- Joined
- Oct 16, 2009
- Messages
- 15,155
- Thread Author
- #1
I have just spent a couple of hours trying to figure out how to get my clean install of 10130 to see my network shares. For some reason, even though I had connectivity, I could not see either my other Windows 10 computer or my NAS.
For this build, I set up a PIN to log on to the system. I had not logged on with a Password and I did not want to change the current configuration while troubleshooting.
It seems using a PIN to log on restricts access to your LAN. My other system could see the shares fine and I was trying to compare the two systems to see why one was working and the other was not.
Well, after much wasted time I decided to go ahead in log on using the Microsoft Account Password. No problem at all, now, seeing the other shares.
So, I suppose I could ask what are the differences between using a password log on and a PIN log on, since obviously, there are some? Microsoft seems to think a PIN is more secure. Are they talking about a 4 digit PIN or a longer one. Why does it seem using a PIN to log on make a difference in the network connectivity?
Thanks..
Thanks..
