Microsoft’s latest Windows 11 Insider preview builds quietly add a one‑click internet speed‑test shortcut to the taskbar network flyout — but the shortcut simply opens Bing’s web‑based speed test rather than running a native, offline measurement — and the same builds also include a subtle but meaningful refresh of several Settings pages and a new, still‑unfinished “Background AI tasks” area that signals Microsoft’s next phase of AI system controls.
Windows-style desktop with translucent dashboards showing download/upload graphs on a blue abstract wallpaper.Background: what Microsoft shipped to Insiders this week​
Microsoft delivered the incremental checkpoints identified as Build 26220.6682 (Dev) and Build 26120.6682 (Beta) as part of update KB5065782 through the Windows Insider channels. Those releases are documented on the official Windows Insider blog and are the authoritative confirmation of the flighted builds and the general scope of changes rolling out to testers. The changes surfaced in these updates are small at a glance, but they reflect two broader trends in Windows engineering: 1) surfacing web‑hosted utilities directly from system UI (reducing duplicate engineering by linking to cloud services) and 2) reorganizing Settings surfaces to make cross‑device and AI‑related controls easier to find and manage. Community captures and early reporting revealed the new taskbar speed‑test control, the reworked Bluetooth & devices > Mobile devices page, clearer Privacy & security labeling, and the addition of a Background AI tasks settings page.
The new built‑in speed test: shortcut, not a native tool​
What changed in the taskbar and quick settings​
Insider builds now show a Perform speed test control in two convenient places:
  • In the right‑click context menu for the network (system tray) icon.
  • As a button inside the Wi‑Fi quick settings flyout that appears when you click the network indicator on the taskbar.
Screenshots from preview testers show Microsoft positioning the control near the Wi‑Fi refresh and adapter selection controls, which makes it easy for users to run a quick throughput check from where they already diagnose connectivity.
How the feature actually behaves​
Despite the interface being inside Windows, the flow is deliberately web‑backed:
  • Clicking the taskbar shortcut opens your default browser.
  • The browser navigates to Bing’s speed‑test widget.
  • You run the measurement from the Bing page; results show download, upload, and latency figures.
This means the control is a launcher for a web service rather than a locally executed diagnostic. Microsoft is funneling users to the Bing tool instead of shipping new measurement engines and server‑selection infrastructure inside Windows itself. That design choice has clear operational advantages — and notable tradeoffs.
Which backend powers the test?​
Bing’s speed test widget has been widely reported to surface Speedtest (Ookla) infrastructure for the actual measurements. Microsoft’s Bing page provides the speed test tool and independent reporting (Edge/TechSpot and others) confirms that the experience delegates to the established speed‑test backends in the web experience. In short, users get a one‑click path to the same underlying measurement tech they would see on Speedtest.net, but wrapped inside Bing’s web UI.
Why Microsoft went this way (practical reasoning)​
By routing taskbar checks to a web widget, Microsoft gains:
  • Update agility: measurement server lists, algorithms, and UI can be changed server‑side without OS updates.
  • Reduced OS complexity: no need to ship and maintain a local measurement engine or server discovery logic across Windows SKUs.
  • Consistent experience: the same Bing/Edge widget is available across devices and platforms.
Those are pragmatic engineering reasons, but they also create a dependency model: the test requires a working browser and access to web servers, and results may vary by browser/network stack and by which remote test server is selected. That changes the diagnostics profile compared with a native diagnostic tool.
What this means for privacy, accuracy, and enterprise use​
Accuracy and reproducibility​
Web‑based tests are convenient but present measurement variability:
  • Browser networking stacks and parallel request handling can slightly alter throughput numbers.
  • Choice of server (how Bing/Ookla select the test host) and server load at test time affect results.
  • Repeatability across machines requires controlling browser and network conditions.
Tech outlets and community testing have flagged discrepancies between embedded web widgets and running Speedtest directly; for power users or IT staff who need repeatable, auditable results, dedicated clients remain preferable.
Provider choice and vendor lock‑in​
The taskbar shortcut currently funnels users to a single provider (Bing + Speedtest/Ookla). That makes the experience simple for mainstream users, but it reduces choice for organizations that standardize on other diagnostics (for example, Fast.com for ISP validation or bespoke ISP‑facing tools). Enterprises that require specific testing endpoints or controlled server selection will still rely on standalone tools.
Telemetry and privacy caveats​
Because the measurement runs in the browser and is provided by Bing/partner services, the network traffic and the resulting telemetry are handled outside Windows. That raises questions for privacy‑sensitive environments and regulated industries where data collection or unfiltered external calls must be controlled. The shortcut itself does not create new network telemetry inside Windows, but it does make it easier for users to run a web test that will interact with third‑party servers. Administrators should consider policy guidance in environments where outbound web testing is regulated.
How to use the feature (quick how‑to)​
  • Left‑click the network icon on the taskbar to open the Wi‑Fi quick settings, then tap the Perform speed test button; or
  • Right‑click the network (system tray) icon and select Perform speed test from the context menu.
  • Your default browser opens to Bing’s Speed Test page; click Start to run the measurement.
  • Review the displayed Download, Upload, and Latency numbers, and rerun if needed.
This flow mirrors the experience of searching “speed test” in Bing or using the Edge sidebar speed test tool. It’s fast for casual troubleshooting but not designed to replace scripted or monitored testing in managed environments.
Alternatives for power users and admins​
If you need repeatable, auditable tests or offline options, consider these alternatives:
  • Use the official Speedtest CLI (Ookla) for scripted, server‑selectable CLI testing.
  • Use PowerShell’s Test‑NetConnection to verify basic connectivity, port reachability, and latency in scripts.
  • Use router‑level or ISP‑provided diagnostics for line‑level validation.
  • For continuous monitoring, deploy network telemetry and synthetic transactions via dedicated monitoring tools (and avoid ad‑hoc manual tests for SLA verification).
PowerShell examples: Test‑NetConnection -ComputerName example.com -Port 443 -InformationLevel Detailed provides diagnostic output suitable for logging and automation.
Settings refresh: mobile devices, privacy, and clearer labels​
Bluetooth & devices > Mobile devices​
The Mobile devices area inside Settings > Bluetooth & devices has been reorganized in these Insider builds so that linked phones and their cross‑device controls appear on a consolidated page rather than launching a separate “Manage mobile devices” window. This is part of Microsoft’s broader effort to unify cross‑device experiences (Phone Link / Link to Windows) into the Settings surface for a more coherent UX. Microsoft documentation and Insider posts confirm the updated flow for Phone Link integration and managing mobile device features from Settings. Benefits of the change include:
  • Fewer context switches — linked phone controls are visible in the main Settings surface.
  • Easier access to per‑device toggles (File Explorer visibility, connected camera mode, photo notifications).
  • Simpler removal/unpairing flow that integrates Phone Link and Settings controls.
Privacy & security tweaks​
Insider reports and Windows coverage indicate Microsoft is refining the Privacy & security section with clearer headings and expanded descriptions so users better understand the effects of toggles and permissions for features — especially for AI‑powered capabilities. This includes a clearer display of which apps have recently requested access to generative AI features in some preview flights. Those interface changes align with Microsoft’s stated goals of making AI interactions more transparent in the OS.
The new “Background AI tasks” page — early signs of a control plane for AI​
One of the most interesting additions in these preview builds is a dedicated Background AI tasks settings page. At present the page is not complete — community testers report the UI is unstable or crashes during testing. The page’s mere presence is notable because it signals Microsoft is preparing an explicit control surface for AI processes that run outside the foreground app context. That could evolve into:
  • A task manager–like list focused on AI workloads or AI‑accelerated services.
  • Runtime controls for throttling background AI inference, telemetry, or network access.
  • Permissions and visibility for model downloads, accelerator usage, and GPU/NPUs resource allocation.
Because the page is still under development and reports show it crashes in early previews, treat any behavior described by testers as provisional; the implementation details will likely change before general availability. Community reports and early previews are the primary evidence for the page’s behavior today rather than formal Microsoft release notes. Consider the current instability a development artifact rather than a finished product.
Critical analysis: strengths, weaknesses, and risks​
Strengths and design wins​
  • Discoverability: Placing a speed‑test launcher in the same place users look for connectivity (network icon/quick settings) is a user‑friendly move that reduces friction for casual troubleshooting.
  • Maintainability: Using a web widget means Microsoft can iterate on accuracy and server mapping without OS updates.
  • Settings consolidation: Reorganizing Mobile devices and Privacy pages reduces context switching and improves cross‑device manageability.
  • Sign of strategic thinking: The Background AI tasks page indicates Microsoft is building controls for an AI‑centric future of Windows, which is appropriate given the platform’s increasing use of local and cloud AI.
Weaknesses and limitations​
  • Not a native tool: The speed‑test is a shortcut to Bing, which limits its usefulness in offline or restricted networks and introduces variability based on the browser and web stack.
  • Vendor centricity: Funnel to Bing/Ookla by default reduces choice and may not meet enterprise test standardization needs.
  • Stability of preview builds: Insider builds frequently include unstable or unfinished features (Settings crashes, experimental pages). The Background AI tasks page crashing is a concrete example. Insiders should expect and tolerate early instability.
Risks and governance questions​
  • Privacy and telemetry: Because the measurement runs on Bing’s web service, administrators must consider what metadata and telemetry are sent to external providers and whether this complies with organization policy.
  • Operational dependence: Relying on a web widget for a core diagnostic shortcut creates an operational dependency on external services; an outage of the web test would break the “one‑click” diagnostic pathway.
  • Regulatory compliance: Organizations in regulated sectors that must maintain logs of diagnostics or control outbound network traffic will need to restrict or standardize how users run speed tests.
Practical guidance: what to do next​
  • For everyday users: The taskbar shortcut is a convenient, no‑install way to check whether your network is grossly slow. Use it for quick verification, then move to deeper tools if you need more detail.
  • For power users and admins: Continue to rely on the Speedtest CLI, Test‑NetConnection in PowerShell, and router/ISP diagnostics for repeatable, auditable testing.
  • For IT teams: Update troubleshooting documentation to reflect that a new one‑click test may be present on managed devices; if necessary, provide guidance on approved testing methods and how/when to use the Bing shortcut.
  • For privacy‑conscious users: Be aware that the test runs in the browser and sends data to the web provider; if you need an offline diagnostic, use native tools or offline client binaries.
The Insider caveat: previews change, and not everything ships​
Microsoft repeatedly emphasizes that features seen in Windows Insider flights are experimental and may be rolled out gradually, altered, or removed before reaching general availability. The official Windows Insider announcements include clear reminders that feature rollouts are controlled and subject to change, and that preview builds may not be suitable for primary work machines due to stability considerations. That advice remains critical — these flies are a staging ground for experimentation and feedback, not a final product.
Conclusion: incremental polish with strategic intent​
The one‑click speed‑test shortcut is a small but telling example of how Microsoft is evolving Windows: pragmatic shortcuts that tie into cloud services, a desire to surface helpful tools at the point of need, and an ongoing effort to reorganize settings around real‑world tasks (linked phones, privacy, and soon, AI). The choice to route diagnostics to a web widget favors maintainability and speed of iteration, but it also shifts control to web partners and introduces variability and policy considerations for managed environments.
The presence of a Background AI tasks page — albeit unstable today — is the most forward‑looking element of these builds. That page hints at a future in which Windows will need explicit controls and observability for AI workloads that run out of band. When that feature matures it could be one of the most important additions to the OS in the short term: a place where users and administrators can see, throttle, and manage AI activity the same way they manage traditional background processes.
For now, the build offers useful polish for everyday users and signals to IT teams about future change. Insiders who like being early will find the tweaks welcome; organizations and power users should note the tradeoffs and keep established, auditable tools in their troubleshooting toolset.
Source: www.guru3d.com Windows 11 Insider Builds Add Built-In Internet Speed Test that outputs to Bing
Microsoft is quietly rolling out a one‑click pathway to check your internet connection from the Windows 11 taskbar: a new system tray shortcut that opens a network speed test in your default browser, currently visible in Insider preview builds.
Windows 11 desktop with a speed test window showing 0 Mbps download and 480 Mbps upload.Background​
Microsoft has long leaned on lightweight web tools and browser‑backed widgets to provide quick diagnostics without heavy OS changes. The latest example is a new “Perform speed test” entry that appears when you interact with the network icon in the taskbar: both as a right‑click context menu item and as a button inside the Wi‑Fi quick settings flyout. Early reports and screenshots from Windows Insider sleuths show the control placed beside familiar quick actions so it’s easy to discover when connectivity feels off. This behavior is currently limited to Windows Insider preview builds in the Dev and Beta channels (build families reported include 26220.6682 and 26120.6682), which means the feature is under test and may change before any public release. Microsoft’s official Insider release notes for the Dev channel confirm the cadence and rollout mechanisms that make features like this visible to select Insiders first.
What the shortcut does — the simple truth​
  • The UI element is a shortcut; it does not run a native, in‑OS speed measurement engine.
  • When you select the action, Windows opens your default browser and navigates to Bing’s online speed test widget where you can run a download/upload/latency measurement.
This is a deliberate tradeoff: by delegating the heavy lifting to a browser‑based tool Microsoft avoids adding a local measurement service, server selection logic, and the maintenance burden that comes with embedded diagnostics. It also lets the web tool be updated independently of Windows servicing. Early reporting indicates this is consistent with several recent Windows UI choices that surface web‑backed utilities from system UI.
Where you’ll find it in Windows 11​
In the system tray (right‑click)​
Right‑click the network icon in the taskbar (Wi‑Fi or Ethernet icon). The context menu now shows a Perform speed test entry alongside items such as Network Troubleshooter and Network Settings. Screenshots from testers show a speedometer icon for quick recognition.
In the Wi‑Fi quick settings flyout​
Left‑click the same network icon to open the quick settings flyout. In the lower‑right corner of the panel you’ll see a Test internet speed or similar button that performs the same action and opens Bing’s speed test in the default browser.
Why Microsoft likely implemented it this way​
There are three practical reasons Microsoft chose a browser shortcut instead of embedding a local speed‑test engine:
  • Web tools are easier to update independently from Windows servicing cycles, so fixes and adjustments roll out faster.
  • Leveraging an existing web widget (Bing’s speed test) avoids duplicating global testing infrastructure and server networks.
  • A web approach keeps the OS footprint small and reduces additional security and maintenance overhead for Microsoft.
All of the above are sensible engineering tradeoffs — but they introduce operational differences that matter to anyone who needs reliable, repeatable network diagnostics.
Measurement accuracy: browser widget vs native testing​
A one‑click web tool is great for convenience, but it’s important to understand the limitations.
What a web speed test measures​
Most browser‑based speed tests show:
  • Download throughput
  • Upload throughput
  • Round‑trip latency (ping)
Bing’s speed test exposes these values in a one‑click flow and is the same widget you get by searching “speed test” on Bing.
Which backends power these results?​
Bing’s speed test experience is implemented using established speed‑test backends (many such embedded widgets have used Ookla’s Speedtest technology or other widely deployed backends). Multiple independent reports and widget analyses indicate Bing/Edge’s embedded speed test delegates measurement to existing, third‑party test infrastructures rather than inventing a new backend.
Why results can differ between tests​
  • Server selection: different speed‑test providers pick different test servers (closer servers often show higher speeds).
  • Browser network stack: tests running in a browser are constrained by the browser’s own networking behavior and any extensions, proxies, or VPNs.
  • Local interference: other devices or background apps consuming bandwidth during a test will lower measured throughput.
  • Measurement methodology: parallel connections, test duration, and chunk sizes affect reported speeds.
For consistent comparisons, run the same test repeatedly, on the same device, and ideally with no other network activity. For technical validation you should also compare results against command‑line or router‑based tests.
Privacy and telemetry: what to expect​
Running a web‑based speed test sends at least the following pieces of information to the test endpoint:
  • Your public IP address (required to route traffic and pick test servers).
  • Client headers (user agent, possibly browser locale).
  • Test measurement traffic (download/upload packets) that reveals throughput characteristics.
Because Bing’s widget runs on the web, data flows through Microsoft/Bing services and the backend provider (for example, Ookla if that backend is used). That means test metadata and aggregated telemetry could be collected according to those services’ privacy policies. If you have concerns about sharing data with Bing or third‑party speed test providers, keep that in mind. Public reporting so far does not show Microsoft collecting additional OS‑level diagnostics at the moment of this shortcut; the flow is a browser navigation to a web tool. This implementation detail can change as the feature evolves, and Microsoft has not published a dedicated privacy FAQ for the taskbar shortcut. Flag: Any claim that Microsoft will or will not retain specific telemetry from the shortcut beyond the normal web request context is currently unverified; formal privacy details would require an official Microsoft statement or updated documentation.
Enterprise and IT implications​
For IT admins and support teams this addition is a mixed bag.
  • Pros:
  • Faster first‑contact troubleshooting: support staff can ask a user to click the taskbar shortcut and run a known test without walking them through a website.
  • Standardized baseline: if the IT team endorses a specific web tool (for example, an internal portal or a chosen provider), the built‑in shortcut could be used as a consistent first step.
