Windows 11 packs a surprisingly capable set of built‑in troubleshooters that can automatically diagnose and repair many everyday PC problems—from flaky Wi‑Fi and silent speakers to frozen updates and stubborn printers. This guide distills what matters: where to find these tools, how to run them effectively, what each troubleshooter actually fixes, and what to try next if the automated repair doesn’t stick. You’ll also find advanced playbooks and safety notes so you can resolve issues faster without risking your data or custom settings.
Close-up of a blue tile-based Windows interface showing Internet, Audio, Update, and Network.Overview​
Windows troubleshooters are small, targeted repair utilities that scan for known problem patterns and apply safe system‑level changes. They don’t replace full diagnostics, but they do resolve a large share of common Windows 11 issues in minutes. The workflow is straightforward:
  • Open Settings and navigate to System > Troubleshoot.
  • Select Other troubleshooters.
  • Choose the tool that matches your symptom (for example, Internet Connections, Keyboard, Printer, or Windows Update).
  • Click Run, follow the on‑screen instructions, and apply recommended fixes.
If a troubleshooter can’t finish or finds nothing, you’re not out of options. A simple restart clears many transient glitches, and there are targeted next steps—manual updates, system file scans, or service resets—that often succeed where a first pass fails. The sections below walk through each of these paths with practical detail.
Background: How Windows 11 Troubleshooters Work​
Windows troubleshooters use rule‑based checks and remediation scripts created by Microsoft’s engineering teams. Each tool focuses on a subsystem or feature and executes a known‑good sequence of tests and repairs. Examples include:
  • Resetting a component to default settings.
  • Re‑registering services or DLLs related to a feature.
  • Flushing caches or queues (for example, Windows Update).
  • Reconfiguring device drivers and restarting dependent services.
Most changes are reversible and do not delete personal files or installed apps. Many troubleshooters also provide a post‑run report that lists detected issues and actions taken. You can rerun a troubleshooter after making changes or updates to verify the fix held.
Windows 11 also includes “recommended troubleshooters,” which can run automatically based on detected problems. You control this in Settings > System > Troubleshoot. Adjust the preference if you want Windows to apply fixes automatically, notify you first, or refrain from running them in the background.
Where to Find and How to Run Troubleshooters​
The core path in Settings​
  • Press Windows + I to open Settings.
  • Go to System > Troubleshoot.
  • Select Other troubleshooters to see the full list.
  • Click Run next to the troubleshooter that matches your problem.
  • Follow prompts, grant administrator permission if requested, and apply the suggested repairs.
Tip: If you don’t see the exact symptom, pick the closest subsystem. For instance, if you can’t get online, “Internet Connections” and “Network Adapter” are both relevant—run both.
The Get Help app and search​
Some modern troubleshooters surface via the built‑in Get Help app. Press Windows + S and type a plain‑language query like “Fix Wi‑Fi,” “Audio not working,” or “Windows Update error,” then open the suggested troubleshooter. You’ll get a guided flow that maps to the same underlying fixes but with more context and tips.
What Each Windows 11 Troubleshooter Covers​
Below is a practical, plain‑English tour of the most useful troubleshooters, what they attempt to fix, and how to get the best results from each.
Internet Connections​
Use this when web pages won’t load, apps can’t reach the internet, or you see “No internet.”
What it does:
  • Checks for disabled adapters, invalid IP/DNS settings, and captive portals.
  • Resets the network stack in targeted ways and restarts related services.
  • Verifies default gateway, DNS resolution, and proxy configuration.
Pro tips:
  • If you’re on Wi‑Fi, run “Network Adapter” next, selecting your wireless card when prompted.
  • For captive portals (hotel or café Wi‑Fi), open a plain http site (not https) to trigger the sign‑in page after the fix.
Network Adapter​
Use this when a specific adapter shows “Not connected,” you have slow transfers on LAN, or there’s no IPv4/IPv6.
What it does:
  • Enables disabled NICs and power‑managed devices.
  • Resets adapter bindings and clears corrupted profiles.
  • Repairs Winsock and TCP/IP issues related to that adapter.
