eXtremeDevil
Hi, the last week I'm been suffering freezes and reboots. I had one or two BSOD but that doesn't seem to be the main problem, and I have no dumps of them.
I have recently changed from a HDD to a SSD, I have applied a theme on my Windows 10, and I have updated to Fall Creators update. I cloned the HDD block by block to the new SSD, so no installation or anything was performed, just a plain old replacement.
I don't know where the problem may be but I'm getting a little worried now.
I'm also using nVidia 3D vision for the first time.
Also, I've put my old HDD as B:\ drive, and I guess it's not related but, sometimes when I boot my pc Windows Firewall asks me to allow a program I gave access before, only now the path to the binary looks like B:0\blah instead of C:\blah.
I attach the watchdog dump.
Thanks in advance
BugCheck D1, {ffffd5803151b000, 2, 0, fffff80049022ddd}
*** WARNING: Unable to verify timestamp for bwcW10x64.sys
*** ERROR: Module load completed but symbols could not be loaded for bwcW10x64.sys
Probably caused by : bwcW10x64.sys ( bwcW10x64+e114 )
Followup:     MachineOwner
eXtremeDevil
I did it a month ago or so because of a problem I had with a game resolution, so I guess that's enough, right?
Hmm well like I said I use it everytime but especially if you have had recent gpu issues. I'd do it anyway just to be on the safe side.
eXtremeDevil
I was going to use DDU when I realised that I actually use two GPUs, Intel and nVidia, one monitor each. I deleted both drivers/profiles with DDU and now I'm using just nVidia. Let's see if that solves something.
Also, I have deleted MSI Gaming APP, because sometimes the app makes my desktop icons to have some flicker, so it may be causing some troubles with the theme, who knows.
Let's see how it goes this week.
Sounds promising and those MSI apps especially the overclocking ones can cause bsod's so it's worth removing as a test.
Hope all goes well this week.
eXtremeDevil
Well, that app is handy to me, and in any case BSODs are not the case here, but anyway, let's see how it goes :)
eXtremeDevil
Seems like there's been no problems this week, not a single 'black screen' issue this time!! I guess it is misteriously resolved now. This weekend I will install again MSI Gaming App and see what happens.
eXtremeDevil
OK, I've been working all week with MSI Gaming App installed, and I had not a single problem!
A few words on this though. There's no doubt that these kind of apps tend to make more damage than good. I actually use this particular one to control a few things about my GPU. But, when reinstalling, I took a closer look and found a lot of 'garbage', we could say.
I turned off the four automatic tasks that comes with the app on the scheduled task manager, as I don't use the app for any in-game overlay or anything like that. Also, I found a 'driver' folder in the app's installation folder (C:\Program Files\MSI\Gaming APP by default). There, I found a uninstall.exe, so I ran it as I don't want any special driver on my system.
Also, I noticed a process that needs to be running for the app to work. This is 'muachost.exe' and it can be found on C:\Windows\SysWOW64 (it is installed with the app, is not a system file despite the path). I don't know why, but when changing my wallpaper, this exe would cause my desktop icons to start flickering. I replaced the exe with other one that does nothing but keeps running, so the app can run as well.
After those steps, now I have the app running fine and no further problems.
There's only two more things for me to try. One is plugging the second monitor on the Intel CPU and install its drivers. The other one is to install the drivers for the displays. Maybe one of the two are the cause of the black screen, or maybe that thing is already solved.
In any case, I have done step one already. Let's wait for another week and see what happens.
Thanks to all.
Much thanks for the informative update.
Your doing a fine job and we really appreciate you sharing. Hope things continue.. :)
Any news?
I just noticed you reading the thread earlier and wondered if an issue had returned?
eXtremeDevil
No, I just have the tab opened all the time so I can remember to post weekly hehe
eXtremeDevil
Sorry guys, I've been ill for a few days. I installed one monitor drivers last weeks and no errors by now. This weekend I will install the other monitor drivers and see how it goes. Or that driver is the cause, or the cause were resolved time ago xD
Cheers.
eXtremeDevil
Seems that, after all, no more errors ocurred. Either the full wipe of *both* video drivers did the trick, or maybe the way I'm now running the MSI Gaming APP is the solution. Those are the only steps I can think of that may have changed something. In any case, thanks to all for the support!