  • Cons:
  • Lack of control: the shortcut is tied to a web provider (Bing) and doesn’t allow choosing a corporate test server or private measurement nodes.
  • Not reliable in captive portal or DNS failure scenarios: if the network problem prevents the browser from loading the web tool, the shortcut is useless.
  • Auditability: for formal SLA checks or disputes with ISPs you’ll often need router logs or ISP‑provided tests rather than a quick web widget screenshot.
In short, this is a helpful consumer‑grade convenience — not a replacement for enterprise‑grade network diagnostics.
Alternatives and advanced options​
If you need more control, accuracy, or unattended testing, use these alternatives:
  • Fast.com (Netflix) — simple, streaming‑focused, runs immediately on the page and can show upload and latency details after the initial download test. Good for streaming‑quality checks.
  • Speedtest by Ookla (web and official CLI) — widely used, offers server selection and an official Speedtest CLI for scripted or automated tests. The CLI is available for Windows and is appropriate for repeatable, logged measurements.
  • TestMy.net and other independent testers — useful for cross‑checking results from different measurement methodologies.
  • Local/lan testing with iperf or LAN speed tools — for true local network performance testing (router ↔ PC) use iperf or dedicated LAN benchmarking tools to isolate Wi‑Fi issues from ISP links.
  • Router diagnostics or ISP portals — many ISPs provide their own speed checks which test to the ISP network edge and may carry more weight in service disputes.
How to use the new Windows 11 shortcut (quick guide)​
  • Click the network (Wi‑Fi / Ethernet) icon in the taskbar.
  • Either:
  • Right‑click the network icon and select Perform speed test, or
  • Open the Wi‑Fi quick settings and click the Test internet speed button in the panel.
  • Your default browser opens to Bing’s speed‑test widget.
  • Click Start (or the test runs automatically depending on the widget) and wait for download/upload/latency results.
  • Repeat the test a few times and compare with an alternate provider if needed.
Practical tips for better tests​
  • Close background apps that might consume bandwidth (cloud backups, streaming, Windows Update).
  • If possible, connect the test device to the router by Ethernet to isolate Wi‑Fi variability.
  • Run three tests over five minutes and use the median value rather than a single reading.
  • If you suspect ISP throttling or inconsistent performance, run tests to different provider endpoints (Ookla, Fast.com, ISP meter) and capture timestamps and screenshots for evidence.
A developer / power‑user view: command line and automation​
For reproducible results and scheduled monitoring, use a CLI tool:
  • Speedtest CLI (Ookla) — official command‑line client that can be scripted and scheduled on Windows via Task Scheduler. Use it for periodic logging and to select specific test servers for fairness between measurements.
Example (high level):
  • Download the official CLI from the vendor.
  • Run speedtest.exe --accept-license --format json > speed-results.json
  • Parse or upload the JSON to a monitoring system.
For local LAN diagnostics use iperf between two machines on the same network to test raw throughput independently of ISP or public test servers.
Strengths of the new taskbar shortcut​
  • Convenience: Quick access from a familiar place — the network icon — lowers friction for the average user.
  • Discoverability: Placing the control where users already check connection status makes it likely to be used when a connection appears slow.
  • Consistency: Routing users to Bing’s widget standardizes the initial troubleshooting flow for many users.
These are valid UX gains that will matter for end users and first‑line support staff.
Risks and limitations​
  • Not a native diagnostic: Because the test runs in a browser, it cannot help if the problem stops web pages from loading in the first place.
  • Measurement variability: Browser‑based widgets and different backend servers mean results are useful for quick checks but not authoritative proof in disputes.
  • Provider lock‑in (perception): Tying the shortcut to a single web provider may feel like product steering; users and admins may prefer choice of provider.
  • Privacy assumptions: Users should assume normal web telemetry applies; any deeper data sharing or telemetry beyond web hits should be verified with official Microsoft documentation.
These are important caveats for readers who might interpret the new shortcut as an authoritative or forensic networking tool.
What’s next — and what remains unverified​
Public reports show the feature in Dev and Beta Insider builds and that the control opens Bing’s online testing widget. Microsoft has not announced plans to convert this shortcut into a native in‑OS speed‑test engine, nor has the company published an official privacy FAQ specifically for this item. Any claim about a future built‑in app or expanded telemetry baked into Windows at the OS level remains speculative until Microsoft confirms it. Those points should be treated as unverified until official documentation or an announcement appears.
Bottom line​
The new Windows 11 taskbar speed test shortcut is a small but useful quality‑of‑life addition for everyday troubleshooting: it makes a one‑click check available exactly where users go when they suspect network trouble. However, because it directs users to a browser‑based test (Bing’s speed test widget), it is a convenience feature — not a replacement for rigorous network diagnostics or enterprise monitoring. For anyone who needs repeatable, auditable measurements, command‑line tools (Speedtest CLI), router logs, or localized LAN testing remain the recommended options.
If you rely on quick checks, the new shortcut will save time. If you rely on accurate and audit‑ready measurements, keep a tested toolkit (CLI tools, iperf, router diagnostics) at hand and use the taskbar button as the fastest way to get a rough, consumer‑grade snapshot of your internet connection.
Source: gHacks Technology News Windows 11 is getting a system tray shortcut to run a network speed test - gHacks Tech News
Microsoft is quietly testing a one-click network speed test shortcut in the Windows 11 system tray that launches Bing’s speed‑test widget in the default browser, putting a simple “Perform speed test” entry directly where users already go to check connectivity.
Windows 11 desktop showing a Bing speed test widget with 250 Mbps down, 150 Mbps up, 5 ms latency.Background​
Windows has long relied on third‑party websites and apps for ad hoc throughput checks: Speedtest by Ookla, Fast.com, and ISP portals are the typical go‑to tools. Microsoft’s recent Insider builds add a taskbar‑level shortcut designed to reduce that friction by placing a speed‑test launcher in the system tray (network icon) and inside the Wi‑Fi quick settings flyout. Early appearances of the control were discovered in Insider preview flights and community captures; Microsoft has rolled the relevant builds to Insiders in the Dev and Beta channels. This is not a native, kernel‑level measurement tool. Instead, the shortcut opens the user’s browser and navigates to Bing’s web speed‑test page — the same Bing widget that appears if you search for “speed test” — where the test itself is started and run from the web UI. That web widget, as implemented in Edge and Bing, draws on established speed‑test infrastructure to measure download, upload, and latency.
What Microsoft has added in Insider builds​
Where you’ll find the shortcut​
  • A “Perform speed test” entry appears in the right‑click context menu for the network/system tray icon.
  • A separate “Test internet speed” button appears in the bottom‑right corner of the Wi‑Fi quick settings flyout.
Both controls perform the same action: open the default web browser and load the Bing speed‑test widget so the user can start a measurement with a click. The UI placement is deliberate — it sits where most users instinctively go when troubleshooting network issues.
Which Insider builds contain it​
The UI was observed in Insider builds distributed in mid‑September 2025, notably builds in the 26220.6682 (Dev) and 26120.6682 (Beta) families (published as KB5065782 for participating Insiders). These builds are rolling out to testers who have opted into the latest preview updates. Because these are preview channels, features can be toggled server‑side and are not guaranteed to ship unchanged to the general public.
How the test actually works — technical flow​
  • The user clicks the system tray network icon (or right‑clicks it).
  • The user selects Perform speed test (or clicks the quick‑settings button).
  • Windows launches the default browser and opens the Bing speed‑test page.
  • The web widget runs the measurement and displays download, upload, and latency results.
Because the measurement occurs in the browser and through a web service, the test depends on normal HTTP/S connectivity to the test backend. If the problem prevents the browser from loading that page (DNS misconfiguration, captive portal, or broken HTTP), the shortcut cannot perform a measurement. The result is a fast, discoverable path to a web‑backed speed test, not a standalone OS diagnostic.
  • Low engineering overhead: By funneling users to a web widget, Microsoft avoids shipping and maintaining a local measurement engine, global server selection, and the backend infrastructure required for reliable worldwide tests.
  • Faster iteration: Web tools can be updated outside the Windows servicing cadence, enabling rapid fixes and feature parity across platforms.
  • Consistent UX: The same Bing‑hosted test can be surfaced from multiple Microsoft touchpoints (Taskbar, Edge, Bing search), ensuring a consistent one‑click experience.
These are pragmatic reasons for the design choice, but the tradeoffs — discussed below — matter for users who need repeatable, auditable, or offline‑capable diagnostics.
What this change means for average users​
For most home users and frontline helpdesk staff, the new shortcut is a clear win:
  • It reduces friction when verifying if a problem is the local machine or the upstream internet connection.
  • It standardizes a quick measurement flow so non‑technical users don’t have to remember specific websites.
  • It integrates with habits: the speed test is now accessible in the same place users look for signal strength and adapter selection.
If a user only needs a fast check of download and upload rates, this is the sort of little UX win that shortens troubleshooting and removes the guesswork about where to start.
Critical analysis — strengths and practical drawbacks​
Strengths​
  • Discoverability: The system tray placement is smart. When a connection falters, most users already open the network menu; surfacing a test there increases usage and helps non‑technical users gather objective data.
  • Maintainability: A web‑backed widget avoids duplicating server infrastructure. Microsoft can update or patch the test independently of Windows updates.
  • Cross‑product parity: The same Bing speed‑test experience is reachable from Edge and Bing, promoting consistency across Microsoft’s ecosystem.
Drawbacks and limitations​
  • Not a native diagnostic: Because it opens a browser, it won’t help in situations where HTTP/S is broken but lower‑level connectivity exists (for example, if DNS is poisoned or a captive portal blocks the test).
  • Measurement variability: Browser‑based tests introduce additional variability — browser extensions, caching, tab throttling, and sandboxing can all slightly skew results compared to a native client.
  • Single‑provider funneling: Early builds appear to link to the Bing/Edge widget with no immediate UI option to pick an alternative provider (Speedtest.net, Fast.com, ISP tools). That decision could frustrate users who prefer a different measurement engine.
Accuracy, backends, and the role of Ookla​
The Bing/Edge speed‑test implementation is not purely cosmetic: it leverages established measurement engines. Reporting and hands‑on analyses show the web widget uses the Speedtest engine provided by Ookla as the backend for server selection and throughput measurement. That is the same underlying technology many professionals use for consumer‑facing speed checks, but the wrapping matters for accuracy and auditing. Implications:
  • The test will generally provide results comparable to other Speedtest instances, but running inside a browser means additional processing layers may affect timing and throughput measurements.
  • For reliable, repeatable testing across networks — required when logging performance for ISPs, SLAs, or lab work — a native client (or a controlled tool such as iperf3 or a dedicated Speedtest client) still produces more consistent results.
Privacy, telemetry, and enterprise concerns​
The available previews do not expose a detailed privacy or telemetry policy specific to the taskbar shortcut. Because the test opens a web service, data flows to Bing/Edge and, depending on the backend, to third‑party test operators. For enterprises and privacy‑conscious users, this raises questions:
  • Which servers collect the test data?
  • Is the test associated with a Microsoft account or device telemetry?
  • Does the call reveal client identifiers, IP location, or other metadata to third parties?
Until Microsoft publishes detailed documentation covering telemetry, enterprise admins should treat the feature as an external web call and evaluate it under existing network and privacy policies. Flagged claims: public documentation on telemetry for this specific shortcut was not available at the time of reporting, and any statements about Microsoft’s internal telemetry handling should be considered provisional until Microsoft publishes explicit guidance.
Practical guidance — when to rely on the taskbar shortcut and when to use other tools​
Use the Windows 11 taskbar shortcut when:
  • You need a quick, informal check of download/upload or latency.
  • You are troubleshooting an immediate connectivity complaint and want a fast number to share with support.
  • You prefer the convenience of a one‑click flow and don’t require audited results.
Use alternative or additional tools when:
  • You need reproducible, auditable measurements (use a native Speedtest client, iperf3, or M‑Lab tools).
  • The network prevents normal HTTP/S access (use lower‑level diagnostics like ping, traceroute, or NIC‑level logs).
  • You need to test under controlled conditions (specific server, protocol, packet sizes, or parallel streams).
A quick, reproducible sequence for power users:
  • Run a browser‑based test (taskbar → Bing widget) for a quick baseline.
  • Run iperf3 against a known, trusted server to measure raw TCP/UDP throughput under controlled conditions.
  • If latency or packet loss is suspected, run repeated pings and traceroutes; capture packet traces with Wireshark if necessary.
Enterprise deployment and management considerations​
For IT admins evaluating rollout impacts:
  • The shortcut is a UI convenience and does not modify network stacks or drivers.
  • Group Policy and MDM controls may eventually include toggles to hide or disable the speed‑test entry; early Insider builds don’t show a built‑in administrative switch yet.
  • If privacy or telemetry is a concern, standard perimeter controls (blocking the specific Bing tools URL or applying web filtering policies) will prevent the shortcut from successfully loading the web widget.
  • When testing at scale, prefer controlled tools (iperf3 servers hosted in the corporate cloud) rather than consumer speed tests.
Enterprises should treat the feature like any other web launch action from the OS and review their web filtering, telemetry, and user instruction policies accordingly.
UX questions Microsoft should address before shipping​
  • Will admins be able to disable or redirect the shortcut to an internal speed‑test service?
  • Will Microsoft document the telemetry and any associated third‑party data handling?
  • Can users choose or configure the test provider (e.g., prefer Fast.com or an ISP tool)?
  • Will there be an offline fallback diagnostic path when HTTP is blocked?
Addressing these would significantly improve the feature’s value for both consumers and pros. Right now, it solves a discoverability problem elegantly but leaves deeper operational questions unanswered.
Alternatives worth knowing​
  • Speedtest by Ookla (native or web): Widely used, reliable, and provides downloadable clients for repeatable tests.
  • Fast.com (Netflix): Extremely simple, minimal UI, ideal for quick download checks.
  • iperf3: The go‑to tool for controlled measurements in lab and enterprise environments.
  • M‑Lab (Measurement Lab): Designed for network researchers and large‑scale measurement with an emphasis on open data.
  • Built‑in Windows diagnostics: For device‑level troubleshooting, Windows’ network diagnostic tools and Event Viewer can reveal local issues beyond raw throughput numbers.
These tools serve different use cases. The Windows 11 shortcut is convenient for quick checks but not a replacement for targeted, high‑integrity testing.
User tips and best practices​
  • Treat single speed‑test results as indicative, not definitive: run multiple consecutive tests at different times of day for a fuller picture.
  • Disable aggressive browser extensions and background downloads during tests to reduce noise.
  • When comparing results, use the same test endpoint and client to keep measurements consistent.
  • For persistent problems, collect multiple data points (speed tests, ping/traceroute, packet captures) before contacting your ISP or support team.
These simple habits reduce the chance of chasing intermittent or misleading data.
Final assessment​
The Windows 11 taskbar speed‑test shortcut is a well‑judged UX convenience that addresses a long‑standing discoverability gap. It fits Microsoft’s current pattern of surfacing web‑backed utilities inside system UI: quick to ship, easy to update, and broadly consistent across Microsoft products. In practice, the feature delivers a fast path to a familiar browser‑based speed test (Bing’s widget), which in turn relies on established backends such as Ookla’s Speedtest engine. For everyday users this is a useful addition; for IT professionals and privacy‑minded organizations it is a launchpad — not a replacement — for deeper diagnostics. Caveat: several operational details — telemetry, admin controls, and final back‑end behavior — are still unconfirmed publicly. These points should be treated as provisional until Microsoft publishes final documentation.
Quick reference: what to expect right now​
  • Feature: Perform speed test shortcut in the Windows 11 system tray and Wi‑Fi quick settings.
  • Behavior: Opens the default browser to the Bing speed‑test widget. Test runs in the browser.
  • Insider availability: Observed in Dev/Beta channel builds 26220.6682 and 26120.6682 (KB5065782) distributed to Windows Insiders.
  • Backend: The Bing/Edge widget delegates measurement work to established speed‑test infrastructure (notably Ookla’s Speedtest engine).
The new system‑tray shortcut is small but effective: it reduces friction, puts a useful tool where users expect it, and reflects a pragmatic engineering tradeoff. The real questions now center on control, transparency, and measurement fidelity — issues Microsoft can and should address during the remaining Insider testing window.
Microsoft has quietly added a one‑click internet speed test launcher to Windows 11 Insider preview builds, placing a “Perform speed test” / “Test internet speed” control directly in the Taskbar’s network menu and Wi‑Fi quick settings — but the button is a launcher that opens Bing’s web speed‑test widget in your default browser rather than executing a native, in‑OS measurement.
Windows desktop displaying Bing Speed Test in a browser with a 52% gauge.Background / Overview​
Windows 11 has been evolving through incremental Insider releases where Microsoft often experiments with small ergonomics and diagnostics features before deciding whether to ship them broadly. In mid‑September 2025 preview builds (reported in the Dev and Beta channels), testers began seeing a new taskbar affordance for running an internet speed check directly from the network (system tray) area. The control appears in two places: a context‑menu entry when you right‑click the network icon, and a small button inside the Wi‑Fi quick settings flyout. This addition is notable because it signals Microsoft’s continued preference for surfacing lightweight utilities via web‑backed flows instead of embedding full native subsystems inside Windows. The launcher funnels users to Bing’s speed‑test page, giving quick access to download/upload/latency readings with a minimum of friction. For most home users this will be a fast way to sanity‑check connectivity; for administrators and power users the design raises questions about reproducibility, telemetry, and provider choice.
