darthmars1
ive had the RC for awhile now (so far so good on that part) and i decided to re-install one of my favorite games star wars: knights of the old republic, i fully patched it and everything but when i tried to play it would go to a black screen then it would say "this programme is not responding" minimize then close... so i tried run as administrator... that failed.. compatibility... that also failed...
my stats are as followed
Manufacturer:none(it was custom made)
Processor:AMD Sempron(tm) Processor 3000+, ~1.6(has been recorded to go to 3.0)GHz
Memory:1 gig
Hard Drive:160 GB
Video Card:NVIDIA GeForce 6150SE nForce 430
Monitor:Generic PnP Monitor
Sound Card:Speakers (High Definition Audio Device)
Speakers/Headphones:3 words... digital surround sound
Keyboard:Standard PS/2 Keyboard
Mouse:Logitech USB Wheel Mouse
Mouse Surface:something.... :)
Motherboard:ASUS M2N-MX SE SERIES
Computer Case:black piece of leet crap
ive never had problems with the game before and yes before you say it i fully updated my graphiques card >_>
if someone has a fix plz do tell this is one of my fav games :'(
win 7 and Kotor have issues
Kotor and win 7 have issues. i would attempt to find the setup file for kotor and run it as an administrator first off. then go and download directx 9.0c as directx 11 that comes with win 7 is not backwards compatible. that graphics chipset is fine to run kotor on as it's newer than the recommended chipset. that's how i got it work on my other win 7 pc. couldnt get kotor 2 to work but there are a few work arounds online if you google them. good luck!
well if i could to work with the update and find away around the first error. I have it set to run as admin and in capability of windows xp server-pack 2
Reading through a Star Wars forum I came across a fix for vista. It might work for win 7 too but if it doesn't work check the forum for other possible solutions:
I have tried this forum already that's y I when to windows for help
Found by googling:
http://www.toptiertactics.com/17609/#axzz2mM77PfP3
Good luck!
