Ninjacatman2009
Hi
Im just going to jump right in.
so i was editing the registry to try to fix all of my downloads going to my ssd instead of my hdd and now to cant download anything because it says path not specified and i cannot open certain programs (even the registry itself!) I cannot find anything on how to fix it!
PLEASE i need urgent help
thanks
I suspect you went here:
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer
If so,and you are in dire straits - no backup,etc, there are a couple of desperate measures you could try.
First, open "programs and features" in the Control Panel. Up on the left, click "Turn Windows Features on or off"
Scroll down and untick IE(x -Whatever version you have) Ok it and wait until the action is complete.Reboot and, if the OS does not start the sequence automatically, repeat the above procedure and tick the IE item. Ok again and reboot. See if this has sorted the problem.
If not, here is a reg file which will return IE registry to its original settings.First export your registry to a known location, so that you can...
Saltgrass
Are you sure you can't tell us what you did, or at least what instructions your were following when you made the changes? If we even knew what you were searching for when you found a website, it might help.
Since you mention path in your first post, perhaps you were making a change to the Environment Variables and messed up the path variable necessary for the system to find certain files.