What Microsoft added in Insider builds​
Where you’ll see the new control​
  • Right‑click the network (Wi‑Fi / Ethernet) icon in the notification area; a new Perform speed test entry is present in the context menu.
  • Left‑click the network icon to open the Wi‑Fi quick settings flyout; a Test internet speed button sits near other quick actions (Wi‑Fi refresh, airplane mode, etc..
Microsoft placed the control exactly where users already look when connectivity is suspect, which makes the feature highly discoverable and intuitive for basic troubleshooting. Screenshots and community captures from preview testers corroborate this placement.
Which Insider builds (reported)​
Community reporting ties the appearance to mid‑September Insider preview builds in the 26220.6682 (Dev) and 26120.6682 (Beta lineage) families distributed as part of the KB5065782 checkpoint — though features in Insider rings can be toggled server‑side and are not guaranteed to ship unchanged. Treat build numbers as provisional evidence rather than final release identifiers.
How the feature actually behaves (technical flow)​
  • User invokes the control — either by right‑clicking the network icon and selecting Perform speed test, or by clicking the Test internet speed button in the Wi‑Fi quick settings.
  • Windows launches the machine’s default browser and navigates to Bing’s Speed Test page (Bing Tools → Speedtest).
  • The speed test UI runs in the browser; the user clicks Start to measure download, upload, and latency. Results are displayed in the web UI.
This is an important distinction: the Taskbar control is a web shortcut embedded into system UI, not a native diagnostic engine running under Windows. If the browser cannot load the page (for example, DNS failure, captive portal, or blocked access), the shortcut cannot perform a measurement, which reduces its utility in some failure modes.
Backend, accuracy, and what actually measures your traffic​
Several reports indicate that the Bing speed‑test widget delegates measurement duties to established speed‑test infrastructure — widely reported as relying on the Speedtest (Ookla) backend in certain Bing/Edge integrations. However, Microsoft has not published a definitive technical whitepaper describing which server endpoints or algorithms are used when the test is launched from the Taskbar shortcut. That makes the backend attribution a well‑supported report rather than an unequivocal, documented fact from Microsoft. Treat claims about the exact measurement engine as probable but not fully verified. Why that distinction matters:
  • Browser‑based tests and native client tests often produce different values because of how browsers manage TCP stacks, prefetching, parallelism and HTTP overhead.
  • Server selection, connection concurrency, and test duration can differ between providers and between web‑embedded widgets and native clients.
  • For contractual or SLA disputes you need reproducible, auditable measurements — which browser‑based tests are less likely to provide by default.
Privacy, telemetry, and security considerations​
Because the speed test runs inside a web page, it inherits the browser and Bing service’s telemetry, logging, cookies, and server‑side behavior. A handful of practical implications:
  • Telemetry and logs are controlled by the web service (Bing) and are subject to Microsoft’s server‑side policies; browsing context (cookies, extensions, enterprise filters) may affect the test’s behavior and the data collected.
  • Enterprises with strict data‑handling requirements should be cautious: running the test sends IPs and timing data to external servers controlled by the provider, which may be routed outside corporate monitoring unless proxied.
  • The shortcut requires a working HTTP path; in scenarios where the network is down at the HTTP layer (DNS failures, captive portal), the shortcut is effectively unusable as a diagnostic.
Administrators should evaluate whether they want this web‑backed flow available to managed devices. Options include documenting the behavior for helpdesk scripts, blocking the specific Bing endpoint via policy (if required), or using internal testing endpoints and native tools for auditable measurements.
Strengths — why this makes sense for most users​
  • Immediate discoverability: Placing the launcher in the exact UI users check when connectivity feels off reduces friction and time to diagnosis.
  • Low maintenance: By linking to a centrally maintained web tool, Microsoft avoids building and operating a global measurement backend inside Windows, accelerating rollout while minimizing OS complexity.
  • Consistent UX: Users get the same test interface across devices and platforms (via Bing/Edge), which simplifies support workflows for home users and help desks.
For the majority of home users or first‑line support interactions, the Taskbar shortcut converts a common troubleshooting habit — “check my internet speed” — into a single, reliable click.
Limitations and risks — why this is not a replacement for native diagnostics​
  • Not auditable or reproducible by default: Browser tests can vary across browsers, system load, and background processes. For ISP disputes or compliance testing, native clients (Speedtest desktop/CLI, iperf3) with server selection and logging are preferable.
  • Provider lock and choice: Today the shortcut funnels to Bing’s tool. There is no user‑facing provider selection (e.g., Fast.com, a specific ISP test, or a private internal endpoint). Single‑provider reliance can be problematic for organizations that prefer vendor neutrality.
  • Telemetry and data controls: Because the measurement runs on an external web service, organizations that require on‑premises telemetry will find this approach incompatible unless they deploy their own internal tools or intercept the web traffic via an enterprise proxy.
  • Dependence on browser and HTTP: Unlike a native diagnostic, the shortcut cannot operate if the browser or web stack is impaired — one of the very scenarios where native tests would be useful.
These limitations are not fatal — they are trade‑offs Microsoft appears to accept in exchange for agility and simplicity — but they should be explicit in documentation and support guidance.
Enterprise and IT pro implications​
IT teams should prepare a short playbook that clarifies when the Taskbar shortcut is acceptable and when to escalate to robust testing methods:
  • Use Taskbar → Bing speed test for quick triage and user reassurance.
  • For reproducible tests or evidence gathering, run:
  • Speedtest CLI (Ookla) with a named server and recorded timestamps, or
  • iperf3 between controlled endpoints, and
  • netsh / ipconfig / traceroute logs for local diagnostics.
  • Decide whether to allow the Bing endpoint in managed networks or to block it if corporate policy forbids external telemetry.
  • Update helpdesk scripts to capture the test URL, timestamp, browser used, and any VPN/proxy context, to avoid ambiguous evidence in support escalations.
For managed devices enrolled in Insider channels, administrators must also consider whether and how Insider flighting policies expose preview features to users — and whether to opt devices into Dev/Beta rings at all, given that these builds can include experimental UI toggles.
Alternatives and best practices​
  • Native clients: Use the official Speedtest desktop client or CLI for server‑selectable, scriptable, and logged tests.
  • iperf3: Best for controlled, point‑to‑point performance measurements inside trusted networks.
  • PowerShell tools: Test‑NetConnection and other built‑in cmdlets provide programmatic reachability and basic latency checks without external web traffic.
  • Multiple provider corroboration: When accuracy matters, run tests against two independent providers and compare results. Browser tools are convenient but should be corroborated for mission‑critical use.
What Microsoft could do to make this feature enterprise‑ready​
If the Taskbar launcher becomes permanent, several enhancements would materially increase its value for IT and power users:
  • Add a selectable default provider or an enterprise policy to point the test to internal endpoints.
  • Allow exportable logs (CSV/JSON) that include server IDs, test timestamps, and raw throughput for auditability.
  • Provide explicit documentation of backend providers, server selection logic, and any telemetry collected when the test runs.
  • Offer an offline micro‑benchmark mode that can run minimal, local throughput checks independent of external HTTP access.
These changes would keep the convenience while addressing the real needs of reproducibility, privacy, and auditability.
How to use it today — quick how‑to​
  • Right‑click the network icon in the Taskbar and select Perform speed test, or left‑click the network icon and tap Test internet speed in the Wi‑Fi quick settings.
  • Your default browser opens and navigates to Bing’s Speed Test page; click Start to run the measurement.
  • Record the timestamp, browser used, and whether a VPN or proxy was active if you need to reuse the result for support or escalation.
Critical analysis — weighing convenience against control​
Putting a speed‑test launcher into the network flyout is a pragmatic UX win: it reduces the cognitive and navigational friction that stops many users from checking speeds when something feels wrong. Microsoft’s choice to funnel to a web widget is rational from an engineering and maintenance perspective: update agility, a single code path for multiple products, and minimal OS bloat. That pragmatism has trade‑offs. The feature’s usefulness as evidence in disputes or formal troubleshooting is limited by its web‑backed design. For administrators and power users the lack of provider choice, exportable metadata, and offline capability reduces the tool to a starting point rather than a definitive diagnostic. The ideal middle road would retain the single‑click convenience while giving advanced users enterprise controls and transparency.
Finally, because this is rolling through Insider channels, Microsoft can — and often does — iterate on the UX and controls before public release. Insiders and observers should continue to press for clearer documentation of backend providers and telemetry so that the feature’s operational profile is transparent before it reaches broad consumer or enterprise audiences.
Flags and unverifiable claims​
  • Multiple community reports and press outlets indicate the Bing widget surfaces Speedtest/Ookla infrastructure for measurements; however, Microsoft has not published an authoritative technical statement that definitively confirms the provider in the Taskbar flow. That claim should be treated as plausible but not fully verified.
  • Build numbers and exact wording observed in Insider captures are accurate to community reports, but Insider features can be changed, hidden, or removed server‑side prior to public release. Any single build identifier is therefore provisional.
Microsoft’s decision to add a one‑click path to Bing’s internet speed test from the Windows 11 Taskbar is a smart usability move for everyday troubleshooting: it reduces friction and places a commonly needed diagnostic exactly where users look for connectivity issues. However, the implementation is a web‑backed launcher rather than a native measurement tool, and that design choice carries important implications for accuracy, reproducibility, telemetry, and enterprise control. For casual users and first‑line support it’s a welcome convenience; for regulated environments and formal diagnostics it should be treated as a rapid sanity check that must be corroborated with dedicated tools.
Administrators and power users should update support documentation, retain reproducible testing workflows (Speedtest CLI, iperf3, system logs), and decide whether the Bing endpoint is acceptable on managed devices. Microsoft can preserve the convenience while addressing enterprise needs by adding provider choice, exportable logs, and clearer telemetry documentation before the feature reaches broad release. Until then, the Taskbar speed‑test shortcut is a helpful addition — but not a replacement for the robust diagnostics that IT teams rely on.
Source: TechSpot Microsoft adds Bing internet speed test to Windows 11 preview
Microsoft is quietly testing a one‑click internet speed test in Windows 11 that surfaces a “Perform speed test” launcher in the taskbar’s network menu and Wi‑Fi quick settings — a small UX change that opens Bing’s web speed‑test widget in the default browser rather than running a fully native measurement inside the OS.
Windows desktop with floating speed-test UI on a blue wallpaper, displaying download and ping gauges.Background​
Windows has historically left ad‑hoc throughput checks to third‑party sites and apps — think Ookla’s Speedtest, Fast.com, or dedicated CLI tools like iperf3. That gap created a proliferation of lightweight utilities and browser shortcuts for quick verification. The new taskbar control seen in recent Windows Insider preview builds is designed to remove friction: put a quick diagnostic exactly where users already look when connectivity feels off. Early reports place the control in two places: the right‑click context menu for the network (system tray) icon and as a small button inside the Wi‑Fi Quick Settings flyout. This addition aligns with Microsoft’s recent pattern of surfacing web‑hosted utilities from system UI — leveraging cloud or web services for light diagnostics rather than expanding the OS surface with new measurement subsystems. That trade‑off has obvious engineering advantages but also operational and privacy implications, which deserve careful scrutiny.
What insiders and reporters have found​
Where the control appears​
  • Right‑click the network icon in the system tray and look for a Perform speed test entry in the context menu.
  • Left‑click the network icon to open Wi‑Fi Quick Settings (the compact flyout) and look for a Test internet speed / speedometer button near the Wi‑Fi refresh and other quick actions.
Screenshots and community captures circulated by Windows Insider testers confirm these placements and show a compact, discoverable affordance intended to be visible in the normal troubleshooting flow.
What the control actually does​
  • Selecting the control opens your machine’s default browser and navigates to Bing’s speed‑test widget.
  • The test runs in the browser UI and measures download, upload, and latency (ping) using the web widget’s measurement engine; users start the test manually from the web page.
Multiple write‑ups indicate the web widget used by Bing and the Edge sidebar delegates measurement duties to established speed‑test backends (widely reported to surface Ookla/Speedtest technology under the hood), rather than a Microsoft‑built server farm inside Windows itself. That appears to be the model behind the taskbar shortcut: a funnel into a maintained web tool rather than a local diagnostic binary.
Why Microsoft likely chose a web‑backed launcher​
Putting a web‑backed speed test behind a taskbar launcher is a low‑cost, high‑value UX change. The practical rationale includes:
  • Maintainability: Web tools can be updated independently of OS servicing cycles, avoiding frequent Windows updates for small measurement tweaks.
  • Reusability: Microsoft already maintains a speed‑test widget in Bing and exposes it through Edge; funneling users to that same endpoint reduces duplication of effort.
  • Speed to ship: A shortcut requires only a small UI change inside Windows and can be server‑side gated for Insiders; Microsoft can iterate quickly based on feedback.
These are rational engineering trade‑offs. They enable a consistent cross‑product experience (Windows → browser → Bing widget) while keeping the OS footprint minimal.
Accuracy, reproducibility, and limitations​
For most everyday users the Bing/Edge speed test is perfectly adequate as a quick sanity check: it gives a fast snapshot of throughput and latency. However, for any scenario demanding precise, reproducible, or auditable results (ISP disputes, Service Level Agreement verification, regulated environments), the browser‑based test introduces meaningful limitations.
Key limitations to understand:
  • Browser variability: Different browsers and browser versions implement networking stacks differently, which can affect test throughput and latency. Running the test in Edge vs. Chrome vs. Firefox may produce different results.
  • Server selection and routing: Web widgets typically choose a nearby public test server automatically. That server selection, routing, and load conditions can change between tests — producing variance that matters for forensic comparisons.
  • Lack of exportable metadata: A simple web UI seldom exposes server IDs, raw measurement samples, or a timestamped log suitable for audit trails. Without that metadata, it’s hard to prove a test to a third party. Multiple outlets recommend using dedicated clients (Ookla Speedtest desktop, Speedtest CLI, or iperf3) when provenance matters.
  • Dependency on a working browser path: If network issues prevent the browser from loading external pages (captive portals, DNS failures, corporate blocklists), the taskbar shortcut cannot run — precisely the situation when a local diagnostic might be most useful.
Practical takeaway: treat the taskbar speed test as a rapid triage tool, not a replacement for controlled measurement methods.
Enterprise, privacy, and manageability considerations​
The shift to a browser‑hosted measurement means some control flows out of the OS and into web services and the browser environment. Organizations should note:
  • Telemetry and logging: The test’s network traffic and any telemetry are governed by Bing/Edge web policies, not Windows telemetry channels. Microsoft has not (so far) published a dedicated feature brief detailing what the Bing widget logs when launched via the taskbar shortcut. That gap is significant for privacy‑sensitive or regulated deployments and should be explicitly addressed by Microsoft before organizations adopt the feature as a supported diagnostic tool. Flag: telemetry specifics remain partially unverifiable.
  • Policy enforcement: Managed devices can block access to the external widget via normal web filters, proxy rules, or endpoint policies. IT can also prevent Insider builds from being installed on managed estate, which will limit exposure to preview features. Administrators should assess whether to allow the web test, block it, or provide a sanctioned internal testing endpoint.
  • Data residency and third‑party exposure: Running tests against public test servers implies external network endpoints are involved; sensitive metadata (IP addresses, timestamps, potential query strings) may cross borders or be retained by third parties. For regulated industries, use on‑premise tools instead.
Enterprises that rely on reproducible evidence should continue to standardize on controlled clients and internal endpoints (Speedtest CLI with pinned server IDs, iperf3 against managed endpoints, or network monitoring appliances).
How to use the taskbar speed test (Insider preview guidance)​
If your device is enrolled in the relevant Windows Insider channel and the control is enabled, the flow is simple:
  • Click the network icon in the taskbar (system tray).
  • Either right‑click the network icon and select Perform speed test, or open the Wi‑Fi Quick Settings and click the Test internet speed button.
  • Your default browser opens a new tab with Bing’s speed‑test widget; click Start to run the measurement.
Notes for users:
  • The test will measure download, upload, and ping as a standard web‑based speed test does.
  • If the page fails to load, local diagnostics (netsh wlan show wlanreport, ipconfig /all, ping, tracert) are still the proper next steps.
Alternatives for power users and IT pros​
For reproducible, auditable, or ISP‑facing verification, prefer these tools:
  • Speedtest (Ookla) desktop client or CLI — supports manual server selection, API access, and more consistent measurements across runs.
  • iperf3 — ideal for controlled, point‑to‑point throughput tests inside managed networks.
  • Netsh / netsh wlan show wlanreport — useful for local wireless diagnostics and event logs.
These tools let you collect server IDs, raw samples, timestamps, and logs — all crucial when you need reproducible evidence or to compare results over time.
UX and product design: small change, outsized daily value​
Placing a speed‑test launcher in the network flyout is a pragmatic UX win. Most users already instinctively inspect the network icon when connectivity feels off; surfacing a one‑click path removes friction and helps non‑technical users get objective numbers quickly. For help‑desk teams and consumer support, that predictability is valuable: it reduces the cognitive step of telling users which site or app to open.
