The thread discusses a user experiencing issues with all icons appearing identical and affecting the start menu, suggesting a possible virus or corruption issue. A responder recommends rebuilding the icon cache by deleting the IconCache.db file and restarting. Another user suggests running a thorough virus scan, indicating concern that malware might be the cause. Overall, the conversation focuses on troubleshooting icon display problems, with solutions involving cache cleanup and malware scanning.
uturn
I need some help and I'm not sure this is the right place. If not could somebody lead in the right direction. Problem: all my icons are the same and when I click on them it opens that program. It has also invaded my start menu. What can I do to fix this? Thanks for any and all help!:rolleyes: Uturn
Rebuilding the icon cach will probably sort it:
Goto control panel, folder options, views. Select the option to show Hidden / System Files. Navigate to C:\Users\<yourUserName>\AppData\Local folder and delete the hidden IconCache.db file. Reboot.
patcooke
Microsoft MVP
Microsoft MVP
Pauli
Fantastic Member
I'm not the first to point out a virus issue, but that sounds like it. I would suggest a thorough scan. One with your own program, perhaps wit an online one.
