steveysteve
- Joined
- Sep 13, 2011
- Messages
- 8
- Thread Author
- #1
I have a HTPC in my living room which since updating on the weekend now has no sound
I have found similar issues and posts on various forums from searching all afternoon Sunday but none with a solution (that works for me) other than a full Windows 7 reinstall.
I will explain the issue and what I have tried thus far:-
I have a PC running onboard realtek (ASRock ConRoe 745 DVI), which was working perfectly until Service [pack one update and two other updates this Sunday.
I unfortunately discovered for some reason the System Restore on this machine was set to off so that is not an option
The audio symbol bottom right says there is no audio device installed, however if you look in the device manager there is the correct Realtek device installed with no exclamation mark and it is reporting as working correctly.
If you right click on the red cross and click playback devices it takes you to the realtek device properties and it is set as default. (In fact if you unplug the speaker jack the PC advises you of this even though it says no audio device installed).
If you click on the red cross it launches the fault detection wizard and returns
"Audio Device is Disabled - Not Fixed"
I have tried uninstalling the device - scanning for changes - reinstall
Repeated the above but deleted the device drivers
Tried a SFC scan and a Chkdsk Scan (No errors)
Tried with the Microsoft default high definition audio drivers and the latest (and not latest) realtek drivers
Tried disabling in the BIOS uninstalling and reinstalling after re-enabling
Tried uninstalling the updates and repeating the above
Tried uninstalling the service pack and repeating the above
Finally unenabled the onboard card and installed a PCI soundblaster Audigy - Same problem
----Driving me mad----
