Windowsforum.com desktop shortcut
davidhk129
The following is how the desktop short looks like.
I seem to recall I saw a different one some time ago.
Does everyone have the same shortcut?
davidhk129
So, what makes mine so "generic "?
Yes, I have cleared IE cache.
No, I have not reset my IE because I don't consider this as indication of being unstable.
I have Win 7 Home Premium SP1, IE 10, and fully updated.
Same issue with my Win 8.1Pro, IE11.
whoosh
Cooler King
Not sure maybe one of the more tech guys could furnish an answer. I will point this thread out.
Delete the shortcut then try ctrl + F5 key combo or sign out/in. Then re-create the shortcut.
Personally I don't use shortcuts, I keep my desktop icon free. Instead I create folders in my booksmark bar, then save site as bookmark...much easier.
seekermeister
Honorable Member
I was wondering what the discussion about a desktop shortcut for the forum was about, then remembered that not everyone uses a browser with a speeddial function.
davidhk129
#7
Problem solved.
I ended up rebuilding my icon cache.... for just one lousy shortcut.
Pauli
#8
I'm on the same line with bassfisher, I don't really like the shortcuts. I use bookmarks for Internet, and then I use the old and dumb Start button > programs... but then of course, I can be considered old and dumb - by anyone who DARES it!
Generally, I think the Forum looks good.