Pro tips:
  • After the troubleshooter, toggle Airplane mode off/on and reconnect to your SSID.
  • If you’ve recently installed a new VPN client, temporarily disable it and rerun the tool.
Playing Audio​
Use this when there’s no sound, volume is low or muffled, or apps play to the wrong device.
What it does:
  • Switches the default playback device, re‑enables disabled outputs, and adjusts sample rates.
  • Restarts audio services and repairs common driver configurations.
  • Checks exclusive mode conflicts and enhancements that can mute or distort audio.
Pro tips:
  • Right‑click the volume icon > Sound settings > Choose where to play sound; confirm the output device the tool selected.
  • If you use USB or Bluetooth audio, unplug and reconnect (or remove and re‑pair) after running the tool.
Recording Audio​
Use this for microphone not detected, low input level, or apps not receiving mic input.
What it does:
  • Sets default input device, re‑enables disabled mics, resets input levels, and restarts services.
  • Checks privacy permissions for microphone access.
Pro tips:
  • Open Settings > Privacy & security > Microphone to make sure desktop and Store apps are allowed to use your mic.
Bluetooth​
Use this for pairing failures, intermittent drops, or devices that vanish after sleep.
What it does:
  • Enables Bluetooth radio, clears stale device pairings, and restarts the BT service.
  • Adjusts power settings that can suspend the radio or devices.
Pro tips:
  • Remove the affected device (Settings > Bluetooth & devices), then run the troubleshooter and pair again.
  • Interference is real: move 2.4 GHz dongles (mouse/keyboard) away from Wi‑Fi antennas and USB 3.0 ports.
Printer​
Use this for printers stuck “offline,” jobs stuck in queue, or new printers that won’t add.
What it does:
  • Restarts the Print Spooler, clears the queue, and re‑adds default drivers if needed.
  • Fixes common port mapping and network discovery issues.
Pro tips:
  • If you’re on a company network with shared printers, ensure the device is reachable and you have permission.
  • For USB printers that disappear, try a different port after the troubleshooter runs.
Keyboard​
Use this for non‑responsive keys, wrong layout characters, or delayed repeat.
What it does:
  • Confirms keyboard layout and language, resets repeat delay/rate, and checks filter keys.
  • Re‑enables disabled HID keyboard devices.
Pro tips:
  • Verify the input language in the taskbar language button; swap to the layout you expect.
Power​
Use this when battery drains too quickly, the PC won’t sleep, or it wakes unexpectedly.
What it does:
  • Resets power plans to recommended defaults and checks for blockers that prevent sleep.
  • Adjusts lid close and power button actions.
Pro tips:
  • Third‑party RGB or peripheral managers often block sleep. Close them and rerun the tool if sleep fails.
Program Compatibility​
Use this when older apps crash, display incorrectly, or require admin rights.
What it does:
  • Applies shims for DPI scaling, legacy graphics modes, and run‑as‑administrator settings.
  • Suggests compatibility modes for prior Windows versions.
Pro tips:
  • You can also right‑click an app > Properties > Compatibility to apply settings manually.
Incoming Connections​
Use this when others cannot connect to services you host (RDP, SMB shares, game servers).
What it does:
  • Checks firewall rules, network profiles, and service states.
  • Ensures required ports are allowed for Private networks.
Pro tips:
  • For remote access over the internet, you still need router port forwarding; the tool can’t configure your router.
Shared Folders​
Use this for “Access denied” or missing network shares.
What it does:
  • Validates share names and permissions and checks SMB client/server components.
  • Resets discovery settings that hide shares on Private networks.
Pro tips:
  • Ensure both PCs are on Private network profiles for discovery to work smoothly.
Search and Indexing​
Use this when Start search is slow, missing results occur, or file types aren’t indexed.
What it does:
  • Rebuilds indexing locations, repairs the Windows Search service, and clears corrupted catalogs.
  • Checks permission issues that prevent indexing of user folders.
Pro tips:
  • If you keep data on another drive, add it in Indexing Options after the troubleshooter completes.
Video Playback​
Use this for choppy video, HDR problems, or apps that won’t play DRM content.
