BSOD Hell...please help me!
#21
It's good now:
ASACPI.sys Wed May 13 21:25:17 2009
021311-17534-01.dmp, 021311-18314-01.dmp
ExceptionCode: c0000005 (Access violation)
Probably caused by : dxgmms1.sys
Could you help me with the web link to Corsair RAM CM3X2G-1600C7DHXIN ?
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\021311-17534-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16695.amd64fre.win7_gdr.101026-1503
Machine Name:
Kernel base = 0xfffff800`02a5c000 PsLoadedModuleList = 0xfffff800`02c99e50
Debug session time: Sun Feb 13 08:27:54.167 2011 (UTC - 5:00)
System Uptime: 0 days 4:20:51.525
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image \SystemRoot\System32\drivers\dxgmms1.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for dxgmms1.sys
*** ERROR: Module load completed but symbols could not be loaded for dxgmms1.sys
BugCheck 1000007E, {ffffffffc0000005, fffff880048307ac, fffff88002e14748, fffff88002e13fb0}
Probably caused by : dxgmms1.sys ( dxgmms1+307ac )
Followup: MachineOwner
0: kd> !analyze -v
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003.  This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG.  This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG.  This will let us see why this breakpoint is
happening.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff880048307ac, The address that the exception occurred at
Arg3: fffff88002e14748, Exception Record Address
Arg4: fffff88002e13fb0, Context Record Address
Debugging Details:
FAULTING_IP:
dxgmms1+307ac
fffff880`048307ac 488b11          mov     rdx,qword ptr [rcx]
EXCEPTION_RECORD:  fffff88002e14748 -- (.exr 0xfffff88002e14748)
ExceptionAddress: fffff880048307ac (dxgmms1+0x00000000000307ac)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
CONTEXT:  fffff88002e13fb0 -- (.cxr 0xfffff88002e13fb0)
rax=0000000000000000 rbx=0000000000000000 rcx=1000000000000000
rdx=fffff8a001e91320 rsi=fffff8a001e91320 rdi=0000000000000000
rip=fffff880048307ac rsp=fffff88002e14980 rbp=fffffa8005c23000
 r8=000000000002b000  r9=0000000000000000 r10=0000000000000001
r11=fffff8a001e91428 r12=0000000000000000 r13=0000000000000001
r14=fffffa8005c2cca0 r15=fffff8a001e91428
iopl=0         nv up ei pl nz na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00210206
dxgmms1+0x307ac:
fffff880`048307ac 488b11          mov     rdx,qword ptr [rcx] ds:002b:10000000`00000000=????????????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
CURRENT_IRQL:  0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  ffffffffffffffff
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002d040e0
 ffffffffffffffff
FOLLOWUP_IP:
dxgmms1+307ac
BUGCHECK_STR:  0x7E
LAST_CONTROL_TRANSFER:  from 0000000000000000 to fffff880048307ac
STACK_TEXT:
fffff880`02e14980 00000000`00000000 : fffffa80`05c23000 fffff8a0`01e91320 fffff8a0`00000000 fffffa80`05c22b90 : dxgmms1+0x307ac
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  dxgmms1+307ac
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: dxgmms1
IMAGE_NAME:  dxgmms1.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4d3fa174
STACK_COMMAND:  .cxr 0xfffff88002e13fb0 ; kb
FAILURE_BUCKET_ID:  X64_0x7E_dxgmms1+307ac
Loading Dump File [F:\a\Minidump\D M P\DMP\021311-18314-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02a14000 PsLoadedModuleList = 0xfffff800`02c51e50
Debug session time: Sun Feb 13 10:20:01.969 2011 (UTC - 5:00)
System Uptime: 0 days 1:38:46.327
BugCheck 1000007E, {ffffffffc0000005, fffff880048307ac, fffff88002135748, fffff88002134fb0}
2: kd> !analyze -v
happening.
