wrxrecon153
i just built this machine and it worked great for a few days and now it keeps giving me a BSOD but nothing has changed hardware or software
it works great with no problems as long as i am using it i can be on it all day with no problems but s soon as i leave it idle for awhile it crashes sometimes its only idle for a few min. other times its idle for a few hours
i have attached my mini.dmp files
any help would be much appreciated
specs:
Gigabyte X58A-UD3R rev.2
Intel core I7-950
ocz DDR3 1066 12gb (3 sticks of 4gb)
Gigabyte GTS 450 1gb GDDR5
corsair 850 watt power supply
micro center 64 gb SSD for os
hitachi 2TB hdd
2x western digital 1TB hdd
Stop 0x124:
BugCheck 124, {0, fffffa800ac6a028, b6000000, 200001}
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred
PROCESS_NAME: AEI.exe <-- Webroot Spy Sweeper
Probably caused by : hardware
CURRENT_IRQL: f
FAILURE_BUCKET_ID: X64_0x124_GenuineIntel_PROCESSOR_MAE
1. No overclocking
2. No overheating
3. All hardware clocks must be set right in strict accordance with the manufacturers'
4. Bios upgrade might fix
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\012811-19562-01.dmp]
Mini Kernel Dump File: Only registers and stack...
Stop 0x124:
CURRENT_IRQL: f
1. No overclocking
2. No overheating
Crash Dumps:
Executable search path is:
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`0304f000 PsLoadedModuleList = 0xfffff800`0328ce50
Debug session time: Fri Jan 28 01:31:25.170 2011 (UTC - 5:00)
System Uptime: 0 days 0:35:16.247
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 124, {0, fffffa800ac1e028, b6000000, 200001}
Followup: MachineOwner
2: kd> !analyze -v
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa800ac1e028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000b6000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000200001, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR:  0x124_GenuineIntel
CUSTOMER_CRASH_COUNT:  1
CURRENT_IRQL:  f
STACK_TEXT:
fffff880`02f6cb58 fffff800`03018903 : 00000000`00000124 00000000`00000000 fffffa80`0ac1e028 00000000`b6000000 : nt!KeBugCheckEx
fffff880`02f6cb60 fffff800`031d5593 : 00000000`00000001 fffffa80`0ab58950 00000000`00000000 fffffa80`0ab589a0 : hal!HalBugCheckSystem+0x1e3
fffff880`02f6cba0 fffff800`030185c8 : 00000000`00000728 fffffa80`0ab58950 fffff880`02f6cf30 fffff880`02f6cf00 : nt!WheaReportHwError+0x263
fffff880`02f6cc00 fffff800`03017f1a : fffffa80`0ab58950 fffff880`02f6cf30 fffffa80`0ab58950 00000000`00000000 : hal!HalpMcaReportError+0x4c
fffff880`02f6cd50 fffff800`03017dd5 : 00000000`00000008 00000000`00000001 fffff880`02f6cfb0 00000000`00000000 : hal!HalpMceHandler+0x9e
fffff880`02f6cd90 fffff800`0300be88 : 00000000`00000002 00000000`00002000 00000000`00000000 00000000`00000000 : hal!HalpMceHandlerWithRendezvous+0x55
fffff880`02f6cdc0 fffff800`030bdfec : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x40
fffff880`02f6cdf0 fffff800`030bde53 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x6c
fffff880`02f6cf30 fffff800`030b64e4 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x153
fffff880`06f59778 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!memmove+0xb4
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: hardware
IMAGE_NAME:  hardware
DEBUG_FLR_IMAGE_TIMESTAMP:  0
Loading Dump File [F:\a\Minidump\D M P\DMP\012811-31699-01.dmp]
Machine Name:
Kernel base = 0xfffff800`0305f000 PsLoadedModuleList = 0xfffff800`0329ce50
Debug session time: Fri Jan 28 15:52:40.212 2011 (UTC - 5:00)
System Uptime: 0 days 1:35:19.289
2: kd> !analyze -v
Arguments:
Arg2: fffffa800ac6a028, Address of the WHEA_ERROR_RECORD structure.
Debugging Details:
CURRENT_IRQL:  f
STACK_TEXT:
fffff880`02f6cb58 fffff800`03028903 : 00000000`00000124 00000000`00000000 fffffa80`0ac6a028 00000000`b6000000 : nt!KeBugCheckEx
fffff880`02f6cb60 fffff800`031e5593 : 00000000`00000001 fffffa80`0ac5d830 00000000`00000000 fffffa80`0ac5d880 : hal!HalBugCheckSystem+0x1e3
fffff880`02f6cba0 fffff800`030285c8 : 00000000`00000728 fffffa80`0ac5d830 fffff880`02f6cf30 fffff880`02f6cf00 : nt!WheaReportHwError+0x263
fffff880`02f6cc00 fffff800`03027f1a : fffffa80`0ac5d830 fffff880`02f6cf30 fffffa80`0ac5d830 00000000`00000000 : hal!HalpMcaReportError+0x4c
fffff880`02f6cd50 fffff800`03027dd5 : 00000000`00000008 00000000`00000001 fffff880`02f6cfb0 00000000`00000000 : hal!HalpMceHandler+0x9e
fffff880`02f6cd90 fffff800`0301be88 : 00000000`00000002 00000000`00002000 00000000`00000000 00000000`00000000 : hal!HalpMceHandlerWithRendezvous+0x55
fffff880`02f6cdc0 fffff800`030cdfec : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x40
fffff880`02f6cdf0 fffff800`030cde53 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x6c
fffff880`02f6cf30 fffff800`030c64e4 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x153
fffff880`08fe9778 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!memmove+0xb4
STACK_COMMAND:  kb
