Rebop
Just took my Windows 10 Laptop out of the house for the first time. I am so used to 7 and hovering the connection in the notification tray for IP address and connection speed I was surprised not to find this. And then more surprised not to be able to find some utility to regain this functionality. I want to know the connection speed from somewhere on the taskbar.
Got a solution?
~Bob
Thank for the rply
I do not actually want to measure "usage" just the connection speed. And I think you are correct, this was a Lenovo utility that has become indispensable. All I really would like is a hoverable something to say connected to:_____________ at 144MBs, for example IP address assigned would be a bonus. Not finding anything.
Thanks again.
~Bob
I think I found a freeware program that might work for you. I tried it out in 10 and it seems to be working fine and has a ton of customization options.
NetWorx : bandwidth monitor, connection speed test & traffic usage log
Also I unchecked the filtering program at install I just left the task bar integration checked.
Hope this works for you
Krypto
So, anything I can try to get it working again? Remove anything in the registry? Delete any files? I just do not see what is different between when it worked and now. Maybe the file that keeps the locations? Worth directing me there to delete it?
Actually, just found it. I was dated the day before the restore, but maybe. Trying now....
That caused it to ask for a location name, but still no left click on the icon.
Here the log...
You can try the second to last uploaded version. It will probably throw an exception and tell us what is crashing.
Same issue. No left click.
Tried the .net repair tool and another install of .net 4.5 and nothing. Says already installed. So this has to be something that recently changed in Win 10 or a result of the resstore for a backup some how. Too odd??
thanks
~Bob
The more I think about it, the more I am sure it worked after the restore. But was older version. I changed to latest and MAY have been working then. Then a TON of Microsoft updates on the 27th and that was when it started not working. Fairly sure.
Can you go into System Settings > Notifications & actions. Under the section "Show notifications from these apps" Are they turned on for NetStatus?
Well, don't spend too much time. I appreciate all you have done. Just cannot understand what changed so it doe snot work any longer/.
I did in a few ways. Toggled. Exited and toggled, etc. No change. Something is preventing the left click and info.
I have a clue.
Under "Select which icons appear on the taskbar" I show BOTH netstatus and netstaus.exe. Something odd. Doing a registry seatrch right now.
Purged just a few things from the registry. Did not change the show which icons list. Did not change how NetStatus does not work.
Any help here?:
Version=1
EventType=CLR20r3
EventTime=131143894874316449
ReportType=2
Consent=1
UploadTime=131143894874941536
ReportIdentifier=b2174347-56a0-11e6-af83-a434d9c56da3
IntegratorReportIdentifier=2fc3b058-ea66-4bc9-bd62-cac541b7e3b7
NsAppName=NetStatus.exe
Response.BucketId=f0d1ba390c2f715c5c4d1304d8617980
Response.BucketTable=5
Response.LegacyBucketId=129158007272
Response.type=4
Sig[0].Name=Problem Signature 01
Sig[0].Value=NetStatus.exe
Sig[1].Name=Problem Signature 02
Sig[1].Value=1.0.0.0
Sig[2].Name=Problem Signature 03
Sig[2].Value=57843748
Sig[3].Name=Problem Signature 04
Sig[3].Value=System.Windows.Forms
Sig[4].Name=Problem Signature 05
Sig[4].Value=4.6.1038.0
Sig[5].Name=Problem Signature 06
Sig[5].Value=5615c2ae
Sig[6].Name=Problem Signature 07
Sig[6].Value=cc6
Sig[7].Name=Problem Signature 08
Sig[7].Value=141
Sig[8].Name=Problem Signature 09
Sig[8].Value=System.ObjectDisposedException
DynamicSig[1].Name=OS Version
DynamicSig[1].Value=10.0.10586.2.0.0.256.48
DynamicSig[2].Name=Locale ID
DynamicSig[2].Value=1033
DynamicSig[22].Name=Additional Information 1
DynamicSig[22].Value=dc46
DynamicSig[23].Name=Additional Information 2
DynamicSig[23].Value=dc46f1b11575dea6fc1dd6153adbb098
DynamicSig[24].Name=Additional Information 3
DynamicSig[24].Value=9ae7
DynamicSig[25].Name=Additional Information 4
DynamicSig[25].Value=9ae79ae79326a59566680b0e0017b37c
UI[2]=C:\Win 10 Software & Utilities\NetStatus.exe
UI[3]=NetStatus has stopped working
UI[4]=Windows can check online for a solution to the problem.
