Windows 7 No Audio input device is installed...:( (with images )
MissNotsoPerfect
Laptop=Toshiba Satellite
Windows 7
current sound drivers overview: image
An image from 'No Audio input device is installed...:( (with images )'. Images show audio device drivers installed but playback issues and no audio output detected.
ive tried uninstalling the drivers...previously conexant than NVIDIA but no luck.
Microsoft Fix it results:attached
The audio jus suddenly disappears.....no solution seems to work.Some1 pls help...!!
The speakers n headphone both show "ready" state but No audio....really frustrating.
i know its kinda messy,im really short of time ...:/
Not sure if Toshiba has this but Dell site will look at the PC and tell you what model. Goto toshiba site and see if they have this option.
badrobot
Uninstall those drivers (right-click) and restart your PC. If drivers did not install automatically after restart, download and install manually.
MissNotsoPerfect
An image from 'No Audio input device is installed...:( (with images )'. Audio troubleshooting ended with 'Audio device is disabled' and not fixed.
hmm done wid it...the drivers have been installed automatically....Now wot?? still no audio :/
Which toshiba satellite have you got?
i dunno ....how exactly can i find out....sorry not so gud at this.....ny further guidance please...:)
Jimbo22
Look on the bottom of the laptop.....you should see the make/model and serial number.
MissNotsoPerfect
I see nothin written there....even if it was ever,its kinda rubbed,u know faded.....
laptops n year old...if its that impo,i might look through old files..
no other way of findin out?
helpifIcan
Fantastic Member
Sonny
Fantastic Member
Check to the lower right hand side of your keyboard. Some Toshiba's show the model number there. Don't know if they all do.
badrobot
Or download a speccy portable so we can at least see your motherboard and sound card specs.
This is from my Win 8.1 tablet as a sample:
An image from 'No Audio input device is installed...:( (with images )'. System specs: Windows 8.1, Intel 1.33GHz CPU, 2GB RAM, 29.1GB SD card, no optical drive.
Trouble
Noob Whisperer
If you're running out of places to look for details regarding make and model you might try looking under the battery. In some cases you might find a sticker inside the battery compartment with that information. Don't know if Toshiba does that or not.
MissNotsoPerfect
An image from 'No Audio input device is installed...:( (with images )'. Speccy shows Windows 7 system with several 'Cannot initialize SPC dll' errors for key hardware info.
Link Removed <=====This is da 1
Toshiba Satellite L735-S3220RD Notebook....:)
