Windows 7 Broadcom BCM57781 onboard LAN keeps dropping out and then coming back
RoddyJones
Hi
I have the above brand of LAN on a ASROCK Z68 Extreme 4 Mobo.
Router: Netgear DG834G
The whole computer is about 7 months old and as per another recent thread it has a fresh install of Windows 7 64bit Pro. However since the reinstall an issue that also existed before continues to annoy me.
Namely, the internet at times drops in and out over a period of hours and then just works.
CAT 5 Cable has been replaced and tested in another machine and is fine.
There is another laptop, older Dell with Vista on the network (wired) that has no issues, everytime my PC drops I check it and 9 times out of 10 its still working.
I just upgraded the latest driver from here
Broadcom.com - Ethernet NIC NetLink Driver Downloads
Whilst I prefer Firefox, i normally solve the issue by opening Explorer and using its Diagnose tool. Quite often it will say ' The default gateway is not available'
One bit of info, it also continously says I am on a ' Unidentified network' and ' Public Network' despite it being a simple home wired (NO wifi i switched it off) LAN. How do you change it back to HOME network? sometimes the Public Network is in blue and you can click it and tell it yet again to be HOME but other times its not in blue or clickable to change.
Surely there is something we can do other than put a separate LAN card in a slot.
I do not think its the DSL, as the entire time I have had another laptop connected by wifi and the last 2 weeks wired, to the same Netgear DG843G router. Every time my machine drops I test the laptop and its fine.
There is no home alarm here.
Hi there
as a report, since uninstalling my VMware adaptors from Device Manager (run in my Win 7) network up time has been alot better. I am in two minds now if I even need to keep my VMware virtual copy of XP at all, I suppose i can keep it but without the ability to run internet in it due to the adaptors being uninstalled.
Any internet I need I can swap in a second back to the Win 7 Pro machine anyway.
Have you given any thought to the DSL causing your problem rather than your system? Is there a way you could keep another computer plugged into the router so as to keep the network active, just for testing?
Also, I wanted to bring up the fact that some older home alarm systems can cause problems with DSL. If you have one, you might want to call the provider to check.
And the phone line type of DSL can have noise problems in some installs....
Hi there
Hi there
It appears my problems are over as far as network drops
Culprit is
VMWARE
disabling the Virtual internet adaptors in Device Manager in Windows 7 was a start.
After my Canon scanner broke which was the only reason I installed VMware I decided there is no reason at all for the software and uninstalled the lot.
Everything seems to be fine now. Any future drop outs will be due to something else.
Also, an earlier thread on this forum I had regarding programs not working after returning from sleep, whereby only a restart of the machine would fix the problem. -- this has gone too!
So alot to blame on VMware..