UI[5]=Check online for a solution and close the program
UI[6]=Check online for a solution later and close the program
UI[7]=Close the program
LoadedModule[0]=C:\Win 10 Software & Utilities\NetStatus.exe
LoadedModule[1]=C:\Windows\SYSTEM32\ntdll.dll
LoadedModule[2]=C:\Windows\SYSTEM32\MSCOREE.DLL
LoadedModule[3]=C:\Windows\system32\KERNEL32.dll
LoadedModule[4]=C:\Windows\system32\KERNELBASE.dll
LoadedModule[5]=C:\Windows\system32\apphelp.dll
LoadedModule[6]=C:\Windows\system32\ADVAPI32.dll
LoadedModule[7]=C:\Windows\system32\msvcrt.dll
LoadedModule[8]=C:\Windows\system32\sechost.dll
LoadedModule[9]=C:\Windows\system32\RPCRT4.dll
LoadedModule[10]=C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscoreei.dll
LoadedModule[11]=C:\Windows\system32\SHLWAPI.dll
LoadedModule[12]=C:\Windows\system32\combase.dll
LoadedModule[13]=C:\Windows\system32\bcryptPrimitives.dll
LoadedModule[14]=C:\Windows\system32\GDI32.dll
LoadedModule[15]=C:\Windows\system32\USER32.dll
LoadedModule[16]=C:\Windows\system32\IMM32.DLL
LoadedModule[17]=C:\Windows\system32\kernel.appcore.dll
LoadedModule[18]=C:\Windows\SYSTEM32\VERSION.dll
LoadedModule[19]=C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll
LoadedModule[20]=C:\Windows\SYSTEM32\MSVCR120_CLR0400.dll
LoadedModule[21]=C:\Windows\assembly\NativeImages_v4.0.30319_64\mscorlib\43226440664fdfb99f9ad60968b2a60c\mscorlib.ni.dll
LoadedModule[22]=C:\Windows\system32\ole32.dll
LoadedModule[23]=C:\Windows\system32\uxtheme.dll
LoadedModule[24]=C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clrjit.dll
LoadedModule[25]=C:\Windows\system32\OLEAUT32.dll
LoadedModule[26]=C:\Windows\assembly\NativeImages_v4.0.30319_64\System\43b8952c0d907f0a02958a98443699ba\System.ni.dll
LoadedModule[27]=C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Drawing\fdc9c3b678ad232cb22146073f71c998\System.Drawing.ni.dll
LoadedModule[28]=C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Windows.Forms\9b397cef9e862b789463f8fb670d66f7\System.Windows.Forms.ni.dll
LoadedModule[29]=C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.10586.0_none_396e892957c7fb25\comctl32.dll
LoadedModule[30]=C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.10586.494_none_a2d8b04ea53e3145\comctl32.dll
LoadedModule[31]=C:\Windows\system32\dwmapi.dll
LoadedModule[32]=C:\Windows\system32\MSCTF.dll
LoadedModule[33]=C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Core\8e325c9a2b96c925621b8214b5785cd7\System.Core.ni.dll
LoadedModule[34]=C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Configuration\af40f3c8414c2b75e6a9e9c7a79fed97\System.Configuration.ni.dll
LoadedModule[35]=C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Xml\b6708e6e2b55466cc8c5ac0eed95468b\System.Xml.ni.dll
LoadedModule[36]=C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.10586.494_none_d3c3a333ffd0ab13\gdiplus.dll
LoadedModule[37]=C:\Windows\SYSTEM32\DWrite.dll
LoadedModule[38]=C:\Windows\system32\shell32.dll
LoadedModule[39]=C:\Windows\system32\cfgmgr32.dll
LoadedModule[40]=C:\Windows\system32\windows.storage.dll
LoadedModule[41]=C:\Windows\system32\shcore.dll
LoadedModule[42]=C:\Windows\system32\powrprof.dll
LoadedModule[43]=C:\Windows\system32\profapi.dll
LoadedModule[44]=C:\Windows\SYSTEM32\sxs.dll
LoadedModule[45]=C:\Windows\system32\clbcatq.dll
LoadedModule[46]=C:\Windows\System32\wshom.ocx
LoadedModule[47]=C:\Windows\System32\MPR.dll
LoadedModule[48]=C:\Windows\System32\ScrRun.dll
LoadedModule[49]=C:\Windows\system32\propsys.dll
LoadedModule[50]=C:\Windows\SYSTEM32\LINKINFO.dll
LoadedModule[51]=C:\Windows\SYSTEM32\ntshrui.dll
LoadedModule[52]=C:\Windows\SYSTEM32\SspiCli.dll
LoadedModule[53]=C:\Windows\SYSTEM32\srvcli.dll
LoadedModule[54]=C:\Windows\SYSTEM32\cscapi.dll
LoadedModule[55]=C:\Windows\Microsoft.NET\Framework64\v4.0.30319\diasymreader.dll
State[0].Key=Transport.DoneStage1
State[0].Value=1
FriendlyEventName=Stopped working
ConsentKey=CLR20r3
AppName=NetStatus
AppPath=C:\Win 10 Software & Utilities\NetStatus.exe
NsPartner=windows
NsGroup=windows8
ApplicationIdentity=129892CA5244E5225B02002AED7E16E8
That "Program has stopped working" could be an issue with Windows or .NET itself. The error is not coming from the program itself.