That said, the implementation choice reveals Microsoft’s current priorities: favoring discoverability and maintainability over embedded, fully configurable diagnostics. If Microsoft later adds provider choice, exportable logs, or a light native micro‑benchmark option, the feature could evolve into a more broadly useful tool for IT teams. Until then, it will primarily be a convenience for everyday troubleshooting.
Verification, caveats, and what remains provisional​
  • Multiple independent outlets and community captures corroborate the presence of the shortcut in recent Insider builds and the fact that it opens Bing’s web widget.
  • Reported build numbers associated with the sightings include 26220.6682 (Dev lineage) and 26120.6682 (Beta lineage), surfaced in mid‑September Insider previews; treat these numbers as provisional because features in Insider channels can be toggled server‑side or adjusted before public release. Flag: build‑level evidence is community reported and subject to change.
  • The claim that the Bing widget delegates to Ookla/Speedtest infrastructure is widely reported by independent tech outlets, but Microsoft has not released a dedicated technical brief specifying backend providers for the taskbar‑initiated flow; until Microsoft confirms, that integration should be considered likely but not fully verified. Flag: backend provider specifics are not fully confirmed by Microsoft.
Because the feature is in preview at the time of reporting, final behavior, placement, or management options may change before a public roll‑out. Administrators and power users should watch official Windows Insider release notes for formal documentation.
Practical recommendations​
  • Home users: use the new taskbar control as a quick sanity check when an app feels slow or you suspect ISP issues. It is fast and discoverable.
  • Power users and IT pros: continue to rely on dedicated clients and controlled test endpoints for reproducible measurements, and document internal procedures (server IDs, timestamps, logs) for support escalations.
  • Administrators: evaluate Insider ring policies and web filtering/proxy rules to control whether this web‑backed tool is allowed in managed environments. Prepare guidance for support staff about the difference between quick web tests and audited diagnostics.
What to watch next​
Microsoft may:
  • Add provider selection or an option to run a native micro‑benchmark inside Windows (less likely in the short term).
  • Publish a feature brief clarifying telemetry collected when the taskbar control opens Bing’s widget (recommended and necessary for enterprise adoption).
  • Change the UX placement, verbage, or rollout strategy between Insider and general availability — features visible to Insiders are often iterated on before public release.
Monitor official Windows Insider release notes and Microsoft support documentation for definitive answers about telemetry, backend providers, and management controls. Until Microsoft provides explicit documentation, treat community reports and third‑party write‑ups as strong indicators rather than final confirmation.
The new Windows 11 taskbar speed‑test launcher is a tidy, well‑placed convenience: a one‑click path from the network icon straight to Bing’s web speed test that saves users the step of opening a browser and hunting for a site. For everyday troubleshooting — quick validation of whether an ISP or local link is the problem — it’s a welcome addition. However, because the test runs in the browser and relies on web‑hosted backends, it is not a substitute for the reproducible, auditable measurements that enterprises and power users require. Organizations should treat it as a rapid triage tool and retain established, controlled testing workflows for forensic or contractual work. Until Microsoft provides formal documentation on telemetry and backend choices, those areas remain open questions to be resolved before broad enterprise adoption.
Small ergonomics changes like this can deliver outsized day‑to‑day benefits. This one does exactly that: it meets users where they already look, removes friction for a common diagnostic step, and reflects Microsoft’s current engineering preference for web‑hosted, updateable utilities — convenient and pragmatic, but deliberately minimal in scope.
Source: PCWorld Windows 11 is getting a built-in speed test
Microsoft has tucked a one‑click internet speed check into the Windows 11 taskbar — but for now it’s a launcher that opens Bing’s web speed‑test widget rather than a native, in‑OS measurement tool.
Windows desktop showing a browser-based speed test with ~950 Mbps download and ~880 Mbps upload.Background / Overview​
Windows 11’s network menu just got a new convenience: a Perform speed test / Test internet speed control appears in the taskbar’s network (system tray) area and the Wi‑Fi quick‑settings flyout in recent Insider preview builds. Clicking the control launches your default browser and loads Bing’s Speed Test page, where you can run the download, upload and latency measurements. This behavior has been observed in Insider Dev and Beta channel builds and is currently being exercised as an experimental rollout. Microsoft’s Insider release cadence and feature‑flight mechanisms mean the UI may be toggled server‑side and can change before public release. Treat the taskbar shortcut as an Insider‑channel convenience under test rather than a finished, broadly shipped feature.
What exactly Microsoft shipped into Insider builds​
Where you’ll find the new control​
  • Right‑click the network icon (Wi‑Fi or Ethernet) in the taskbar’s notification area and look for Perform speed test in the context menu.
  • Left‑click the network icon to open the Wi‑Fi quick settings flyout; a Test internet speed or similar button appears near other quick actions (Wi‑Fi refresh, airplane mode).
What happens when you click it​
  • Windows opens the machine’s default browser and navigates to the Bing speed‑test widget. The test itself runs in the browser UI; you click Start to measure download, upload and latency. The taskbar control acts as a launcher — not a local measurement engine.
Which Insider builds have the button (observed)​
Reporting and community captures tie the discovery to mid‑September Insider preview flights, notably build families in the 26220 and 26120 series (examples: 26220.6682 on Dev and 26120.6682 on Beta). Microsoft’s Insider blog for these builds documents the rollout cadence; feature availability is controlled and may vary by device and toggles. Use the Insider documentation and your Settings > Windows Update controls to confirm which updates you receive.
Why Microsoft took this approach — the engineering tradeoffs​
Microsoft chose to funnel users to a web‑hosted speed test for pragmatic reasons:
  • Update agility: Web tools can be updated independently from OS servicing cycles, so fixes and UI changes roll out faster than Windows updates.
  • Reuse of infrastructure: Bing’s tools already include a speed test experience that delegates to established backends (notably Speedtest by Ookla). Reusing that avoids building and maintaining global measurement servers inside Windows.
  • Smaller OS footprint: Delegating the heavy lifting to the web reduces local code, maintenance and security surface area inside Windows.
These are sensible engineering tradeoffs for a quick‑triage, consumer‑facing utility. The downside is that the flow inherits the limitations and operational model of browser‑hosted tests.
What this means for accuracy, reproducibility and enterprise use​
Browser vs native clients — measurable differences​
A speed test running in a browser can yield different numbers than a native client because of differences in:
  • network stack and TCP tuning used by the browser,
  • thread scheduling and resource contention,
  • browser extensions or security settings that alter network behavior,
  • default parallelism and connection management implemented by the browser.
That means a single click‑to‑Bing measurement is excellent for quick sanity checks — but it’s not a forensic, reproducible audit for contractual or regulatory disputes.
Backend server selection matters​
Bing’s speed‑test experience has used Speedtest by Ookla infrastructure in the past; multiple independent reports indicate Bing delegates its testing to Ookla’s measurement backend. That influences results because server proximity, load and routing affect throughput and latency. If you need authoritative measurements, you should be explicit about which test server you use and collect raw logs.
Telemetry and privacy considerations​
Because the test runs in the browser against a web provider, normal web telemetry and server‑side logging may apply. Microsoft has not published a task‑specific, OS‑level privacy FAQ for the taskbar shortcut as of the preview reports; administrators should assume web requests to Bing’s hosting and the chosen measurement backend may be logged. For managed environments you’ll want clear guidance about telemetry and whether the feature should be allowed or blocked by policy.
How to try it today (Insider checklist)​
  • Enroll the test device in the Windows Insider Program and choose the Dev or Beta channel as appropriate. Confirm you have the latest Insider preview updates and the toggle for “get the latest features” switched on.
  • Confirm you’re on one of the preview build families that have shown the control (examples reported include 26220.6682 for Dev and 26120.6682 lineage for Beta). Feature availability may vary; the Insider blog and Windows Update will show which build you have installed.
  • Click (or right‑click) the network icon in the taskbar. Look for Perform speed test in the context menu, or Test internet speed inside the Wi‑Fi quick settings.
  • Your default browser opens to Bing’s speed‑test widget — click Start to run the test. Repeat the test multiple times and compare with other tools if you need verification.
If you don’t see the control, it may not have been toggled to your device yet; Insider rollouts often use controlled feature releases. Patience or toggling the “receive the latest features” setting is typically necessary.
Practical testing tips — get better, more reliable results​
  • Prefer wired (Ethernet) for accuracy. Wi‑Fi variability — signal, interference and roaming — will skew results. Use Ethernet if you want to measure ISP performance rather than Wi‑Fi.
  • Kill or pause bandwidth consumers. Stop cloud backups, streaming, large downloads and video conferencing before testing. Close background browser tabs and apps that may consume the link.
  • Repeat the test and use the median. Run 3–5 tests over a short window and use the median throughput to reduce outlier influence.
  • Test from multiple providers/clients. Cross‑check Bing’s test with Ookla’s Speedtest (web or app), Fast.com and an iperf3 test to isolate variables.
  • Record evidence for disputes. If measuring for an ISP complaint, capture timestamps, server IDs, and screenshots; prefer CLI clients that produce JSON logs for forensic purposes.
Better alternatives when you need repeatability or automation​
If you require repeatable, auditable or scheduled measurements, rely on native or command‑line tools rather than a browser widget.
  • Speedtest CLI (Ookla): Official command‑line client; supports server selection, JSON output and scripting. Good for scheduled logging via Task Scheduler or monitoring systems.
  • iperf3: For LAN or router ↔ PC throughput testing, iperf3 runs on two endpoints and measures raw TCP/UDP throughput without public test servers in between — ideal to isolate Wi‑Fi or local network problems.
  • Official Speedtest apps: Speedtest by Ookla has a Windows app available from the Microsoft Store that runs inside Windows and can show results and notifications without switching to a browser.
  • ISP portals and router diagnostics: Some ISPs provide hosted diagnostic pages or router‑side tests that measure to the provider’s edge nodes and can be more relevant in a service‑level discussion.
Example high‑level steps to automate Speedtest CLI logging (conceptual):
  • Install the official Speedtest CLI for Windows.
  • Create a scheduled task to run speedtest.exe --accept-license --format json --server <server_id> and redirect output to a dated JSON file.
  • Store logs centrally or upload to your monitoring solution for trend analysis and SLA verification.
Flag: exact CLI flags and installation steps change over time — consult the vendor docs when implementing. This advice is conceptual and should be verified against the current Speedtest CLI version.
Strengths: why the taskbar shortcut is useful​
  • Immediate discoverability: Placing a speed test where users already look when connectivity seems off removes friction; many non‑technical users will now find a speed check with one click.
  • Reduced support friction: Help desks and support staff can instruct users to click the same taskbar control to gather a quick snapshot before escalating.
  • Low maintenance for Microsoft: The web‑backed model lets Microsoft adjust server endpoints and UI without shipping OS updates. That reduces maintenance overhead while delivering a consistent consumer experience.
Risks and limitations — what to watch out for​
  • Not a native diagnostic: If the network problem prevents the browser from loading pages, the taskbar button will not help. It requires a functioning HTTP/HTTPS path to the test service.
  • Browser‑dependent variability: Results will vary across browsers and system loads; comparisons between browser tests and native clients may not be apples‑to‑apples.
  • Perception of vendor steering: Routing users to Bing’s tool may be perceived as favoritism or product steering; enterprises might prefer neutrality and the ability to pick their own test backends.
  • Telemetry and auditability: Web providers may log tests; without exportable raw metadata (server IDs, timestamps, connection tuples), the test lacks audit trails needed in some professional contexts.
What Microsoft could (and should) add​
If Microsoft wants to make a taskbar speed test genuinely useful for power users and enterprise admins, the following would make a big difference:
  • Add an in‑OS native test mode or an option to run the test via a local built‑in tool that can export JSON/CSV logs. This would remove browser variability and allow offline microbenchmarks.
  • Provide provider choice and server selection or at least document the backend(s) used by the Bing tool and how servers are chosen.
  • Implement exportable logs (server IDs, latency samples, timestamps, thread counts) for reproducibility and dispute resolution.
  • Offer an MDM/GPO policy to control or deny the feature for managed devices, and an auditable telemetry opt‑out for enterprise environments.
These additions would preserve the convenience for ordinary users while addressing the measurement and manageability requirements of professionals.
How to interpret numbers you see in the Bing test​
  • Download / Upload (Mbps): Peak throughput measured during the test window. Single runs may reflect transient conditions; prefer medians or time‑series for conclusions.
  • Latency (ms): Round‑trip time to the selected server. High ping with low throughput can point to different issues (routing vs saturated link).
  • Server selection: Results depend heavily on which test server was used; closer, less loaded servers usually show better throughput and lower latency. Verify server ID when comparing tests.
Verdict — a welcome convenience, not a replacement for professional diagnostics​
The Windows 11 taskbar speed‑test shortcut is a smart, ergonomically sound convenience that lowers the barrier for average users to run a quick connectivity check. It belongs in the “small but useful” category: discoverable, low‑friction and sufficient for fast triage.
At the same time, the present implementation — a browser launch that leverages Bing’s web widget (which in turn delegates to established backends like Ookla) — means the control inherits browser variability, backend selection choices and the limitations of web telemetry. For repeatable, auditable, or enterprise‑grade testing, native clients, CLI tools and controlled test endpoints remain the right tools. Microsoft’s current approach makes sense as a first pass: it gives millions of users an easier way to get a quick status check while the company evaluates demand and design options in Insider rings. Whether Microsoft extends this into a native, exportable, and manageable diagnostic will determine the feature’s long‑term value to IT professionals and regulated industries. Until then, use the taskbar button for quick sanity checks — and use CLI/native tools when you need precision, logs and repeatability.
Quick reference — what to do right now​
  • If you’re curious, join the Windows Insider Program and check whether your device received build 26220.6682 (Dev) or the appropriate Beta lineage build.
  • Use the taskbar control for fast checks; treat it as a sanity check, not a formal measurement.
  • For disputes or enterprise monitoring, use Speedtest CLI, iperf3 or vendor‑backed portal tests that provide auditable logs.
The Windows taskbar speed test is a subtle ergonomics win with honest limitations. It simplifies discovery and basic troubleshooting today, and it could evolve into something far more powerful if Microsoft adds native measurement capabilities, exportable logs, and enterprise controls in future updates.
Source: ZDNET Windows 11 lets you run a network speed test right from the taskbar now - how to try it
Microsoft has quietly added a one‑click internet speed test shortcut to the Windows 11 taskbar in recent Insider preview builds, placing a “Perform speed test” control in both the network system‑tray context menu and the Wi‑Fi quick‑settings flyout — and that control opens Bing’s speed‑test tool in your default browser rather than running a native, in‑OS measurement.
Desktop shows Bing speed test with a large speedometer and floating widgets.Background​
Windows has long offered multiple ways to diagnose and troubleshoot network connections: from the old Network Troubleshooter to the Settings > Network & internet pages and built‑in diagnostic logs. Over the past few years, Microsoft has shifted toward surfacing simpler, web‑backed utilities directly from system UI so they can be updated independently of OS servicing. The new taskbar speed‑test shortcut continues that trend by pointing users to a web tool (Bing’s speed test) instead of embedding a full measurement engine inside the OS. This change first surfaced in Insider previews in mid‑September, when prominent Windows insiders captured screenshots showing the new control in the network flyout and context menu. Early reporting indicates the option is present in current Canary, Dev and Beta preview builds used by testers, although the exact channel coverage varies by report and remains subject to change as Microsoft iterates.
What changed in the taskbar and quick settings​
Microsoft placed the shortcut in two highly discoverable locations:
  • The right‑click context menu on the network icon in the system tray — alongside options such as Network troubleshooter and Network settings.
  • Inside the Wi‑Fi quick‑settings flyout (left‑click the network icon) as a small Test internet speed button near the Wi‑Fi refresh and quick actions.
Placing the control where users already go to inspect connectivity is deliberate: it reduces friction for basic diagnostics and makes speed tests visible to non‑technical users who otherwise might not know which third‑party site to open. The UI itself appears to be a launcher rather than a new pane or embedded widget.
How it behaves when you click​
Clicking either the context‑menu entry or the quick‑settings button launches your default web browser and opens the Bing speed‑test page. The test itself runs inside the browser’s tab or window — meaning the system is relying on a web‑hosted measurement tool rather than performing the network test fully within a privileged OS subsystem. This makes the shortcut quick and low‑effort but also dependent on the browser and the HTTP(S) path to Microsoft’s test servers.
Technical implications and verification​
Is the test “native” to Windows 11?​
No — the current implementation is a web launcher. Community captures and reporting show the button opens Bing’s internet speed test in your default browser rather than executing a local measurement engine inside Windows. This means Windows is acting as a convenient discoverability layer for an existing web tool, not as an independent diagnostic framework.
Which Insider builds include the control?​
Public reporting ties the appearance of the feature to recent Insider channel builds in mid‑September. Some outlets and community posts identified build families such as 26220.6682 and 26120.6682 (KB5065782) as examples where testers saw the change, though exact build numbers and channel designations can fluctuate as Microsoft merges fixes between channels. These build numbers were reported by several outlets covering the Insider ring captures. Treat those numbers as indicative of the timeframe and preview families rather than a final release tag.
