* Bugcheck Analysis *
BugCheck 24, {1904aa, fffffa600cc37678, fffffa600cc37050, fffffa60014e7309}
Probably caused by : Ntfs.sys ( Ntfs!NtfsExpandHashTable+79 )
Followup: MachineOwner
this is your most common dump file out of those sent. The above and other dump files suggest you may have issues with either the Hard drive or RAM.
Please run a chkdsk:
I see that your machine is a NV80Vm Notebook and as such drivers and updates are supplied by the manufacturer. I also notice you have several Bios updates available:
Check your RAM
If after making the above changes you still get the bsod then you need to test your RAM.
Windows does have it's own memory testing app but it can often miss errors and the best app for the job is Memtest86. The latest version of which can be found here:
http://www.memtest.org/
To run Memtest86 you need to either burn a copy of it to disk or use a USB stick. If you look down the page you'll eventually find the latest version and it's associated downloads. If your burning to disk choose the pre-compiled iso zip. If your using a USB method then the corresponding download is the auto installer for a USB stick.
Once you have Memtest86 on the media you selected you'll then need to enter your bios and change the boot order so that the machine will boot from either the disk or stick you have Memtest86 on.
Try and run the test overnight if possible unless it becomes clear that there is a issue. If there is a problem with the RAM you'll see the errors pop up in red so you can't miss them.
Post any new dump files.