What it does:
  • Resets hardware acceleration and media playback settings.
  • Checks codecs and suggests default app associations that work with protected content.
Pro tips:
  • For HDR monitors, confirm Settings > System > Display > HDR is enabled and use the built‑in calibration tool.
Windows Store Apps​
Use this when Microsoft Store, Photos, or other built‑in apps crash or won’t update.
What it does:
  • Resets app caches, re‑registers app packages, and repairs Store licensing.
  • Checks background permission settings that block updates.
Pro tips:
  • Run “wsreset” from Start to clear the Store cache after the troubleshooter if issues persist.
Windows Update​
Use this for update failures, repeated rollback loops, or error codes during install.
What it does:
  • Stops update services, clears and re‑creates update cache folders, and re‑registers components.
  • Restarts services with known‑good defaults and checks servicing stack health.
Pro tips:
  • After the troubleshooter, check for updates again in Settings > Windows Update, and install any pending servicing stack or cumulative updates first before optional drivers.
Fast Results: A Quick‑Start Recipe for Common Problems​
If you just need a clean sequence to follow, use these targeted playbooks.
Wi‑Fi or Ethernet won’t connect​
  • Run Internet Connections and apply fixes.
  • Run Network Adapter; select your adapter when prompted.
  • Toggle Airplane mode on/off; reconnect to your SSID.
  • If still offline: open Settings > Network & internet > Advanced network settings > Network reset. Reboot when prompted.
No sound or wrong speaker selected​
  • Run Playing Audio and accept changes to default device.
  • In Settings > System > Sound, pick the correct Output device.
  • If on Bluetooth, remove and re‑pair the headset; then run Bluetooth troubleshooter.
Printer is “offline” or won’t print​
  • Run Printer; clear the spooler and apply fixes.
  • Power cycle the printer; ensure it’s on the same network.
  • Re‑add the printer in Settings > Bluetooth & devices > Printers & scanners.
Windows Update errors​
  • Run Windows Update troubleshooter; apply all fixes.
  • Reboot and try “Check for updates” again.
  • If it still fails, follow the advanced reset in the next section.
When a Troubleshooter Fails: Advanced Repair Playbooks​
Troubleshooters fix a lot, but not everything. The sequences below resolve stubborn cases without resorting to a full reset. Run commands from an elevated Windows Terminal (Admin).
System file integrity​
  • Scan system files:
  • sfc /scannow
  • Repair component store:
  • DISM /Online /Cleanup-Image /RestoreHealth
  • Reboot and rerun the original troubleshooter.
These commands repair corrupted or missing system files that can cause troubleshooters to fail or undo fixes on reboot.
Deep reset for Windows Update​
If updates repeatedly fail after running the automated tool:
  • Stop update services:
  • net stop wuauserv
  • net stop bits
  • net stop cryptsvc
  • net stop msiserver
  • Rename cache folders:
  • ren C:\Windows\SoftwareDistribution SoftwareDistribution.old
  • ren C:\Windows\System32\catroot2 catroot2.old
  • Start services:
  • net start wuauserv
  • net start bits
  • net start cryptsvc
  • net start msiserver
  • Reboot, then check for updates again.
This forces Windows Update to rebuild its working folders and metadata.
Network stack refresh (manual)​
If connectivity issues outlive the troubleshooters:
  • ipconfig /flushdns
  • netsh winsock reset
  • netsh int ip reset
  • Reboot, reconnect to the network, and test again.
Microsoft Store repair​
  • Reset the Store cache:
  • wsreset
  • Re‑register Store and apps (elevated PowerShell):
  • Get-AppxPackage -AllUsers Microsoft.WindowsStore | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.InstallLocation)\AppxManifest.xml"}
Then open Microsoft Store and try updates again.
Search index rebuild​
If Search is still incomplete after the troubleshooter:
  • Open Control Panel > Indexing Options > Advanced > Rebuild.
  • Keep the PC plugged in; rebuilding can take time on large libraries.
Safety, Reversibility, and Privacy​
  • Data safety: Troubleshooters apply configuration changes but do not delete personal files. Still, if you’re about to make deeper adjustments (registry edits, app re‑registration, service resets), create a System Restore point first.