Arguments:
Arg3: fffff88002135748, Exception Record Address
Arg4: fffff88002134fb0, Context Record Address
Debugging Details:
FAULTING_IP:
dxgmms1+307ac
EXCEPTION_RECORD:  fffff88002135748 -- (.exr 0xfffff88002135748)
NumberParameters: 2
CONTEXT:  fffff88002134fb0 -- (.cxr 0xfffff88002134fb0)
rdx=fffff8a009d154a0 rsi=fffff8a009d154a0 rdi=0000000000000000
rip=fffff880048307ac rsp=fffff88002135980 rbp=fffffa8005bec000
 r8=0000000000100000  r9=0000000000000000 r10=0000000000000001
r11=fffff8a009d155a8 r12=0000000000000000 r13=0000000000000001
r14=fffffa8005919ec0 r15=fffff8a009d155a8
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010206
dxgmms1+0x307ac:
CURRENT_IRQL:  0
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002cbc0e0
 ffffffffffffffff
FOLLOWUP_IP:
dxgmms1+307ac
BUGCHECK_STR:  0x7E
STACK_TEXT:
fffff880`02135980 00000000`00000000 : fffffa80`05bec000 fffff8a0`09d154a0 fffff8a0`00000000 fffffa80`05be9b90 : dxgmms1+0x307ac
STACK_COMMAND:  .cxr 0xfffff88002134fb0 ; kb
Drivers:
fffff880`0412b000 fffff880`04169000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00f01000 fffff880`00f58000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02c0e000 fffff880`02c98000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`041bb000 fffff880`041d1000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`0105f000 fffff880`0106a000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`04176000 fffff880`0417e000   ASACPI   ASACPI.sys   Wed May 13 21:25:17 2009 (4A0B72FD)
fffff880`00e2a000 fffff880`00e33000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`01035000 fffff880`0105f000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`044fe000 fffff880`0451e000   AtihdW76 AtihdW76.sys Wed Nov 17 07:02:04 2010 (4CE3C43C)
fffff880`048b1000 fffff880`050e8000   atikmdag atikmdag.sys Tue Jan 04 21:48:52 2011 (4D23DC14)
fffff880`03f23000 fffff880`03f70000   atikmpag atikmpag.sys Tue Jan 04 21:19:38 2011 (4D23D53A)
fffff960`00950000 fffff960`009b1000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`00fc9000 fffff880`00fd5000   BATTC    BATTC.SYS    Mon Jul 13 19:31:01 2009 (4A5BC3B5)
fffff880`019ee000 fffff880`019f5000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`03ed6000 fffff880`03ee7000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`0639d000 fffff880`063bb000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`007c0000 fffff960`007e7000   cdd      cdd.dll      unavailable (00000000)
fffff880`019bb000 fffff880`019e5000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00ccf000 fffff880`00d8f000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01955000 fffff880`01985000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c71000 fffff880`00ccf000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01128000 fffff880`0119b000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`00fc0000 fffff880`00fc9000   compbatt compbatt.sys Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`041ab000 fffff880`041bb000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`06271000 fffff880`0627a000   cpuz135_x64 cpuz135_x64.sys Tue Nov 09 08:33:36 2010 (4CD94DB0)
fffff880`045df000 fffff880`045ed000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`03e35000 fffff880`03eb8000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`03eb8000 fffff880`03ed6000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`02db2000 fffff880`02dc1000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`0193f000 fffff880`01955000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0455b000 fffff880`0457d000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`04400000 fffff880`04409000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`045ed000 fffff880`045f9000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`04409000 fffff880`0441c000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`0441c000 fffff880`04428000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`050e8000 fffff880`051dc000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`04800000 fffff880`04846000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`03aaa000 fffff880`03b83000   eamonm   eamonm.sys   Thu Dec 09 00:29:20 2010 (4D006930)
fffff880`01800000 fffff880`01825000   ehdrv    ehdrv.sys    Thu Dec 09 00:29:58 2010 (4D006956)
fffff880`0627a000 fffff880`0629b000   epfwwfpr epfwwfpr.sys Thu Dec 09 00:26:09 2010 (4D006871)
fffff880`04169000 fffff880`04176000   fdc      fdc.sys      Mon Jul 13 20:00:54 2009 (4A5BCAB6)
fffff880`010b6000 fffff880`010ca000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`044de000 fffff880`044e9000   flpydisk flpydisk.sys Mon Jul 13 20:00:54 2009 (4A5BCAB6)
