EliasThorpe
I've been getting this error every startup. It's been happening for a while so I don't know what program is causing the problem, or I would have reinstalled it.
I looked through my startup programs on system config and it says the startup item is "sta", manufacturer is "Unknown", command is "rundll32 "jjysp.dll",,Run", and finally location is "HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Run"
I have no idea what it is or where it came from, but I'm pretty suspect of the process. I searched online for the .dll file but nothing came up. Should I disable it? Is that all I need to do to get rid of it, or is there something more that I should do?
It's almost certainly a leftover from and antivirus cleanup. You should use msconfig or autoruns (much more powerful startup manager) free from MS:
Autoruns for Windows
to stop it running, delete it from startup reboot then do a final search and make sure the dll has been deleted (it probably was by your AV).
EliasThorpe
I disabled it and it seems like everything is working fine, no problems on startup or anything.
patcooke
Microsoft MVP
Microsoft MVP
