Windows 8 Bluetooth Not Working!
Husnain Hussain
so i have a hp pavilion with bluetooth biult in but when i add a device it says searching and never finds the device. i have tried to update the drivers but they are the latest , and tried services.msc. BEEN TRYING FOR DAYS PLEASE HELP ASAP!
  • Verify you have blue tooth enabled on both devices
  • Verify that the device you are trying to discover is set to be visible to other devices and the pairing pin is set.
  • Then you should be able to discover it from the computer
Husnain Hussain
btw i was trying to connect an galaxy s3 and wireless controller
Neemobeer
Windows Forum Team