Which web service runs the test?​
Bing hosts the speed‑test tool that the shortcut loads. Microsoft’s Bing tools page includes a speed‑test widget, and reporting confirms Windows links to that tool. Historically, Bing’s speed test experience has delegated to Speedtest by Ookla (the industry’s widely used speed‑test backend), and Bing integrated native support for Ookla’s test engine in prior years — a fact worth noting because it affects how results are gathered and which servers are used. In short: Windows opens Bing’s tool; Bing’s test layer has in past implementations used Ookla’s infrastructure to run measurements.
Why Microsoft likely chose a web‑backed approach​
Embedding a full measurement engine inside Windows would mean taking on server selection, global test infrastructure, and frequent maintenance to keep the tool accurate and fair. Using a web‑hosted tool allows Microsoft to:
  • Update the test and server logic independently of OS servicing cycles.
  • Reuse one test endpoint across multiple products (Bing, Edge, system UI) for consistent results.
  • Avoid duplicating engineering effort when reliable third‑party test engines already exist.
This design choice is pragmatic: it accelerates delivery of a user‑facing convenience without the long tail of maintaining measurement servers and server selection logic in the OS.
Benefits for everyday users​
  • Immediate discoverability: the test is now where most users go when they notice connectivity issues, reducing the need to remember specific websites.
  • Low friction: one or two clicks launches a test in the browser, no app install required.
  • Consistency: using Bing’s tool (which historically integrates established backends) means users will generally get reliable baseline numbers comparable to other common web tests.
Benefits are particularly pronounced for casual users and help‑desk scenarios where a quick, visible measurement can confirm whether an issue is local or ISP‑related before deeper troubleshooting begins.
Limitations and operational risks​
Although convenient, the web‑backed approach introduces important caveats:
  • Dependence on the browser: if the default browser is misconfigured, blocked by policy, or affected by extensions, the shortcut may fail or produce misleading results.
  • Reliance on HTTP access: diagnostic value collapses if the network error itself blocks HTTP(S) — a captive portal, DNS failure, or proxy misconfiguration can stop the test from even loading.
  • Telemetry and privacy: launching a web test sends metadata to the test provider (server selection, client IP ranges, potentially ISP tags); organizations with strict egress controls will need to evaluate whether this fits policy.
  • Regional availability and blocks: a web service can be geo‑restricted or subject to ISP/authority blocks, making the shortcut unusable in some regions.
  • Perception vs. precision: browser‑based tests and native measurement engines may select different test servers or concurrency models, producing results that diverge from what an in‑appliance or managed test would show.
Enterprises and sensitive environments should treat this as a helpful convenience for quick checks, not a logging‑grade diagnostic for SLA verification or forensic analysis.
Practical guidance: how to use the shortcut responsibly​
  • If you see the option: right‑click the network/system‑tray icon and select Perform speed test, or open the Wi‑Fi quick‑settings flyout and click Test internet speed.
  • Confirm the browser that opens is truly your default browser and that its privacy settings and extensions won’t interfere with test accuracy.
  • Run multiple tests (3–5) over a period of minutes to average out short‑term variance.
  • If you need higher‑precision or persistent measurement (for example, to dispute an ISP SLA), follow up with a native Speedtest app or a managed monitoring service that supports scheduled tests and server selection.
  • If the shortcut fails to load, try manually navigating to another website to confirm general HTTP access before assuming the issue is the upstream link.
What this means for power users, IT admins and enthusiasts​
Power users should understand the distinction between a convenience launcher and a full diagnostic tool. The taskbar shortcut is perfect for a quick sanity check, but it lacks the control and telemetry granularity that many power users require.
IT administrators have three immediate takeaways:
  • Policy controls: ensure group policy and firewall rules account for the new outbound behavior if your environment blocks or filters web testing tools.
  • Visibility and trust: consider whether remote help‑desk procedures should instruct users to use a web test or a managed internal test host to maintain consistent server choice.
  • Communication: update documentation and user KBs to explain what the shortcut does and how to interpret results, especially when diagnostic workflows expect different metrics from internal monitoring.
Rollout prospects and what to watch​
This function is currently visible in Insider previews, meaning it could change or vanish before reaching general release. Several scenarios are plausible:
  • Microsoft keeps the web‑backed shortcut as a low‑maintenance convenience and ships it broadly.
  • Feedback from enterprise customers or privacy advocates prompts a toggle or policy setting to disable/redirect the shortcut.
  • Microsoft later implements a native in‑OS measurement engine for environments that need offline diagnostics or telemetry‑free results.
Watch for announcements tied to the Windows 11 servicing cadence (patch or feature updates) and for the feature’s appearance in stable builds. Insider channel behavior is a leading indicator but not a guarantee.
Verification notes and disputed points​
  • Multiple independent outlets and Insider captures confirm the shortcut’s presence and behavior (opening the Bing speed‑test page). Major reporters include Windows Central, Tom’s Hardware and TechSpot, among others. Those sources corroborate the basic flow and UI placements.
  • Build numbers and channel coverage vary slightly across reports. Some writeups cite specific preview build numbers (e.g., 26220.6682 and 26120.6682/K B5065782) while community posts mention Canary/Dev/Beta collectively. Treat build numbers as approximate markers of the Insider timeframe; exact distribution will depend on Microsoft’s internal merges and the date you check. This is an area where the public information is changing quickly and should be re‑verified if you rely on a particular build ID.
  • Mezha.Media and other outlets reported the same behavioral detail and noted the browser redirection to Bing; however, Mezha also listed Canary explicitly. The broader reporting pattern tends to emphasize Dev and Beta builds, with Canary sometimes included by region or test cohort. Because channel coverage can be inconsistent between outlets and test machines, lab verification is recommended before citing channel scope definitively. Flag: Canary inclusion is plausible but not uniformly reported; consider it unverified until Microsoft publishes the rollout channels.
  • The historic connection between Bing’s speed‑test widget and Speedtest by Ookla has been documented previously, and Bing’s tools page currently hosts a speed‑test page. That corroboration supports the assertion that users may be routed to an Ookla‑backed test via Bing’s UI — but the exact provider for a given Bing test instance can be updated by Microsoft. Flag: provider mappings are subject to change and should be re‑checked if your workflow depends on a specific backend.
Security and privacy checklist for administrators​
  • Audit outbound rules and proxies to ensure the Bing speed‑test endpoint is allowed only if you accept external test telemetry.
  • Consider a controlled internal test host for managed diagnostics if you must avoid third‑party endpoints.
  • Educate help‑desk staff on interpreting web test results and on differences between browser‑launched tests and managed monitoring.
  • If you permit the shortcut for users, document the expected browser behavior and any extensions that should be disabled temporarily (ad‑blockers, privacy extensions) to avoid skewed results.
The UX tradeoff: convenience vs control​
The taskbar shortcut is a classic UX tradeoff: it reduces friction and helps non‑technical users get a useful data point quickly, but it pushes control and telemetry outward to a web provider. For most home users the convenience wins: it’s far easier to click a visible button than to hunt for a reputable speed‑test site. For managed or sensitive scenarios, it’s less clear‑cut — and organizations will need to decide whether to allow, discourage, or replace the shortcut with internal tools.
The new Windows 11 taskbar speed‑test shortcut is a practical usability improvement that makes checking internet performance easier for everyday users. It is, however, a launcher to Bing’s web‑based tool rather than a native in‑OS measurement engine — a choice that favors rapid deployment and maintainability but introduces dependencies on the browser, external servers, and web connectivity.
Users can treat the control as a fast sanity check and follow up with more controlled tests for high‑precision needs. Administrators should review egress policies and help‑desk procedures to accommodate the new flow or to provide alternatives where required. As with all Insider‑originated features, expect iteration: Microsoft may adjust the behavior, add policies, or develop a native alternative depending on feedback and enterprise needs.
Source: Mezha.Media The Windows 11 taskbar now has a function to check your internet speed
Microsoft has quietly added a one‑click internet speed‑test launcher to Windows 11 Insider preview builds — a small, highly discoverable convenience that opens Bing’s web‑based speed‑test widget from the Taskbar’s network menu rather than running a native diagnostic inside the OS.
Windows 11 desktop with a Speedtest by Ookla window and a network settings popup.Background​
Windows 11 continues to receive incremental UX and diagnostic tweaks through Insider channels, and the newest convenience addition is a speed‑test control placed where users already check connectivity: the network/system tray icon and the Wi‑Fi Quick Settings flyout. Early previews show a Perform speed test (or Test internet speed) entry in the right‑click context menu and a small button in the Wi‑Fi panel. Clicking the control launches the default browser and navigates to Bing’s speed‑test experience, where the measurement runs. This decision follows Microsoft’s recent pattern of surfacing web‑hosted tools from system UI rather than bundling these utilities as heavyweight native subsystems. The Bing speed test itself has been part of Microsoft’s search and tools ecosystem for years and, since late 2023, leverages Speedtest by Ookla as its measurement backend — meaning the visible UI is Bing’s, but the underlying test infrastructure is supplied by an established third‑party engine.
What has been found in Insider builds​
Where the UI appears​
  • Right‑click the network (system tray) icon and look for Perform speed test in the context menu.
  • Left‑click the network icon to open the Wi‑Fi Quick Settings flyout; a Test internet speed button sits near the Wi‑Fi refresh and other quick actions.
Screenshots shared by preview‑build sleuths show deliberate placement: the control sits exactly where users already go when connectivity feels wrong, maximizing discoverability for non‑technical users and support staff.
How the control behaves​
Clicking either UI element does not start a local OS test. Instead:
  • Windows opens the system’s default browser.
  • The browser navigates to Bing’s speed‑test widget.
  • The user manually starts the test from the web UI and sees download/upload/latency results.
That flow makes the Taskbar item a launcher for a web service — convenient, low‑friction, and trivially maintainable by Microsoft — but not a substitute for a reproducible, auditable native measurement engine.
Why Microsoft likely implemented it this way​
Practical engineering tradeoffs​
  • Low maintenance: A web endpoint can be updated independently of OS servicing cycles. Microsoft can iterate the test UI and backend without shipping a cumulative update.
  • Reusability: The same Bing/Edge tool can be reused across products and surfaces. That reduces duplicated engineering work.
  • Global infrastructure avoidance: Running accurate speed tests requires geographic server selection, hosting test endpoints worldwide, and maintaining measurement logic. Delegating this to a web service (and to a third‑party engine like Ookla) avoids building and operating that global stack inside Windows.
UX benefits​
Placing a speed‑test launcher exactly where users inspect signal strength and adapter selection reduces friction. For the majority of home users who simply want a quick sanity check — “Is my ISP performing?” — a one‑click route to a speed test is a clear win.
What this is not: limitations and practical implications​
Not a native diagnostic engine​
Because the test runs in the browser, results are subject to browser context, network path, DNS and HTTP availability, and the test provider’s server selection. If DNS is broken or a captive portal prevents loading Bing, the shortcut cannot perform a measurement — precisely the scenarios where a native offline diagnostic might still help.
Accuracy and reproducibility concerns​
  • Browser variability: Different browsers and extensions can affect how web‑based tests behave, introducing variability not present in native clients.
  • Server selection: Web widgets commonly delegate server selection to the measurement backend. Power users and IT pros often need control over which test server is used and the ability to record server IDs and timestamps for disputes with ISPs. The current launcher does not expose that level of control.
  • Telemetry and privacy: Running a speed test via Bing surfaces metadata to Microsoft and the chosen backend. Organizations with stringent privacy or telemetry rules will want clarity on what is sent and how it can be disabled or controlled centrally. This behavior is not yet documented in preview materials.
Enterprise management & auditing​
For IT teams that need audit trails (CSV/JSON exports, server IDs, reproducible test parameters), the Taskbar shortcut is insufficient today. Until Microsoft introduces provider choice, exportable metadata, or management controls, the new control remains a consumer‑grade convenience, not an enterprise diagnostic tool.
Verification and provenance of the claims​
Multiple independent outlets and community captures corroborate the new Taskbar launcher appearing in mid‑September Insider flights, with mentions of builds in the 26220.6682 and 26120.6682 families (KB5065782) as examples where testers observed the feature. Those build numbers are provisional and can change; Insider features are often gated server‑side and may be altered before public release. Treat the build references as indicative rather than definitive. Bing’s migration to use Speedtest by Ookla within the search tools ecosystem is public and well documented — Microsoft integrated Ookla’s Speedtest into Bing’s tools around late 2023 — which explains why the Taskbar launcher funnels users into a measurement experience powered behind the scenes by an established third‑party engine.
Critical analysis: strengths, risks, and unanswered questions​
Strengths​
  • Discoverability: The Taskbar is the natural place to check connectivity. The placement reduces support friction and helps less technical users get objective numbers quickly.
  • Speed to ship and iterate: Web‑backed tools allow rapid UI/backend changes without OS patches. Microsoft can update server endpoints or measurement heuristics server‑side.
  • Consistent user journey: By funneling users to Bing, Microsoft keeps the same diagnostic UI across search, Edge, and now system shortcuts, which lowers cognitive load for users who have seen the Bing speed test before.
Risks and downsides​
  • Perception of vendor lock‑in / promotion: Routing a core troubleshooting action to Bing inside the OS can be perceived as product promotion rather than a neutral diagnostic capability. Some commentary already frames the control as a subtle way to surface Bing. That perception matters for user trust.
  • Limited value for professionals: Without exportable logs, server selection, or offline micro‑benchmarks, the shortcut is useless for forensic analysis, SLA disputes, or regulated environments.
  • Security and privacy tradeoffs: A web test exposes metadata to Microsoft and the backend provider. Organizations will want precise documentation of what data is collected and whether the feature can be disabled via group policy or MDM. That documentation does not yet appear in preview release notes.
Unanswered questions Microsoft should clarify​
  • Will IT admins be able to disable or replace the shortcut via policy?
  • Will Microsoft offer an official native speed‑test client or an exportable diagnostic mode for enterprise telemetry and auditing?
  • Which backend providers are used in all regions, and how is server selection performed (e.g., proximity, latency, custom peering)?
These items are critical for the feature’s usefulness outside straightforward consumer triage.
Practical guidance for users and IT professionals​
For casual users​
  • Use the Taskbar shortcut for a fast sanity check: it tells you whether download and upload throughput look roughly in line with expectations. For most home troubleshooting, that is sufficient.
For power users and IT pros​
  • Treat the Taskbar launcher as a convenience, not definitive evidence.
  • For reproducible or auditable testing, run dedicated clients:
  • Speedtest by Ookla desktop app (or the web UI with explicit server selection).
  • iperf3 for controlled throughput testing between endpoints you manage.
  • Router‑level diagnostics and SNMP/counters for sustained throughput measurements.
  • When preparing evidence for an ISP, capture timestamps, server IDs, test tool versions, and raw logs. The Taskbar test lacks those export features.
For system administrators​
  • Monitor Insider release notes and Microsoft Docs for policy controls. At preview stage, feature flags for OS UI elements are often implemented server‑side; Microsoft typically adds policies later if an enterprise need exists. Assume you will want the ability to block or audit this feature across managed devices.
Alternatives and complementary tools​
  • Speedtest (Ookla) — The de facto public measurement engine with apps and web UI; allows server selection and historical results.
  • Fast.com — Lightweight, simple, consumer‑oriented by Netflix; good for quick checks but lacks export/audit features.
  • iperf3 — Command‑line, server/client model ideal for controlled lab and enterprise environments.
  • Router/ISP diagnostic pages — Useful for measuring link speed and session errors from the network edge.
  • Third‑party taskbar meters (NetSpeedMonitor, TrafficMonitor) — Provide continuous throughput display rather than ad hoc tests.
Each tool serves a different purpose; combining them yields the best diagnostic coverage.
How this fits into Microsoft’s broader strategy​
The Taskbar speed‑test launcher is emblematic of Microsoft’s choice to surface web‑backed utilities in system UI rather than embedding every consumer utility as native functionality. That strategy prioritizes rapid iteration and lower OS footprint at the cost of some control and reproducibility. It mirrors other moves — Edge/Bing tools, in‑UI links to web utilities, and cloud‑delivered experiences — and suggests a roadmap where the OS is a hub for web services rather than a monolithic feature set.
That design philosophy can accelerate feature rollout and keep the OS agile, but it raises governance questions for enterprise customers and scrutiny about whether core diagnostic workflows should remain platform‑native.
Recommended improvements Microsoft should consider​
  • Add an option for a native mode that runs a local micro‑benchmark and records server ID, timestamp, and interface metadata for export. This would bridge the gap between convenience and auditability.
  • Provide explicit group policy and MDM controls to disable or redirect the Taskbar launcher to an internal corporate tool.
  • Surface a simple “what’s collected” panel showing telemetry and data shared with Bing/third‑party providers before the test runs. Transparency reduces privacy concerns and builds trust.
  • Offer provider selection or an enterprise backend endpoint option for organizations that operate their own test servers. This would make the feature genuinely useful in managed networks.
What to watch next​
  • Whether Microsoft ships the feature widely or changes its behavior based on Insider feedback. Features in Dev/ Beta channels can be tweaked, rolled back, or enhanced before reaching general availability.