Interesting.
Si I noted there is nothing .net in programs and features to repair or uninstall. I downlaoded a netfix_setupvrrifier program. It reports that all versions are installed fine from 2.0 to 4.6.1. It does show the following errors but would suprise me if this is the issue:
[07/31/16,08:53:03] Beginning of new SetupVerifier error logging session
[07/31/16,08:53:03] Build created on December 18, 2015
[07/31/16,08:53:03] For more information about repairing the .NET Framework, see http://support.microsoft.com/kb/2698555 and Download Microsoft .NET Framework Repair Tool from Official Microsoft Download Center
[07/31/16,08:53:03] Activity log file location: C:\Users\bulius\AppData\Local\Temp\setupverifier_main_07-31-16_08.53.03.txt
[07/31/16,08:53:03] Error log file location: C:\Users\bulius\AppData\Local\Temp\setupverifier_errors_07-31-16_08.53.03.txt
[07/31/16,08:53:04] Detected operating system: Windows 10 (x64)
[07/31/16,08:53:04] Windows directory: C:\Windows
[07/31/16,08:53:04] System directory: C:\Windows\system32
[07/31/16,08:53:04] Program Files directory: C:\Program Files (x86)
[07/31/16,08:53:04] Common Files directory: C:\Program Files (x86)\Common Files
[07/31/16,08:53:21] ***WARNING*** File C:\Windows\Microsoft.NET\Framework64\v4.0.30319\aspnet.mof is not installed on the system
[07/31/16,08:53:21] ***WARNING*** File C:\Windows\Microsoft.NET\Framework64\v4.0.30319\aspnet.mof.uninstall is not installed on the system
[07/31/16,08:53:37] ***WARNING*** File C:\Windows\Microsoft.NET\Framework64\v4.0.30319\aspnet.mof is not installed on the system
[07/31/16,08:53:37] ***WARNING*** File C:\Windows\Microsoft.NET\Framework64\v4.0.30319\aspnet.mof.uninstall is not installed on the system
[07/31/16,08:53:50] ***WARNING*** File C:\Windows\Microsoft.NET\Framework64\v4.0.30319\aspnet.mof is not installed on the system
[07/31/16,08:53:50] ***WARNING*** File C:\Windows\Microsoft.NET\Framework64\v4.0.30319\aspnet.mof.uninstall is not installed on the system
[07/31/16,08:54:06] ***WARNING*** File C:\Windows\Microsoft.NET\Framework64\v4.0.30319\aspnet.mof is not installed on the system
[07/31/16,08:54:06] ***WARNING*** File C:\Windows\Microsoft.NET\Framework64\v4.0.30319\aspnet.mof.uninstall is not installed on the system
[07/31/16,08:54:17] ***WARNING*** File C:\Windows\Microsoft.NET\Framework64\v4.0.30319\aspnet.mof is not installed on the system
[07/31/16,08:54:17] ***WARNING*** File C:\Windows\Microsoft.NET\Framework64\v4.0.30319\aspnet.mof.uninstall is not installed on the system
[07/31/16,08:54:26] ***WARNING*** File C:\Windows\Microsoft.NET\Framework64\v4.0.30319\aspnet.mof is not installed on the system
[07/31/16,08:54:26] ***WARNING*** File C:\Windows\Microsoft.NET\Framework64\v4.0.30319\aspnet.mof.uninstall is not installed on the system
[07/31/16,08:55:17] SetupVerifier exiting with return value 0
The main file shows nothing that points out an issue and is long.
No other program has an issue as far as I can tell. Not sure what else to trouble shoot.
~Bob
Reset the notification tary and older is no longer available to show. Which is good, but no change.
Could this have anything to do with "location" Neemo? I recall changing privacy settings though changing back what I thought I changed makes no change to NetStatus.
Anniversary Win 10 Update today. Netstatus started working again! Go figure:)
Broke a bunch of other things. Making a list....
Lol well at least it's working again. The location of Netstatus.exe doesn't matter, except if you have it set to start on boot since the start up would no longer point to the correct path. That could be fixed by simply toggling the "start on boot". The profile path is set to be in C:\ProgramData\Neemobeer\Netstatus. If it doesn't exist Netstatus will recreate it. It doesn't use the registry at all.
Hi Neemobeer,
Today was my lucky day for Win 10 1809 updates. Broke 8 things and of course, NetStatus :) It reports No Active Networks even though I am online. I go to adapter settings and just touch the wireless network and it works. 50% of the time it is perfect from there until a restart and 50% it creates the message in the action center rather than the slideout with sound.
Got a fix?
Thanks!
~Bob
