Rich73Kelly
Honorable Member
- Joined
- Jun 9, 2018
- Messages
- 59
- Thread Author
- #1
I browsed through the "Screensaver" posts before even joining the Forums and didn't find my particular issue.
I purchased a "used" HP Compaq 6200 with Windows 7 Pro installed. If other information about this machine is needed, I'll need steps on how to find it within the software as there is next to nothing on the case.
Now to my issue ... The Screensaver is set at 3 minutes ... Monitor off is set at 15 minutes. The Screensaver (Bubbles) will come on, I can hear the fans slow down and, almost that quick, the screensaver goes off and back to the desktop. There is nothing running in the background to cause this. I never experienced this on my old XP machine. Nor have I experienced it on this Win 10 machine, which was upgraded from 7.
Is there some way to remove and reinstall the screensaver software itself? Or, maybe some other kind of work around to get this screensaver working properly ???