  • Admin rights: Some fixes require elevation. If you run as a standard user, you may see prompts; approve them to allow the repair.
  • Privacy and diagnostics: Recommended troubleshooters rely on diagnostic telemetry to detect issues and tailor fixes. You can adjust how aggressively Windows runs these in Settings > System > Troubleshoot. If you prefer more control, set it to ask before applying changes.
Limitations and Known Caveats​
Troubleshooters are powerful, but they have boundaries. Understanding where they stop saves time.
  • Hardware faults: No software tool can repair a failing SSD, dying Wi‑Fi card, or swollen battery. If problems persist across clean boots and multiple users, consider hardware diagnostics.
  • Third‑party security software: Some antivirus or firewall suites intercept network calls or block Windows services. Temporarily disable them while testing, then re‑enable when done.
  • Custom configurations: If you rely on non‑default policies, scripts, or registry tweaks, a troubleshooter may revert settings to recommended defaults. Document your customizations so you can reapply them if needed.
  • Legacy troubleshooters: Older Microsoft Support Diagnostic Tool (MSDT) flows have been phased out in favor of newer, integrated experiences. If you’re used to launching hidden troubleshooters by command ID, you may find they redirect to modern equivalents or no longer exist. Use Settings or the Get Help app instead to access supported tools.
  • Domain‑joined devices: In managed environments, Group Policy or MDM can restrict automated repairs or network profile changes. Coordinate with IT if a tool reports it cannot make required changes.
An IT Pro’s Perspective: Make Troubleshooters Part of a Repeatable Playbook​
For help desk teams, standardize on a tiered approach where troubleshooters are step one, not an afterthought. Doing so reduces ticket time, improves first‑call resolution, and avoids invasive fixes.
  • Tier 0 (self‑service): Provide end users a short guide with the exact paths—System > Troubleshoot > Other troubleshooters—and which tool to run for common symptoms. Encourage a reboot midway if the first run fails.
  • Tier 1 (assisted): Have techs run the relevant troubleshooter twice: once before any manual changes and once after basic hygiene (reboot, update drivers, clear caches) to confirm stability.
  • Tier 2 (advanced): Use the playbooks here—SFC/DISM, update cache reset, network stack repair—and collect logs (Event Viewer channels for Windows Update, Networking, and AppX Deployment) if the issue persists.
  • Tier 3 (escalation): Create system restore points, capture reliability history, and evaluate in‑place repair installs if corruption is widespread.
Standardized notes should capture which troubleshooter was run, what it reported, and any changes applied. That history becomes gold when patterns emerge across multiple devices.
Troubleshooters for Performance, Battery, and Stability​
While not a full performance suite, a few built‑in tools can help stabilize a sluggish system.
  • Power troubleshooter: Resets plans that force high‑performance or block sleep, improving battery life.
  • Search and Indexing: Fixes runaway indexing that hurts I/O on HDDs and small SSDs.
  • Windows Store Apps: Stops background crash loops from built‑in apps that can spike CPU usage.
  • Program Compatibility: Allows legacy line‑of‑business apps to run without GPU thrashing or admin prompts, improving user experience.
Combined with basic hygiene—free disk space, uninstall bloat, update graphics drivers—these tools often restore a smooth baseline.
Step‑By‑Step: The Smart Way to Run Troubleshooters​
To get consistent results, run them deliberately rather than randomly.
  • Identify the subsystem. Match the symptom to the closest troubleshooter (network, audio, update, etc..
  • Close open apps. Prevent interference and ensure services can restart cleanly.
  • Run the troubleshooter. Accept suggested fixes and allow administrative changes if prompted.
  • Reboot. Many fixes finalize after a restart.
  • Re‑test and rerun. If the issue resurfaces, run the same troubleshooter again; look for different findings on the second pass.
  • Advance to the next playbook. If still unresolved, apply the relevant advanced steps in this guide.
This disciplined flow prevents half‑applied repairs and eliminates hidden dependencies that often cause “it worked once, then broke again.”
Troubleshooter‑Plus: Pair With These Built‑In Tools​
Windows 11 includes other utilities that complement the automated troubleshooters.