  • Documentation from Microsoft clarifying telemetry and administrative controls. Until Microsoft publishes these details, evaluate the Taskbar control as a consumer convenience only.
  • Any move from Microsoft to add native measurement capabilities or a local diagnostic mode that complements the web widget. That would be the logical evolution if enterprise demand is high.
The Taskbar speed‑test launcher is a textbook example of a pragmatic UX improvement: small, focused, and placed where it will help people the most. For everyday users it removes friction — no URL memorization, no third‑party apps, one click to a result. For IT professionals and power users, however, the decision to surface a web‑based test rather than a native, auditable diagnostic introduces limitations around reproducibility, telemetry, and control.
Microsoft’s implementation choice trades implementation complexity for agility. If the company follows through with enterprise controls, data export, and optional native measurements, the Taskbar launcher could mature into a genuinely useful cross‑audience tool. Until that happens, it should be treated as a rapid sanity check — a useful first step in troubleshooting, not the final word when accuracy, evidence, or compliance matters.
Microsoft is quietly surfacing a one‑click internet speed test right in the Windows 11 taskbar — a tiny but notable convenience that opens Bing’s speed‑test widget from the network icon’s context menu and Wi‑Fi quick settings in current Insider preview builds. This change, first observed in mid‑September Insider flights, makes it trivial for everyday users to check download, upload, and latency numbers without remembering a URL or installing an external app — but it also raises technical and administrative questions about measurement accuracy, telemetry, and enterprise suitability.
A Windows desktop screen shows a Bing speed test with download 550 Mbps, upload 320 Mbps, and 15 ms ping.Background​
Why this matters now​
Windows has long relied on third‑party tools and websites for ad‑hoc speed checks — Speedtest by Ookla, Fast.com, and standalone utilities are the go‑to options. Putting a speed‑test launcher inside the taskbar changes discoverability: users already open the network flyout when connectivity feels wrong, so placing a test button there reduces friction for simple triage. Multiple independent reports and Insider captures show the feature is appearing in Dev and Beta preview builds in September 2025, tied to checkpoint updates identified by build families 26220.6682 (Dev) and the 26120.* Beta lineage (KB5065782).
What Microsoft has published​
Microsoft’s Insider release cadence and recent Dev/Beta builds confirm the cadence and mechanism through which features like this are tested and rolled out; the Dev channel announcement for Build 26220.6682 (KB5065782) documents the overall flight and feature gating approach, even if the taskbar speed test isn’t called out line‑by‑line in the blog post. That enables Microsoft to toggle who sees the feature while it collects feedback.
What the new taskbar speed test actually does​
Two places you’ll see it​
  • Right‑click the network (system tray) icon: a new Perform speed test (or similarly labeled) entry appears in the context menu.
  • Inside the Wi‑Fi quick settings flyout: a small Test internet speed button sits near the refresh/quick‑action area.
Screenshots and community reports confirm both placements, which are deliberate UX choices to maximize discoverability where users already go to check connectivity.
How it runs​
  • Selecting the taskbar action does not start a native, in‑OS measurement engine. Instead, Windows opens your system’s default browser and navigates to Bing’s internet speed test page, where the usual download, upload, and ping measurements are available. In other words, the taskbar control is a launcher for a web‑hosted speed test rather than an internal diagnostic tool.
Likely backend and implementation tradeoffs​
Public reporting and technical analysis indicate that Bing’s speed‑test widget has, in the past, leveraged third‑party test engines (notably Speedtest by Ookla) for measurement infrastructure. This means the visible Bing UI may present results while delegating server selection and throughput probes to an established provider. That setup is pragmatic: Microsoft avoids shipping global test servers and keeps the OS footprint small, while maintaining an updateable web surface. However, provider mappings and backend configurations are subject to change, and Microsoft has not published a formal, machine‑readable policy that guarantees which backend will be used for every region or build. Treat the provider claim as widely reported and probable but not immutable.
Strengths: what this brings to Windows users​
  • Instant discoverability: A speed check is now one or two clicks away from the exact UI where people already go to inspect networks. That reduces support friction for front‑line troubleshooting.
  • Low maintenance for Microsoft: By funneling to a web tool (Bing), Microsoft can update UI and measurement logic without pushing OS cumulative updates.
  • Consistent consumer experience: The Bing widget is already accessible via search and Edge sidebar shortcuts; the taskbar launcher reuses a familiar experience that many users already recognize.
For most home users and basic help‑desk triage, this is a practical usability win: a single, visible place to capture a quick throughput snapshot when an app is slow or streaming stutters.
Limits and risks: why this is not a substitute for professional diagnostics​
Browser dependence​
The test requires a working browser path to Bing’s tools. If the problem prevents the browser from loading the page (DNS outage, captive portal, HTTP path disruption), the shortcut will not help. This is an operational dependency that any web‑backed tool must accept.
Measurement variability​
Browser‑based tests differ from native clients in measurable ways:
  • Browser stacks introduce variability (different networking stacks, extensions, or proxy settings can affect throughput).
  • Server selection matters: test results depend heavily on which server the widget chooses; different servers yield different latencies and throughput.
  • VPNs, corporate proxies, content filtering, or QoS rules can skew browser results compared with a native CLI client or iperf3 test. Independent comparisons have shown small but meaningful differences between embedded browser tests and native Speedtest clients. For reproducible, auditable testing (ISP disputes, SLA verification), use dedicated clients or controlled endpoints.
Telemetry and data egress​
Because the test delegates to a web service, it necessarily involves outbound connections to external servers and may send telemetry or identifying metadata to those endpoints. Microsoft has not published a public, per‑feature telemetry breakdown for the taskbar control as of the latest Insider notes; administrators concerned with data exfiltration or compliance should assume the usual web‑based telemetry model applies and evaluate accordingly. For managed environments, consider blocking or auditing the specific Bing speed‑test endpoints until you validate behavior.
Enterprise control and policy​
No explicit group policy or MDM setting was documented in the public Insider notes to toggle or disable this specific taskbar action at the time of reporting. That means organizations should plan to:
  • Test the behavior in pilot rings.
  • Update help‑desk scripts and documentation.
  • If necessary, implement network‑level blocking or create an internal support tool that supplants the browser‑based test.
Practical guidance: how to use the shortcut and when to use alternatives​
Quick checklist for casual use​
  • Click the Wi‑Fi/network icon in the taskbar.
  • Choose Perform speed test or press the small Test internet speed button in the flyout.
  • Your default browser opens to Bing’s speed test; click Start to run the test and view Download, Upload, and Ping results.
When you should rely on other tools​
  • Supplier disputes or SLA claims: use vendor clients (Speedtest CLI), iperf3, or ISP‑provided test pages that produce server IDs, timestamps, and logs.
  • Controlled internal measurements: use iperf3 with a known endpoint inside your test network to measure raw throughput without external variables.
  • Audit/logging requirements: use CLI utilities that can output CSV/JSON logs for archiving and evidence.
Suggested alternatives:
  • Speedtest by Ookla (desktop app or CLI) for reproducible server selection.
  • Fast.com for a very simple downstream‑only check.
  • iperf3 for point‑to‑point controlled testing.
This new Windows shortcut is best treated as a sanity check — fast and helpful for everyday triage, but not the final word for formal diagnostics.
Security, privacy, and admin considerations​
What IT admins should review now​
  • Egress rules: Ensure firewalls, proxies, and endpoint protections either allow the Bing speed‑test endpoints (if you accept external telemetry) or block them if internal policy forbids such tests.
  • Help‑desk processes: Update troubleshooting guides to explain the shortcut and to instruct users on when to escalate to CLI/native tests.
  • Group policy / MDM: Monitor Microsoft’s enterprise documentation and the Insider release notes for any forthcoming management controls; pilot the update in a controlled ring before broad deployment.
Privacy checklist​
  • Assume the test exchanges metadata with the server operator (ISP detection, test server ID, IP address).
  • If privacy tools or extensions are in use, advise users to disable them temporarily for the test to avoid false negatives.
  • For privacy‑sensitive environments, prefer internal measurement tools that don’t send data to third‑party endpoints.
What Microsoft could do next (reasonable improvements to watch for)​
If Microsoft intends to make this feature more useful for power users and enterprise customers, sensible enhancements would include:
  • Provider choice: Allow users or admins to select preferred speed‑test providers (Bing, Ookla, Fast.com, ISP page).
  • Exportable logs: Offer an option to export test metadata (server ID, timestamp, RTT, throughput) as CSV/JSON for audits.
  • Local microbenchmarks: Add an optional native microbenchmark that runs in the OS for offline or captive‑portal scenarios.
  • Management controls: Expose Group Policy/MDM options to enable/disable the taskbar control and to whitelist/blacklist outgoing test endpoints.
Those additions would preserve the convenience while addressing the reproducibility and governance issues that professionals care about. Early reporting suggests Microsoft is treating this as an ergonomics experiment; how it evolves will depend on Insider feedback and enterprise telemetry.
Cross‑checking the key claims (verification)​
  • The taskbar speed‑test shortcut has been observed in Insider preview builds and reported by mainstream outlets; community evidence ties it to build families 26220.6682 (Dev) and 26120.* Beta lineage, which were released to Insiders in mid‑September 2025. Microsoft’s Insider blog confirms the Dev channel checkpoint (Build 26220.6682, KB5065782) and the enablement package model used for rolling features.
  • The shortcut opens Bing’s speed test in the default browser rather than running a native OS test. This behavior is corroborated by multiple independent outlets and by the Bing Tools speedtest page itself.
  • Reporting that Bing’s embedded speed test uses Speedtest by Ookla as its backend is widely documented and has been in place since Microsoft integrated Ookla’s test into Bing in prior years; however, the exact provider and mapping for every region can change, and Microsoft hasn’t made a binding public guarantee that the taskbar‑launched test will always use the same backend. Treat the Ookla link as well documented but subject to change.
These cross‑checks use Microsoft’s own Insider releases plus independent reporting from multiple outlets and community captures to verify the load‑bearing points about what the feature is, where it shows up, and how it behaves.
Bottom line​
The Windows 11 taskbar speed‑test button is a pragmatic UX improvement: it places a useful diagnostic where users already look and removes friction for quick triage. For casual users and first‑line support, it’s a welcome timesaver. For professionals, enterprises, and anyone needing highly reproducible or auditable measurements, it remains a convenience — not a substitute for dedicated tools. Administrators should pilot the change, review outbound rules and telemetry expectations, and update support documentation accordingly. Microsoft’s approach prioritizes discoverability and maintainability; whether they broaden control, exportability, and provider choice before public rollout will determine the feature’s long‑term utility for power users and regulated environments.
Conclusion: a small button can matter. The new Windows 11 taskbar speed test turns a common, fiddly troubleshooting habit into an immediate action — and it gives Microsoft an opportunity to refine how diagnostic utilities are surfaced in the OS. Users should enjoy the convenience, and IT pros should treat it as one more tool in their toolbox rather than the final authority.
Source: extremetech.com Windows 11 Users Won’t Have to Google 'Internet Speed Test' Anymore
Microsoft has quietly added a one‑click way to check your internet connection from the Windows 11 taskbar: a new “Perform speed test” shortcut in the network menu and Wi‑Fi quick settings that launches Bing’s speed‑test widget in your default browser, giving users a fast, discoverable sanity check for download, upload and latency numbers.
Windows 11 desktop featuring a Bing Speed Test window with download, upload, and ping gauges over a blue abstract wallpaper.Background / Overview​
Microsoft’s recent Insider preview builds have continued a trend: instead of embedding every small utility inside the operating system, Windows 11 is increasingly surfacing web‑backed tools directly from system UI. The new Taskbar shortcut appears in two places — the right‑click context menu for the network (system tray) icon and as a small button in the Wi‑Fi quick‑settings flyout — and when invoked it opens the Bing Speed Test page in the default browser so the test runs from the web widget. This convenience is rolling out behind Insider channels (Dev and Beta) as Microsoft experiments with ergonomics and troubleshooting flows. Early reports tie visibility to specific preview build families, which indicates the feature is still under evaluation and could change before broader release.
Where you’ll actually find the button​
Short, scannable locations make the feature easy to discover:
  • Right‑click the network icon in the taskbar notification area (system tray) and look for a Perform speed test entry in the context menu.
  • Left‑click the network icon to open the Wi‑Fi quick‑settings flyout; a Test internet speed or similar button sits near the Wi‑Fi refresh and other quick actions.
Both controls do the same thing: they act as a launcher that opens your default browser and navigates to Bing’s speed‑test widget. Because the test runs in the browser, the measurement depends on web infrastructure, not a native Windows measurement engine.
How the shortcut works — step‑by‑step​
  • Click or right‑click the network icon in the taskbar.
  • Select Perform speed test from the context menu or tap the Test internet speed tile in the Wi‑Fi flyout.
  • Windows opens the default web browser and loads Bing’s Speed Test page.
  • Click Start in the Bing widget to run download, upload and latency measurements.
  • Review the results and, if necessary, re‑run or cross‑check with another test provider.
This launcher model is deliberately minimal: it reduces friction for the average user who needs a quick check, but it’s not a full replacement for repeatable, auditable diagnostics that enterprises or power users may require.
What the test measures (and what it doesn’t)​
  • The Bing speed‑test widget presents the standard trio of measurements:
  • Download throughput (Mbps)
  • Upload throughput (Mbps)
  • Round‑trip latency / ping (ms)
    These are the values most people associate with “speed tests.”
  • The widget — as integrated across Microsoft properties — generally delegates the heavy lifting to an established measurement engine (reports indicate it uses Speedtest by Ookla under the hood in many places). That means the UI you see is Bing’s, but the backend measurement infrastructure is a familiar third‑party engine.
  • What it does not provide:
  • Native, OS‑level measurement hooks or offline diagnostics that run regardless of browser connectivity.
  • Exportable, auditable logs tied to a Windows diagnostic timeline (for example, event log entries or centrally collected telemetry scoped for enterprise reporting).
  • Built‑in selection of private or corporate test servers (the web widget selects public measurement servers).
Because the test runs in a browser tab, it requires that the browser can load the page; if DNS, captive portal pages, or severe HTTP failures are the problem, the taskbar shortcut won’t help. That limitation is important to understand when using the feature for triage.
  • Faster updates: Web tools can be improved independently of OS release cycles, enabling quicker fixes and UI changes.
  • Reuse of existing investments: Bing and Edge already surface a speed‑test widget, so Windows can funnel users to an existing endpoint rather than rebuilding server selection logic.
  • Lower OS complexity: No need to embed measurement servers, scheduling, or extra maintenance burden in Windows itself.
These are pragmatic engineering trade‑offs that favor convenience and maintainability for the majority of home users at the cost of deeper control demanded by IT teams.
Accuracy and reproducibility: what to expect​
A browser‑based speed test is useful for quick sanity checks but has limitations when precision matters:
  • Browser behavior, extensions, proxy settings, and caching can influence results. Running the same test in different browsers can yield slightly different numbers.
  • A single test snapshot can be affected by background traffic (cloud backups, updates, streaming), Wi‑Fi variability, and transient network congestion. For more reliable results, follow testing best practices (below).
  • For contractual or SLA disputes, courts and ISPs often prefer hosted logs or tests executed from provider‑approved endpoints. The Bing widget’s browser results are convenient but may not carry the same weight as formal ISP measurements or router logs.
Practical tips to get reliable readings​
  • Close bandwidth‑hungry apps (cloud sync, streaming, large downloads) before testing.
  • Prefer a wired (Ethernet) connection when testing to eliminate Wi‑Fi variability.
  • Run multiple tests and use the median value rather than a single reading. Three runs over five minutes is typically a good baseline.
  • If you need to capture evidence, take screenshots with timestamps and test from multiple providers (Bing/Ookla, Fast.com, ISP portal).
  • For reproducibility and scheduled monitoring, use an official CLI (Speedtest CLI by Ookla) or an internal monitoring tool rather than the browser widget.
Alternatives for power users and IT admins​
  • Speedtest CLI (Ookla): Scriptable, selectable test servers, JSON output for logging. Ideal for scheduled, auditable tests.
  • iperf3: Peer‑to‑peer LAN or WAN measurements between controlled endpoints to isolate Wi‑Fi or router issues. Use this when you need raw throughput between two machines on the same network.
  • Router / ISP portal tests: Many ISPs expose edge tests that measure to the provider’s network edge and are useful for formal disputes.
  • PowerShell Test‑NetConnection: Good for scripted connectivity checks (ping, TCP port reachability) but not a full throughput tool.
These tools provide the control and auditability enterprises require: server choice, scheduled runs, and machine‑readable logs.
Enterprise, privacy, and manageability implications​
  • Provider choice and corporate policy: The current shortcut funnels users to Bing. Enterprises that require internal test endpoints or want to avoid external testing should plan to continue using managed tools or request MDM/Group Policy controls if Microsoft exposes them in the future.
  • Telemetry and privacy: Because the test runs in a browser against web servers, normal web telemetry applies. Microsoft has not published a dedicated privacy FAQ for this specific Taskbar launcher, so administrators should assume standard web request metadata (IP, headers) will be visible to the test endpoint and validate any broader telemetry expectations with official documentation. Flag: any deeper claims about telemetry retention or sharing remain unverified until Microsoft publishes explicit guidance.