fffff880`0106a000 fffff880`010b6000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`013dc000 fffff880`013e6000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01905000 fffff880`0193f000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`0148b000 fffff880`014d5000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`02ff1000 fffff800`0303a000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`04846000 fffff880`0486a000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`04583000 fffff880`045df000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`04896000 fffff880`048af000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`041f5000 fffff880`041fd080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`04888000 fffff880`04896000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`062d5000 fffff880`0639d000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`018fc000 fffff880`01905000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`03f0d000 fffff880`03f23000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`0419c000 fffff880`041ab000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`03ba4000 fffff880`03bb2000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bad000 fffff800`00bb7000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`0442f000 fffff880`04472000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`013b1000 fffff880`013cb000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01460000 fffff880`0148b000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`0457d000 fffff880`04582200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`03bcf000 fffff880`03be4000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`051dc000 fffff880`051ff000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c19000 fffff880`00c5d000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`07307000 fffff880`07315000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`0409c000 fffff880`040ab000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`03bb2000 fffff880`03bbf000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00e10000 fffff880`00e2a000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`063bb000 fffff880`063d3000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`063d3000 fffff880`06400000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`06200000 fffff880`0624e000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`0624e000 fffff880`06271000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`01883000 fffff880`0188e000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f61000 fffff880`00f6b000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`010ca000 fffff880`01128000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`02da7000 fffff880`02db2000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`018ea000 fffff880`018fc000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`014ff000 fffff880`015f1000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04000000 fffff880`0400c000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`0400c000 fffff880`0403b000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`044e9000 fffff880`044fe000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02d0c000 fffff880`02d1b000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02c98000 fffff880`02cdd000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01400000 fffff880`01460000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`0188e000 fffff880`0189f000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02d9b000 fffff880`02da7000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02a14000 fffff800`02ff1000   nt       ntkrnlmp.exe Tue Oct 26 22:43:09 2010 (4CC791BD)
fffff880`0120e000 fffff880`013b1000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`019e5000 fffff880`019ee000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`02ce6000 fffff880`02d0c000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00fab000 fffff880`00fc0000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f6b000 fffff880`00f9e000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00fea000 fffff880`00ff1000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00e00000 fffff880`00e10000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`013cb000 fffff880`013dc000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`03a00000 fffff880`03aa6000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`03bbf000 fffff880`03bcf000   point64  point64.sys  Tue Jun 29 04:54:31 2010 (4C29B4C7)
fffff880`0451e000 fffff880`0455b000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c5d000 fffff880`00c71000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`041d1000 fffff880`041f5000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0403b000 fffff880`04056000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`04056000 fffff880`04077000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`04077000 fffff880`04091000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`02d4a000 fffff880`02d9b000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`04091000 fffff880`0409c000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`01868000 fffff880`01871000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01871000 fffff880`0187a000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0187a000 fffff880`01883000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`018b0000 fffff880`018ea000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`03be4000 fffff880`03bfc000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0629b000 fffff880`062a6000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`014e5000 fffff880`014ed000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`07200000 fffff880`07296000   srv      srv.sys      Mon Jun 21 23:21:11 2010 (4C202C27)
fffff880`0731e000 fffff880`07386000   srv2     srv2.sys     Mon Jun 21 23:20:47 2010 (4C202C0F)