  • Reliability Monitor: Type “Reliability” in Start and open Reliability Monitor to see a timeline of crashes, updates, and driver installs. Correlate events with when issues began.
  • Device Manager: Update or roll back a driver that a troubleshooter identifies as problematic.
  • Event Viewer: Check Windows Update (WindowsUpdateClient/Operational), AppXDeployment‑Server, and Diagnostics‑Networking logs for detailed error codes.
  • System Restore: Create a restore point before deep changes; restore if needed to undo a problematic configuration.
  • Clean Boot: Use System Configuration (msconfig) to perform a clean boot that isolates third‑party services. If a problem disappears, reintroduce services gradually to find the culprit.
These tools turn a successful automated fix into a durable one by revealing root causes and confirming stability.
Frequently Asked Questions​
Why is a troubleshooter not working or failing to start?​
Most failures stem from system file corruption, interrupted services, or pending updates that hold locks on components. Restart your PC, check for updates, and then run the troubleshooter again. If it still fails, use SFC and DISM to repair the component store, reboot, and retry. Also confirm that core services such as Diagnostic Policy Service and Background Intelligent Transfer Service are running.
Can troubleshooters fix Windows Update errors automatically?​
Yes. The Windows Update troubleshooter performs targeted resets of update services and caches. It resolves many transient errors on its own. When it doesn’t, the deeper reset sequence in this guide (stopping services, renaming SoftwareDistribution and catroot2, then restarting services) typically clears persistent issues.
Are Windows 11 troubleshooters safe to use?​
Yes. They apply safe, reversible system‑level changes, avoid deleting personal files, and limit scope to the subsystem you choose. For complex environments or heavily customized systems, document your current settings and create a restore point if you’re about to apply broader manual repairs.
Should I enable recommended troubleshooters to run automatically?​
If you value convenience and don’t significantly customize Windows, enabling automatic or “run then notify” is sensible. For highly tuned or managed systems, choose a setting that asks before applying changes so you can review the plan.
A Practical Checklist You Can Save​
  • Open Settings > System > Troubleshoot > Other troubleshooters.
  • Run the tool that matches your symptom; accept recommended fixes.
  • Reboot and retest. Rerun the tool if necessary.
  • If unresolved:
  • System file repair: sfc /scannow and DISM /Online /Cleanup-Image /RestoreHealth.
  • Windows Update deep reset (stop services, rename caches, start services).
  • Network stack refresh (flush DNS, reset Winsock/TCP/IP).
  • Store repair (wsreset and app re‑registration).
  • Rebuild Search index.
  • Create a restore point before deeper changes; document custom configurations.
  • Use Reliability Monitor, Device Manager, and Event Viewer for root‑cause clues.
  • For managed devices, check policy restrictions before applying changes.
Final Analysis: Strengths, Risks, and the Best Way to Use Windows 11 Troubleshooters​
The built‑in troubleshooters are a fast, low‑risk first line of defense. Their biggest strength is institutional knowledge: they encode the fixes Microsoft’s engineers know solve the majority of everyday problems. They are discoverable in Settings, run quickly, and guide you through the steps with clear prompts. When paired with a reboot, they resolve many issues in a single pass.
There are risks—but they’re manageable. Automated repairs can revert custom tweaks, and legacy command‑based flows from older versions of Windows may no longer be available as Microsoft retires outdated components. On tightly managed or specialized PCs, your policies may block automated changes. None of these are reasons to avoid the tools; they’re reasons to use them intentionally, with restore points and notes when deeper steps are needed.
The most effective approach is layered. Start with the right troubleshooter, let it do its job, and then validate the fix. If it doesn’t hold, move to the targeted playbooks in this article: system file repairs, cache resets, and network stack refreshes. Use Windows’ supporting tools to confirm stability and get ahead of repeat incidents. With this method, you’ll fix most Windows 11 problems quickly, safely, and without resorting to a wipe‑and‑reload—exactly what modern PC support should look like.
Source: Windows Report How to Use Troubleshooters in Windows 11 to Fix Common Issues
Support hub