  • Captive portals and offline scenarios: The launcher is useless if the network prevents the browser from loading the page. For networks with captive portals or strict DNS filters, embedded or local diagnostics remain necessary.
Overall, the feature is a consumer‑grade convenience; enterprises should treat it as a helpful front‑line tool but maintain established internal diagnostics for regulated or audit‑sensitive contexts.
UX and accessibility analysis — why discovery matters​
Placing the test exactly where users first look when something goes wrong — the network icon — is a small but high‑impact UX decision. Many non‑technical users don’t know which third‑party site to visit when internet performance appears degraded; offering a single click reduces friction and standardizes the first step for support workflows. That discoverability delivers real day‑to‑day value for home users and help‑desk teams.
However, surfacing a single upstream provider raises product perception questions. Users and admins may ask why Microsoft funnels to Bing rather than letting people choose their preferred testing provider. If Microsoft wants this to become an enterprise‑grade diagnostic path, it will need to add provider choice, exportable metadata, offline micro‑benchmarks and management controls. Until then, it’s a polished convenience — not a forensic tool.
How to try it today (insider checklist)​
  • Join the Windows Insider Program and enable the Dev or Beta channel if you want early access; the Taskbar shortcut has been reported in recent Insider preview builds. Be aware builds are experimental and may change.
  • Confirm your device received the relevant preview update (community reporting has tied the button to mid‑September Insider flights). Treat reported build numbers as provisional; Insider features can be toggled server‑side.
  • Use the Taskbar flow to launch the test and then cross‑check with another provider for confirmation.
Risks, unanswered questions and what to watch for​
  • Will Microsoft add enterprise controls (MDM/Group Policy) to block or redirect the shortcut? Administrators will want the ability to force a corporate test endpoint or disable external launches. This remains an open request until Microsoft documents such controls.
  • Will Microsoft publish a privacy/telemetry FAQ for the shortcut? Users deserve clarity on what is logged by Bing’s widget and how long that data is retained. This has not been verified in official documentation yet.
  • Will the taskbar launcher evolve into a native, exportable diagnostic with local measurement options? Community feedback will determine whether Microsoft keeps this as a simple web launcher or invests in a more robust in‑OS measurement capability.
Flag any firm claims that Microsoft will add specific enterprise features as provisional until confirmed by Microsoft’s documentation or official release notes.
Conclusion — small idea, outsized daily value​
The taskbar speed‑test shortcut is a tidy example of design trade‑offs: Microsoft prioritized discoverability and maintainability by funneling users to Bing’s tested web widget rather than embedding a full measurement engine in Windows. For everyday users and support staff, that one click can shave minutes off common troubleshooting flows and remove friction in capturing basic performance numbers. At the same time, the implementation’s browser‑based nature imposes meaningful limits for power users, enterprises and anyone who needs reproducible, auditable test logs. Until Microsoft provides management controls, provider choice, and clearer telemetry documentation, the Taskbar button should be treated as a rapid sanity check rather than definitive proof of network health. For readers who want the best of both worlds: use the taskbar shortcut for quick checks, but rely on CLI tools (Speedtest CLI), iperf, or ISP‑provided portals when accuracy, reproducibility and auditability matter most.
This feature is rolling through Insider preview channels; expect this convenient launcher to reach more users if Microsoft deems it valuable and addresses enterprise and privacy questions during the testing window.
Source: itsecuritynews.info https://www.itsecuritynews.info/windows-11-lets-you-run-a-network-speed-test-right-from-the-taskbar-now-how-to-try-it/
Microsoft has quietly placed a one‑click network speed test where many users already go to check connectivity — the Windows 11 system tray — but for now it behaves as a browser‑launched shortcut to Bing’s speed‑test widget rather than a native, in‑OS measurement engine.
Windows desktop with translucent Bing speed test widgets floating over a blue wallpaper.Background / Overview​
Windows 11 Insider testers began spotting a new Perform speed test entry in the network (system tray) menu and a Test internet speed button in the Wi‑Fi quick‑settings flyout during mid‑September Insider flights. The control appears either when you right‑click the network icon in the taskbar or when you open the quick settings panel and look for the small speedometer‑style button in the lower‑right area of the Wi‑Fi pane. Invoking the option opens the default browser and navigates to Bing’s web‑based speed test tool, where the familiar download/upload/latency measurements are run from the web UI. In short: the taskbar item is a launcher — convenient and discoverable — not a native diagnostic service running inside Windows. The feature has been observed in Insider builds distributed to the Dev and Beta channels (community reporting ties visibility to builds in the 26220.6682 and 26120.6682 family, associated with KB5065782), but Microsoft’s feature‑flighting model means the UI can be toggled or altered before any broad public release. Treat the build numbers as provisional evidence while Microsoft iterates.
What Microsoft added (what you actually see)​
UI placement and discoverability​
  • Right‑click the network (Wi‑Fi / Ethernet) icon in the taskbar’s notification area. You may see a Perform speed test entry in the context menu.
  • Left‑click the same network icon to open the Wi‑Fi quick settings flyout; a Test internet speed button may be visible near other quick actions (Wi‑Fi refresh, airplane mode, etc..
This placement is deliberate: Microsoft put the control where users instinctively check network status, making a basic throughput check one click away. For non‑technical users and first‑line support, that discoverability is the feature’s primary value.
What the buttons do​
  • Click the network icon or right‑click it.
  • Select Perform speed test or press the quick‑settings Test internet speed button.
  • Windows launches the default browser and opens Bing’s Speed Test page.
  • The speed test runs inside the browser tab; you click Start to initiate download/upload/latency measurements.
Because the measurement runs in the browser against a web backend, it requires an operational HTTP(S) path to the test servers — if DNS, captive portal, or severe HTTP failures prevent the page from loading, the shortcut cannot perform the test. That dependency is a crucial operational limitation.
Technical anatomy: why this is a web shortcut, not a native test​
Microsoft’s current implementation is a pragmatic engineering choice: it surfaces a launcher in system UI that directs users to an existing web‑hosted tool (Bing’s speed test). That approach offers several clear benefits for Microsoft:
  • Fast iteration: web tools can be updated independently of Windows servicing cycles.
  • Lower OS footprint: no need to ship and maintain local measurement servers, selection logic, or a measurement service.
  • Consistent UX: the same Bing widget can be surfaced from multiple Microsoft touchpoints.
Under the hood, Bing’s speed test itself has been reported to delegate to established measurement backends (notably Speedtest by Ookla in prior integrations), meaning the numbers you see are produced by well‑known third‑party measurement engines surfaced through Microsoft’s web UI. That backend mapping has been observed by multiple outlets, though backend selection and exact provider mappings can change and are not guaranteed to remain static.
Cross‑checking the claims (verification)​
The most load‑bearing claims are:
  • The taskbar shortcut exists in Insider builds and appears in the right‑click menu and the Wi‑Fi flyout: verified by Insider build notes and multiple independent press captures.
  • Selecting the control opens Bing’s speed‑test page in the default browser: corroborated by hands‑on reports and screenshots from preview testers.
  • The Bing widget delegates measurement to an established third‑party engine (historically Ookla): supported by independent technical write‑ups and prior Bing/Edge integrations. This claim is well‑attested but can be considered provisional in the sense that provider mappings may change; treat backend specifics as subject to confirmation.
Where certainty is lower (and we flag it): final telemetry behavior, any outbound network endpoints Windows may contact at the moment you press the taskbar button, administrative controls to enable/disable the launcher, and whether Microsoft will add a native measurement mode with exportable logs. Those operational details remain unconfirmed publicly and should be watched in forthcoming Insider release notes and Microsoft documentation.
Strengths: why this is a useful addition​
  • Discoverability and convenience. Many users don’t know which website to visit for a speed test. Putting a one‑click launcher in the network menu reduces friction for everyday triage.
  • Consistency with Microsoft’s direction. Microsoft has been moving lighter‑weight diagnostics and consumer utilities to web‑backed tools; this fits that pattern and lets the company iterate without shipping OS updates.
  • Low maintenance overhead. Delegating measurements to an existing web tool avoids shipping and maintaining global test servers or test server selection logic in the OS.
  • Good for frontline support. Helpdesk agents can standardize on a single, easily reachable test path when guiding callers through connectivity checks.
Limitations and risks — what power users and IT should know​
  • Not auditable or reproducible for disputes. Browser‑based tests often lack exportable, signed logs and server selection control, making them unsuitable for contractual or SLA disputes. Use dedicated CLI/native tools like Speedtest CLI, iperf3, or vendor portals when you need auditable evidence.
  • Browser, extension and environment variability. Test results can vary with the browser chosen as default, active extensions, parallel downloads, and system resource contention. That introduces measurement noise.
  • Dependency on web connectivity. If the computer’s HTTP path is broken, the shortcut cannot perform a test — the test’s operational envelope is limited to situations where the browser can reach Bing’s tools page.
  • Telemetry and privacy considerations. Because the test is web‑hosted, the backend provider may collect metadata (IP, timestamps, server IDs). Microsoft has not published granular telemetry details for the shortcut flow in the Insider notes; organizations should treat telemetry implications as provisional pending official documentation.
  • Provider lock‑in (single provider exposure). The button currently points to Bing’s test; there is no UI to choose a different provider (Fast.com, Ookla direct, TestMy.net). That reduces choice for users who prefer alternate meters.
Practical guidance: how to treat and use the new shortcut​
  • For everyday checks: use the taskbar shortcut as a fast sanity check when an app seems slow or buffering. It’s the quickest way for a non‑technical user to get a ballpark of download/upload and latency.
  • For troubleshooting and escalation:
  • Reproduce the test at different times of day and collect multiple samples.
  • Cross‑check with a native client (Speedtest CLI) or iperf3 to confirm results.
  • Capture supporting diagnostics — ipconfig /all, netsh wlan show wlanreport, ping/tracert — before contacting an ISP.
  • For enterprise / managed devices: pilot the change in a controlled ring and update internal troubleshooting guides to specify which test is considered “authoritative” for support workflows. Consider blocking or restricting the feature if your security policy forbids automatic web launches from system UI.
A short comparison: taskbar shortcut vs common alternatives​
  • Taskbar shortcut (Bing web widget)
  • Pros: immediate, discoverable, no install, browser‑agnostic.
  • Cons: not auditable, browser variability, dependent on web connectivity.
  • Speedtest CLI (Ookla) / Speedtest desktop app
  • Pros: selectable server, CLI automation, logs, reproducible for reports.
  • Cons: needs installation, slightly higher user skill requirement.
  • Fast.com (Netflix)
  • Pros: minimal UI, one‑click, reliable for download throughput.
  • Cons: limited metrics (upload/latency are secondary), limited server control.
  • iperf3 (native)
  • Pros: fully controlled endpoint testing, ideal for internal network validation.
  • Cons: requires a reachable iperf server, more technical to configure.
Use the taskbar button for sanity checks; use native clients for evidence and in‑depth troubleshooting.
Enterprise considerations and suggested Microsoft improvements​
IT administrators and privacy teams should watch for the following and press Microsoft (through Insider feedback channels) to add:
  • Provider choice — allow admins/users to choose the default speed‑test provider or point the launcher to an internal, corporate test endpoint.
  • Exportable logs — add an option to save raw measurements (CSV/JSON) with server IDs and timestamps for auditing.
  • Administrative controls — Group Policy/MDM controls to enable/disable the launcher and to centrally specify the target test endpoint.
  • Telemetry transparency — publish documentation detailing what telemetry is collected when users invoke the test.
These items would transform the shortcut from a consumer convenience into a manageable enterprise diagnostic tool.
What to expect next​
The UI is currently in Insider channels (Canary/Dev/Beta) and being evaluated; Microsoft may:
  • Keep it as a web shortcut and leave the behavior largely unchanged.
  • Add management options, provider selection, or a native micro‑benchmark mode in later flights.
  • Remove or reword the control based on Insider feedback.
Monitor the official Windows Insider release notes and support documentation for definitive rollout details and any telemetry disclosures. Until Microsoft publishes final documentation, treat the taskbar shortcut as a work in progress.
Final assessment​
This small change is a classic usability win: it removes friction for a routine diagnostic and places a useful action where users expect to look when connectivity fails. For the average home user and first‑line support personnel, a one‑click speed check is a welcome ergonomic improvement. However, the current architecture — a browser‑launched Bing widget — transfers the heavy lifting to web infrastructure and inherits the limitations of browser‑based tests: measurement variability, limited auditability, and potential telemetry collection by the backend. For power users, IT professionals, and regulated environments requiring reproducible, auditable metrics, the taskbar launcher should be treated as a convenience rather than a final diagnostic authority. If Microsoft wants this feature to serve enterprises as well as consumers, the next logical steps are to add provider choice, exportable logs, and management controls. Until then, keep it in the toolbox for fast triage and continue to rely on dedicated tools when you need precision and forensic evidence.
Conclusion: the Windows 11 taskbar speed‑test shortcut is a small, well‑targeted quality‑of‑life addition that reduces friction for everyday network checks, but it remains a web‑backed convenience — useful for quick sanity checks, not a substitute for controlled, auditable network diagnostics.
Source: gHacks Technology News Windows 11 is getting a system tray shortcut to run a network speed test - gHacks Tech News
Microsoft is quietly folding a one‑click internet speed check into Windows 11’s network UI — but the shortcut doesn’t run a native measurement engine; it launches Bing’s web speed test, meaning the “built‑in” convenience is really a fast path to an online tool rather than a local diagnostic.
Windows 11 desktop with a blue speed-test window displaying download, upload, and latency bars.Background​
Windows has long offered pieces of network troubleshooting inside its Settings and Network flyouts, from basic connection status to an automated troubleshooter. The newest Insider preview builds add a more visible access point: a Perform speed test control surfaced in the taskbar network icon’s context menu and a dedicated button inside the Wi‑Fi quick settings flyout. Clicking either control opens the default browser and loads Bing’s speed‑test widget so users can start an upload/download/latency measurement without manually navigating to a web‑based testing site. Multiple outlets that inspected preview build behavior also reported the UI’s two placements — right‑click on the system tray network icon and as a tile inside the Quick Settings flyout — which places speed testing exactly where most users go first when they suspect connection trouble. The builds where the control appears were identified by preview numbers reported in coverage of the feature.
What Microsoft is shipping in Insider builds (what you’ll see)​
  • A new Perform speed test entry in the network/system tray context menu.
  • A Speed test button in the Wi‑Fi quick settings panel (the panel that opens from the network icon on the taskbar).
  • When invoked, the control opens your default browser and navigates to Bing’s speed‑test page to conduct the measurement. The result display and the measurement logic are delivered from the web widget.
How the flow behaves (step‑by‑step)​
  • Left‑click the network icon on the taskbar to open the Quick Settings panel or right‑click the system tray network icon to open the context menu.
  • Click the Speed test button or select Perform speed test from the context menu.
  • Your default browser launches and loads Bing’s speed‑test interface; you then start the test from within the browser tab or sidebar.
This is important: the new Windows control is a launcher. It does not embed a low‑level measurement engine in the OS itself. That distinction changes the operational and security characteristics of the feature compared to a truly native network diagnostic tool.
Why Microsoft chose a web‑backed approach​
There are pragmatic engineering reasons for Microsoft to link to a web test rather than build measurement servers and logic into Windows.
  • A web‑hosted test requires no OS servicing to update server lists, measurement logic, or UI, allowing the provider to evolve the test independently of Windows update cycles.
  • It significantly reduces engineering and infrastructure costs: accurate speed testing needs geographically distributed servers and continuous maintenance to avoid biases and stale server mappings.
  • Embedding a web widget lets Microsoft reuse existing tools already integrated in Bing and Edge, accelerating rollout while delivering a familiar interface to many users.
That economy of effort also explains the practical behavior seen in Insider builds: Microsoft surfaces the test where users expect to find it, but keeps the heavy lifting on web infrastructure rather than inside core OS binaries.
Who powers the test? The engine behind Bing’s speed test​
Bing’s web speed test has, in prior implementations, relied on third‑party measurement infrastructure rather than a Microsoft‑native engine. Coverage of the Bing/Edge speed‑test widget has repeatedly shown that the web experience delegates to or embeds Speedtest by Ookla for actual throughput and latency measurements. That same backend behavior is inherited by the Windows launcher because the taskbar control opens Bing’s web widget. This matters because Ookla’s infrastructure is broadly recognized and widely used, but it also means the measurement characteristics — server selection, throttling handling, and logging behavior — follow Ookla’s model rather than a Microsoft‑owned methodology.
What this means for speedtest sites and the ecosystem​
The headline claim that “Speedtest‑type sites may be a thing of the past” is overstated. The Windows shortcut makes it faster for casual users to run a web test, but it does not remove the need for third‑party testing sites or dedicated clients. Here’s why:
  • The taskbar button opens one specific web test (Bing’s); there’s no user‑selectable provider option exposed in the UI, so power users and professionals who prefer other test backends will still use dedicated sites or apps.
