prospects do not look good. Sorry bud.
Code 43: Windows has stopped this device because it has reported problems
Device Manager displays the following message in the Device Properties...
Device Manager displays the following message in the Device Properties dialog box, on the General tab, in the Device Status text box:
Windows has stopped this device because it has reported problems. (Code 43)
Diagnosis
A device driver notified the operating system that the device failed.
Ref: http://technet.microsoft.com/en-us/library/cc725873(WS.10).aspx
Yes! Yes! Yes! Thank you! It works!!!!!
After a month it finally works! Thanks so much.
Much (x100000000000) respect.
Thanks! :D
Fantastic!!!
I really thought you weren't going to see a solution with this so it's great that all has worked out.
Make sure you hang on to a copy of that driver! :)
Please do visit again and enjoy the other sections of our forum.
All the best
(Ross)
Ya.me too. upgrading from Windows XP to windows 7 and the oso using standard VGA graphic adapter.
i can't find the setup driver for tis adapter. where can i find it?
Besides that, my speacker can't function too. it show did not install any driver for the sound device.
i using dell speaker, but i dunno the name of it. can u tell me where to find the driver for it? or may be restore from the window.old file?
thank you.
Hi, i had the same problem with the same video card. I installed not this
driver, because i had a problem with downloading it, but this one - WinXP/2k 32-bit - (84.21) it is a bit later version.
I can see my video card in device manager now, but sometimes a blue screen appears and this error - 0x00000050: PAGE_FAULT_IN_NONPAGED_AREA. Please help me to fix this problem :)
