The forum discussion revolves around a user's ongoing issue with their ASUS X44H laptop's sound system, which shows an "x" over the sound icon and prevents sound-related programs from running. Multiple contributors suggest troubleshooting steps, including repairing Windows, checking for hardware problems, and ensuring sound is not muted. Ultimately, the original poster decides to replace the laptop instead of attempting further repairs, indicating frustration with resolving the sound issue.
Peemcheng Xiong
I have been having problems with my laptop and there seems to be no way that I know of to solve the problem. I cannot run any programs that require sounds and the sound icon displays an "x" over it. I have already tried all the posted solutions about updating the sound driver, downloading a new driver, and I have even restored my computer back to its' factory settings. The sound system on my ASUS X44H laptop does not seem to work.
This is at the level of "Did you check to make sure it is plugged in?", but I have seen people go nuts checking for the underlying problem and the issue was that they had accidentally put the sound on mute. On my computer, the sound icon gets an X when it is on mute. There are several locations where you can disable the sound through a setting. If you didn't already check those, it's worth a look before you buy a new computer. If you are getting a message that "No Audio Output Device is Installed", it's not that.
badrobot
If you have tried everything, try Repair Install. Google it up. There are lots of tutorials to do system repair on Windows 7. Good luck!
Pauli
Fantastic Member
Agree with badrobot, plus: there's always the possibility of a hardware problem. If it still has warranty, take it to the retailer, or some service.
Peemcheng Xiong
Thread Author #4
There really isn't a way to fix this problem. I don't want to spend 20 to 30 dollars on a system recovery disk for my laptop, so I'm getting a better laptop.
Fixer1234
Pauli
Fantastic Member
Good point, Fixer. One should always start with the easiest part... :up:
Like we have a saying, Don't go fishing further than the sea.