fffff880`062a6000 fffff880`062d3000   srvnet   srvnet.sys   Mon Jun 21 23:20:32 2010 (4C202C00)
fffff880`040ab000 fffff880`040ac480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01603000 fffff880`01800000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`03fc6000 fffff880`03fd8000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`0189f000 fffff880`018ac000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`01000000 fffff880`0101e000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02d36000 fffff880`02d4a000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00490000 fffff960`0049a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`03ee7000 fffff880`03f0d000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`04472000 fffff880`04484000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`0417e000 fffff880`0419b000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`04428000 fffff880`04429f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`04877000 fffff880`04888000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04484000 fffff880`044de000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`03f70000 fffff880`03fc6000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`0486a000 fffff880`04877000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00f9e000 fffff880`00fab000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01825000 fffff880`01833000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01833000 fffff880`01858000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`014d5000 fffff880`014e5000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00fd5000 fffff880`00fea000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00d8f000 fffff880`00deb000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`0119b000 fffff880`011e7000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`02d1b000 fffff880`02d36000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`01858000 fffff880`01868000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e4e000 fffff880`00ef2000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00ef2000 fffff880`00f01000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02cdd000 fffff880`02ce6000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00050000 fffff960`00360000   win32k   win32k.sys   unavailable (00000000)
fffff880`00f58000 fffff880`00f61000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`03b83000 fffff880`03ba4000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`040c8000 fffff880`0412b000   yk62x64  yk62x64.sys  Wed Sep 15 10:31:29 2010 (4C90D8C1)
Unloaded modules:
fffff880`040ad000 fffff880`040bb000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`07296000 fffff880`07307000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`072ad000 fffff880`0731e000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01985000 fffff880`01993000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01993000 fffff880`0199f000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0199f000 fffff880`019a8000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`019a8000 fffff880`019bb000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`0417e000 fffff880`0419c000   i8042prt.sys
    Checksum:  00000000
    ImageSize:  0001E000
#22
Set it 1066Mhz 7-7-7-20.
#23
Sorry to appear thick, but what link/info is it you need?
Do you think it is a memory problem?
Set ram to 1066??? so low?
#24
I need the official rated specs for your RAM, as recommended by Corsair.
Yes I do.
#25
This is the ifo written on the sticks themselves:
CM3X2048 - 1600C7DHXIN
XMS - 1600 2048MB
7-7-7-20 1.90v ver3.1
08451327 (no idea what this number is).
I hope this is the info you need.
#26
I just went into the Bios screen and adjusted the memory down to 1066.
I did, however, notice that it said that if the ram was set to 1600 or 1800 the FSB and CPU would also be auto adjusted to suit the ram freq.
I remember the guys over at the Corsair forum telling me that I would have to make some changes in the Bios to run this memory at 1600. I was told to overclock cpu from 2.8Ghz to 3.4Ghz (20%).
....wait a minute!! I just read in the MB manual that it only supports up to 1333Mhz for the ram!!! Although the MB can overclock ram at 1600 and 1800. 1333 is the highest freq for memory as standard.
You thoughts?
#27
You thoughts?
I stated my thoughts long time ago:
Important! Every thread starter please see. said:
- If your RAM sticks are set wrong, or if they are mismatching, or not supported by motherboard, your BSOD thread will grow many pages and yet you'll be having crashes. Sorting software and drivers won't help, and memtest will not necessarily detect errors.
XMS - 1600 2048MB
Well, what I needed was this:
http://www2.corsair.com/_datasheets/TWIN3X4096-1600C7DHXIN.pdf
SPD programmed at:
 XMP 7-7-7-20 values at 1600MHz
 JEDEC standard 9-9-9-24 values at
1333MHz
Since your motherboard does support DDR1333, set the RAM this way in the bios:
1333 Mhz 9-9-9-24
Should work. Otherwise you need new RAM or a new motherboard. Memory sticks must be compatible with the motherboard.
#28
Thank you very much for your patients Cyber.
I will set the ram as you said.
If all else fails I'll just get some other ram modules.
Thanks again :)
#29
Sure thing, you're much welcome.
