Kaso
Well-Known Member
I received my laptop yesterday - Core i5, 4GB RAM, Windows 7 Professional 64-bit. I proceeded to install some apps from Microsoft and Adobe. Installation went fine and the apps started without problems. As soon as I saw the long list of fonts in Word, I wanted to remove as many of them as I possibly could.
Brought up Fonts panel. Only 10 fonts - 10 ancient, bitmap fonts. What!? I saw and selected many fonts in Microsoft and Adobe apps. The fonts are indeed there, but they are simply not shown - no Segoe, no Cambria, no Corbel, no Constantia, not even Arial and Times New Roman, nothing.
I got nervous and decided to restore Windows all the way back to the starting point. No luck. Same problem.
Today, I created the recovery DVDs from the factory partition. Rebooted from the DVDs to re-image C drive. Set up Windows and created my account. Windows 7 came up fresh. I went straight to the Fonts panel to check. Horror - the same 10 bitmap fonts, and nothing else.
What is going on? The factory-installed Windows 7 has problems showing fonts? What should I do now?
Thanks in advance.
Hi Kaso,
The fonts maybe hidden. Go to Control Panel\Fonts, click on Font Settings, and then Restore Default Font Settings. If the fonts are hidden, this should do the trick.
Further, if you'd like to install (and uninstall) fonts, please refer to the steps found at this page: Install or uninstall fonts
Hope this helps :D
Ahmad AA
Windows 7 Professional Outreach Team
I have the same problem as most of the other posters here. I've tried all the suggestions, but none of them seemed to work. So, I'm using Bitstream Font Manager now to see and manage my fonts. It works fine. I don't even look at the stupid font folder anymore -- it's just too frustrating.
Do you think this problem might come from Windows 7 trying to handle older, Type 1 fonts?
