John Lauhoff
- Joined
- Dec 2, 2011
- Messages
- 12
- Thread Author
- #1
[FONT=Segoe UI, Arial]On Sat 5/5/2012 1:34:24 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\050412-31715-01.dmp
This was probably caused by the following module: [FONT=Segoe UI, Arial]ntoskrnl.exe[/FONT] (nt+0x44A7E)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF80002E8EA7E, 0xFFFFF880009A99D8, 0xFFFFF880009A9230)
Error: [FONT=Segoe UI, Arial]SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M[/FONT]
file path: C:\Windows\system32\ntoskrnl.exe
product: [FONT=Segoe UI, Arial]Microsoft® Windows® Operating System[/FONT]
company: [FONT=Segoe UI, Arial]Microsoft Corporation[/FONT]
description: NT Kernel & System
Bug check description: This indicates that a system thread generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
[/FONT]
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: [FONT=Segoe UI, Arial]ntkrnlmp.exe[/FONT] (nt!KeBugCheckEx+0x0)
Bugcheck code: 0x7E (0xFFFFFFFFC0000005, 0xFFFFF80002E8EA7E, 0xFFFFF880009A99D8, 0xFFFFF880009A9230)
Error: [FONT=Segoe UI, Arial]SYSTEM_THREAD_EXCEPTION_NOT_HANDLED[/FONT]
Bug check description: This bug check indicates that a system thread generated an exception that the error handler did not catch.
[/FONT]
[FONT=Segoe UI, Arial]On Fri 5/4/2012 10:48:54 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\050412-48656-01.dmp
This was probably caused by the following module: [FONT=Segoe UI, Arial]ntoskrnl.exe[/FONT] (nt+0x7CC40)
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF800031851CA, 0xFFFFF8800A7D1F60, 0x0)
Error: [FONT=Segoe UI, Arial]SYSTEM_SERVICE_EXCEPTION[/FONT]
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
[/FONT]
[FONT=Segoe UI, Arial]On Fri 5/4/2012 5:04:45 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\050412-33072-01.dmp
Bugcheck code: 0xA (0x1, 0x2, 0x0, 0xFFFFF80002EE6B46)
Error: [FONT=Segoe UI, Arial]IRQL_NOT_LESS_OR_EQUAL[/FONT]
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
[/FONT]
[FONT=Segoe UI, Arial]On Fri 5/4/2012 3:07:27 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\050412-27300-01.dmp
Bugcheck code: 0x50 (0xFFFFFFFFFFFFFE9A, 0x8, 0xFFFFFFFFFFFFFE9A, 0x0)
Error: [FONT=Segoe UI, Arial]PAGE_FAULT_IN_NONPAGED_AREA[/FONT]
Bug check description: This indicates that invalid system memory has been referenced.
[/FONT]
[FONT=Segoe UI, Arial]On Thu 5/3/2012 10:21:31 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\050312-24320-01.dmp
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF800030042FE, 0xFFFFF8800A1BBAA0, 0x0)
[/FONT]
[FONT=Segoe UI, Arial]On Thu 5/3/2012 6:43:49 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\050312-23852-01.dmp
Bugcheck code: 0xC7 (0x4, 0xFFFFF80000000000, 0x1, 0xFFFFFFFF)
Error: [FONT=Segoe UI, Arial]TIMER_OR_DPC_INVALID[/FONT]
Bug check description: This is issued if a kernel timer or delayed procedure call (DPC) is found somewhere in memory where it is not permitted.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
[/FONT]
[FONT=Segoe UI, Arial]On Wed 5/2/2012 10:45:26 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\050212-34725-01.dmp
Bugcheck code: 0xD1 (0x0, 0x2, 0x0, 0xFFFFF880049EEAC7)
Error: [FONT=Segoe UI, Arial]DRIVER_IRQL_NOT_LESS_OR_EQUAL[/FONT]
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
[/FONT]
[FONT=Segoe UI, Arial]On Tue 5/1/2012 9:42:56 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\050112-34320-01.dmp
Bugcheck code: 0xFC (0xFFFFF88003E93AB8, 0x80000000B24E1963, 0xFFFFF88003E938B0, 0x2)
Error: [FONT=Segoe UI, Arial]ATTEMPTED_EXECUTE_OF_NOEXECUTE_MEMORY[/FONT]
Bug check description: This indicates that an attempt was made to execute non-executable memory.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules. There is a possibility this problem was caused by a virus or other malware.
[/FONT]
[FONT=Segoe UI, Arial]On Tue 5/1/2012 5:05:32 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\050112-34913-01.dmp
This was probably caused by the following module: [FONT=Segoe UI, Arial]ntoskrnl.exe[/FONT] (nt+0x70590)
Bugcheck code: 0x1E (0x0, 0x0, 0x0, 0x0)
Error: [FONT=Segoe UI, Arial]KMODE_EXCEPTION_NOT_HANDLED[/FONT]
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
[/FONT]
[FONT=Segoe UI, Arial]On Tue 5/1/2012 1:16:14 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\043012-28329-01.dmp
This was probably caused by the following module: [FONT=Segoe UI, Arial]ntoskrnl.exe[/FONT] (nt+0x705C0)
Bugcheck code: 0xA (0x0, 0x2, 0x1, 0xFFFFF80002EC33BC)
[/FONT]
[FONT=Segoe UI, Arial]On Tue 5/1/2012 12:12:38 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\043012-42759-01.dmp
Bugcheck code: 0xA (0x1E, 0x2, 0x1, 0xFFFFF80002CA50E0)
[/FONT]
[FONT=Segoe UI, Arial]On Mon 4/23/2012 10:55:25 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\042312-18408-01.dmp
Bugcheck code: 0x50 (0xFFFFFFFFFFFFFF8B, 0x1, 0xFFFFF80002CCF682, 0x0)
[/FONT]
[FONT=Segoe UI, Arial]On Sun 4/22/2012 12:54:16 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\042112-16801-01.dmp
Bugcheck code: 0xA (0x60910A342, 0x2, 0x1, 0xFFFFF80002C6E2BE)
[/FONT]
[FONT=Segoe UI, Arial]On Sun 4/22/2012 12:07:49 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\042112-17690-01.dmp
Bugcheck code: 0xA (0x48D8, 0x2, 0x0, 0xFFFFF80002D2F00E)
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
