BootStrapped
Active Member
- Joined
- Sep 3, 2012
- Messages
- 8
- Thread Author
- #1
I got a new laptop recently (Windows 7 Home Premius SP1), and but there were several dozen updates that wouldn't install. After looking around online a bit, I eventually decided to go to msconfig and change the startup to only boot with windows programs, which solved that particular problem.
Now however I can't change it back to normal startup.
If I change it back and click apply, then when I go back in the setting is as before. If I just click "okay" and restart with new settings, then it does a selective startup anyway and reverts the settings.
Is there a way out of this?
