Windows 7 Need help with BSODs
Yupensee
Hi all,
I have recently wiped both my drives and reinstalled windows taking care to get all necessary drivers and windows updates. Despite this I am still getting regular BSODs and I don't know what to do next to fix it. Please help.
I have attached the necessary file
BugCheck 3B, {c0000005, fffff88000f3a12b, fffff8800821ace0, 0}
Probably caused by : Wdf01000.sys ( Wdf01000!FxIoQueue::ProcessIdleComplete+eb )
Followup: MachineOwner
although most of the dump files you sent have the same bugcheck they each blame something different. This is...
So this happened... my first bluescreen in several days and then my sound temporarily backed up... what does it mean?!
BugCheck 3B, {c0000005, fffff96000119916, fffff880058805b0, 0}
Probably caused by : win32k.sys ( win32k!DEVLOCKBLTOBJ::~DEVLOCKBLTOBJ+56 )
Hey,
same old 3B and win32K.sys which might point at a possible hardware issue (memory). I know you were running on a single stick the last time we spoke as it were.. What's happening in that area? You may need to run memtest86 on the stick your using.
Gw64.sys Fri Jan 31 00:45:30 2014: This is malware and is related to this file:
http://www.herdprotect.com/wstlib64.sys-f5ff0c618ec52daf2723e3d1d0c3c5ddafa357ce.aspx
Download and run this app:
https://www.malwarebytes.org/
dtsoftbus01.sys Fri Feb 21 09:49:36 2014: Daemon Tools driver. Possible BSOD issues in Win7 please uninstall to test.
nx6000.sys Thu Dec 02 22:23:39 2010: Microsoft Lifecam driver updated in 2012:
Post any new dump files.
