Windows 7 MSI problem (common fix wont work)
Jahren
hi guys,
I just installed windows 7 and was glad with most of its features!
The only problem I encountered (besides msn not going into the tray bar. now resolved)
is that windows installer of MSI packages will stay still and not run at all.
I get NO ERROR message.
I tried installing both iTunes x64 and Steam with the same behavior:
3 msexec running in task manager.
and one using 13% of cpu steadily without any change in memory.
I tried the registry fix and shutting down customer help program via gpedit + reboot
no good.
I need more help !
thanks!
Windows 7 x64 pro
EDIT:
Well guys, I just found out PANDA ANTI-VIRUS interferes with MSI installers!
For others having this problem, jsut de-activate auto-protection while you want to install the softwares.
Great you found the fix.
Here is a tip: Right click on the icons and select properties and tun them in Vista mode. They will go to the taskbar and not to hidden icons when minimized.
I wish there was a way to foce minimized programs to go to the hidden icon menu because I like to use a "close all" untility and it lets those programs keep running.