  • Dedicated speed‑test sites and tools offer features Microsoft’s quick path does not: server selection, testing schedules, historical logging, exportable results, API access, and deeper diagnostic metrics (packet capture, jitter analysis, multi‑stream testing).
  • Enterprises and network engineers typically rely on instrumented, repeatable tests (including M‑Lab, Ookla, Fast.com, local loopback tests) to diagnose complex problems; a single web widget won’t replace that workflow.
In short, convenience doesn’t equal replacement. The Windows shortcut lowers friction for quick checks but does not provide the control and extensibility many users and organizations require.
Accuracy, methodology and limitations​
Speed tests produce useful but context‑sensitive metrics. The Windows → Bing path inherits the same accuracy constraints that affect any browser‑based speed test:
  • Browser overhead and background activity can influence results; other apps consuming bandwidth will reduce available throughput for the test.
  • Tests measure the path between your device and the chosen test server at that moment — they do not represent sustained throughput across all routes.
  • If the browser cannot load the web widget because of DNS failure, captive portals (hotel/Wi‑Fi logins), or severe HTTP stack problems, the shortcut will not help because the flow requires an operational HTTP channel.
Additionally, relying on a single web provider raises transparency questions: users should be aware of which servers are used, what sampling interval is conducted, and what, if any, logging or telemetry accompanies the test. Those aspects differ between providers and can materially affect perceived speeds.
Privacy, telemetry and compliance concerns​
Because the test is web‑hosted, several privacy and compliance considerations follow:
  • The test exposes your public IP address and routes test traffic to remote servers run by the test provider; metadata about tests (timestamp, geographic region, server used) may be logged by the provider.
  • Organizations with strict data handling policies or network measurement restrictions need to evaluate whether sending measurement traffic (and correlated telemetry) to third‑party servers complies with policy.
  • The web flow could circumvent or complicate internal monitoring: if endpoint tests are required to run against corporate measurement endpoints, a browser‑backed external test will not substitute.
Enterprises should treat the Windows shortcut as a convenience for end users, not as a sanctioned diagnostic tool for regulated or audited environments.
Deployment and rollout expectations​
The control is present in current Windows 11 Insider preview builds, but Microsoft has not publicly committed to an exact release date or guaranteed that the completed implementation will mirror the preview behavior. Insider builds are by definition experimental, and features can change, be delayed, or never ship to general consumers. Expect the following possibilities:
  • The feature could appear as reported, launching Bing’s web speed test from the taskbar.
  • Microsoft could expand the flow (for example, offering multiple provider options or integrating more diagnostic telemetry) before public release.
  • The company could also delay or remove the change based on user feedback gathered during the Insider cycle.
Until Microsoft publishes formal documentation or releases the feature to the stable channel, timing and exact behavior remain subject to change — treat reports from preview builds as provisional. This is an unverifiable claim until Microsoft confirms it in public release notes.
User impact: who benefits and who should be cautious​
Beneficiaries:
  • Home users and helpdesk staff who need a fast, visual way to confirm whether an internet connection is working and roughly how fast it is.
  • Non‑technical users who find the current process (open browser → search for “speed test” → pick a site) awkward or confusing.
Users who should be cautious:
  • IT administrators, security teams, and compliance officers in organizations that require internal control over network measurement traffic.
  • Users who require high‑precision, reproducible throughput measurements for troubleshooting, SLA verification, or forensic work.
  • Anyone who doesn’t want their public IP and test metadata reaching third‑party servers by default during a routine check.
The ecosystem of internet speed measurement remains broad; built‑in convenience won’t replace specialised options:
  • Speedtest by Ookla (web and dedicated clients) — broad server network, configurable settings, exportable results.
  • Fast.com (Netflix) — simple, minimalist measurement focused on download throughput, useful for media streaming checks.
  • M‑Lab (Measurement Lab) — open, research‑grade measurements used in academic and regulatory contexts.
  • ISP‑provided speed meters — some ISPs host their own endpoints to measure performance to the ISP’s infrastructure.
  • Local CLI tools and packet captures (iperf, tcpdump) — for in‑depth diagnostics and reproducible testing in lab conditions.
For regular diagnostics, a combination of quick web checks and periodic, instrumented tests remains the recommended approach.
Developer and power‑user recommendations​
  • Treat the Windows 11 speed‑test launcher as a first‑look diagnostic: use it to quickly rule out total outages and get a baseline number.
  • For reproducible results and troubleshooting, use a dedicated test client (Ookla, iperf, or an enterprise measurement tool) and document test times, server choices, and network conditions.
  • If you manage devices at scale, inform users about what the taskbar control does and whether it is permitted under corporate policy; consider firewall or proxy rules if you need to restrict outbound test traffic.
  • Monitor the Insider feedback channels — the feature is still in preview and may gain options or settings before public release.
Microsoft’s responsibilities and open questions​
The addition raises a few product and policy questions Microsoft would be well served to address publicly:
  • Will the final implementation provide an option to pick a preferred speed‑test provider or to disable the quick‑launch entirely?
  • How will Microsoft document the privacy and telemetry implications of running the test from the taskbar?
  • Will enterprises be able to centrally manage or disable the shortcut through Group Policy or Intune?
  • If Microsoft continues to route the shortcut to Bing’s web widget, will it document the measurement backend and server selection behavior so users can interpret results correctly?
Answers to these questions will determine whether the control is a helpful convenience or a source of confusion for businesses and power users. The preview behavior suggests a lean integration focused on consumer convenience rather than enterprise flexibility.
Practical walkthrough: test it responsibly (quick checklist)​
  • Confirm you are comfortable with the browser opening and performing an external network test (IP exposure).
  • Close bandwidth‑intensive apps (downloads, cloud sync) for a cleaner measurement.
  • Right‑click the network icon or open Quick Settings and select Perform speed test.
  • When the browser opens, start the test and note download, upload, and latency.
  • If you need repeatable results, record the test server, time, and device state and run multiple trials.
Critical analysis — strengths and risks​
Strengths:
  • Reduced friction: Putting a speed‑test entry where users already diagnose network problems improves discoverability and usability.
  • Low maintenance: Delegating to a web widget avoids OS bloat and lets Microsoft leverage continuously updated web infrastructure.
  • User empowerment: Non‑technical users get an accessible way to validate ISP speeds before escalating to support.
Risks and limitations:
  • Not truly native: Because it launches the browser and relies on web infrastructure, it lacks the deep diagnostic capabilities and offline robustness of a native tool.
  • Privacy and enterprise compliance: Third‑party server interactions could conflict with organizational policies or produce unwanted telemetry.
  • Single‑provider push: If the UI tightly couples to Bing’s test without an option to choose providers, users may feel their choice is constrained and may distrust single‑vendor defaults.
Given these tradeoffs, the feature is a pragmatic consumer convenience — valuable, but not transformative for professionals who depend on controlled, reproducible measurements.
Final verdict​
The Windows 11 taskbar speed‑test launcher is a meaningful usability improvement for everyday users and first‑line support scenarios. It lowers the barrier to running a quick check and aligns with a broader trend: integrating helpful web services directly into system UI. However, the implementation’s reliance on a web widget (historically backed by Ookla in Bing) means this convenience is not a substitute for professional diagnostic workflows or for organizations with strict privacy requirements. Until Microsoft publishes definitive release notes or adds controls for provider choice and enterprise management, the new feature should be treated as a fast shortcut to a web tool — useful, but limited. Users and administrators should continue to rely on dedicated measurement tools when accuracy, repeatability, and policy compliance matter.
The shift underlines a practical design philosophy: ship low‑friction, discoverable helpers in the UI while leaving specialized tooling to established providers and third‑party apps. For most users, that will mean less time hunting for “speed test” sites and faster answers when the internet feels slow. For power users and IT professionals, the landscape remains unchanged — the ecosystem of dedicated speed testers, research platforms, and enterprise tools will keep serving the needs that a one‑click launcher cannot address.
Source: Gamepressure.com https://www.gamepressure.com/newsroom/windows-11-will-let-you-test-your-internet-speed-speedtest-type-s/z585dd/
A subtle change hidden inside a recent Windows 11 preview build surfaces a new, one‑click path to measure internet speed directly from the taskbar: a “Perform speed test” option now appears in the network icon’s context menu and in the Wi‑Fi quick settings, and selecting it launches the default browser to run Bing’s embedded speed‑test widget (which in turn uses established speed‑test backends). The addition is small, but it highlights a larger truth about modern Windows: Microsoft is increasingly surfacing web‑backed utilities inside system UI shortcuts rather than building every utility natively into the OS. This feature is currently gated in Insider preview builds and behaves as a launcher to a browser‑hosted test rather than as a locally executed diagnostic — a design choice with clear convenience benefits and equally clear technical and privacy trade‑offs.
Windows 11 desktop with Bing speed test showing 350 Mbps down and 280 Mbps up.Background​
Windows has never shipped a truly native, built‑in broadband speed measurement tool in the system tray despite the internet being central to modern computing. Users historically rely on third‑party web tools (Ookla Speedtest, Fast.com), store apps, or diagnostic command‑line utilities for throughput testing. The new taskbar shortcut changes the discovery surface by placing a speed‑test launcher where users already go to check connectivity: the network icon and the Wi‑Fi quick settings flyout.
The feature was first observed in Insider preview builds by members of the Windows community and appears in recent Dev/Beta flight captures. It does not run a local measurement engine; instead, it opens a browser tab (or Edge window) that navigates to Bing’s built‑in speed‑test tool. That Bing tool is a web page that gives download, upload and latency measurements, and—behind the scenes—relies on an external measurement backend for the heavy lifting.
Several related pieces of Microsoft work are visible in preview builds at the same time: refreshed mobile device pages, updated privacy/security settings, and other small convenience features. The network speed tester is an incremental UX change rather than a platform‑level networking diagnostic overhaul.
How the feature works — step by step​
  • Right‑click the network icon in the taskbar notification area (system tray) and look for a “Perform speed test” option.
  • Alternatively, left‑click the network icon to open the Wi‑Fi quick settings flyout and select the speed‑test control that appears alongside refresh and other quick actions.
  • The shortcut launches the system’s default browser and navigates to Bing’s speed‑test widget.
  • The user clicks Start inside the widget; the web page runs a download/upload/latency measurement against a remote test server and displays results.
Key behavior to note:
  • The OS itself does not perform any packet‑level throughput testing. The action is a web launcher.
  • The test result is produced by the web widget and whatever server/backend it uses (commonly an industry test engine such as Ookla’s infrastructure).
  • The experience is identical to performing a manual search for “speed test” and clicking the Bing tool.
Why this matters: convenience, discoverability, and UX​
Placing a speed‑test shortcut directly in the network quick actions is a smart UX decision in isolation. Most users don’t know where to look when their connection feels slow; the network icon is the single most natural place to surface basic connectivity tools.
Benefits:
  • Instant access: One or two clicks from the taskbar starts the full test flow, reducing friction for non‑technical users.
  • Consistent experience: The same web widget is available whether launched manually or via the taskbar shortcut.
  • Low maintenance: Because it links to a web tool, Microsoft can update the test experience without shipping OS updates.
For many users this will be the fastest way to answer a simple question—am I getting billed bandwidth?—and that alone explains the appeal.
Accuracy and technical limitations​
A crucial part of the evaluation is understanding what a browser‑based speed test can and cannot do. A web widget running inside a browser is constrained in ways a native test client is not.
Why results can vary:
  • Browsers operate under different network stacks and constraints (TCP congestion control settings, parallel connection behavior, buffering, and HTTP protocol choices) compared with dedicated native apps.
  • Some browsers limit the number of parallel connections or alter connection algorithms for performance and battery life; that can affect peak throughput measurements.
  • The test uses selected test servers; geographic proximity, peering paths, and transient congestion all influence results.
  • Web tests are typically run over HTTPS HTTP(S) or WebSockets and often rely on more conservative TCP tuning compared with native UDP‑based testing that can saturate a line faster.
  • Browser extensions, antivirus, VPNs, and OS power‑saving features can interfere with or throttle throughput during the test.
Practical consequences:
  • Browser‑run tests may under‑report the maximum achievable throughput on very fast connections or in environments where the browser is throttling parallel fetches.
  • Variability across browsers and client setups can produce different numbers for the same physical line; a difference of 10–20% between tools is common, and higher discrepancies are possible.
  • For precise network troubleshooting — packet loss, jitter, or TCP handshake anomalies — browser speed tests are only a first step, not a replacement for deeper diagnostics (iperf, traceroute, packet captures).
These constraints have been observed in community testing and in side‑by‑side comparisons between web widgets and native Speedtest clients. For anyone using tests for service level verification, billing disputes, or network tuning, the difference matters.
Privacy and telemetry considerations​
Because the taskbar control launches a web tool, a handful of privacy questions naturally follow:
  • When the default browser opens to Bing’s speed test, the test exchange will share IP address, user agent, and other standard HTTP metadata with the test server and with Bing’s telemetry systems.
  • If the browser is signed into a Microsoft account or synchronizing data, there may be additional context sent or logged by the browser or Bing.
  • Any backend provider used by the test widget (including commercial test networks) will collect test metrics for its own analytics unless explicitly stated otherwise.
What to watch for:
  • The test flow may include cookies or tracking pixels embedded in the test page; these are normal for web tools but are materially different from a purely offline OS diagnostic.
  • The choice of default browser becomes a privacy vector: launching the test in Edge vs. a third‑party browser may change what is logged or linked to a user profile.
  • Enterprises and privacy‑conscious users should treat the taskbar shortcut as a link to an external web service rather than as a purely on‑device diagnostic.
This distinction should be made clearly for users: it is a web‑backed convenience feature, not an offline diagnostic.
Accessibility, internationalization, and discoverability nuances​
Putting the option in the system tray is accessible to most users, but some details matter for inclusivity and global use.
Accessibility:
  • The new menu entry and quick settings tile must be properly labeled for screen readers and keyboard navigation to be fully accessible.
  • The resulting browser page should honor accessibility standards (text‑to‑speech, high contrast, and keyboard focus) — these are properties of the web widget more than the Windows launcher.
Internationalization:
  • Test server selection and language of the web page should adapt to locale to give meaningful results and instruction to non‑English speakers.
  • Users in regions with limited CDN coverage may see reduced accuracy; documentation or in‑UI notes could help set expectations.
Discoverability:
  • Right‑clicking the network icon is a common action for power users; many casual users only ever left‑click. Including the tile inside the quick settings flyout improves discovery for both user groups.
  • A tooltip or small in‑UI hint the first time the feature is available would encourage adoption without cluttering the UI.
Alternatives for power users and IT professionals​
For users who need more than a quick browser test, there are robust alternatives that provide more precise or repeatable measurements:
  • Native speed‑test apps (official Speedtest by Ookla desktop application) — these can use optimized protocols and have richer server selection.
  • Command‑line tools:
  • iperf3 — a cross‑platform tool for throughput testing that can be run against a dedicated iperf server; ideal for repeatable, high‑fidelity tests.
  • Test‑NetConnection (PowerShell) — useful for latency and port checks but not a substitute for throughput benchmarking.
  • curl/wget combined with timing scripts — lightweight checks to remote endpoints for simple throughput sanity checks.
  • Router/firmware tests — some routers expose built‑in diagnostic tools that run tests from the router’s perspective, which can be more representative of WAN capacity.
  • Enterprise network monitoring — RUM, SNMP, and flow monitoring provides continuous, long‑term insights rather than single‑point tests.
For day‑to‑day consumer checks, the taskbar shortcut is convenient; for SLA validation or deep troubleshooting, the above tools remain necessary.
Enterprise and IT management implications​
From an IT perspective, a taskbar launcher to a public web tool is a low‑impact convenience but should be considered in organizational policy:
  • Enterprises can block web services at the network perimeter if organizational policy forbids external test traffic.
  • Group Policy or MDM controls might be used to hide the context menu option for managed machines if desired; administrators should verify whether the control can be suppressed or configured centrally.
  • Relying on a web widget for diagnostic workflows is not appropriate in controlled environments where test traffic must traverse specific monitoring systems or where external endpoints are disallowed.
The feature is unlikely to replace existing enterprise diagnostics, but it could reduce helpdesk noise by giving users a quick way to confirm throughput on their own.
Security considerations​
On the surface, launching a browser to run a public speed test seems low risk, but a few security considerations are noteworthy:
  • Phishing/URL redirection risk: the context menu must open the intended URL; otherwise a malicious extension or system compromise could redirect to unsafe pages. The OS should assert a trustable launch pattern (e.g., a known, canonical Bing URL).
  • Extension interference: browser extensions could alter test behavior or redirect traffic, leading to incorrect results or interception of test metadata.
  • Local network effects: low‑quality Wi‑Fi, captive portals, or middleboxes could distort results; detecting and communicating these conditions helps avoid misinterpretation.
Overall, the security risks are typical of any web‑launch feature; clear UI messaging and a stable canonical URL mitigate most concerns.
Why Microsoft chose a web‑backed approach (likely reasons)​
Several pragmatic reasons explain why the taskbar launcher points to a web widget instead of shipping a native speed‑test engine:
  • Engineering cost and maintenance: a web tool is faster to update and iterate without OS releases.
  • Centralized backend: using a single web‑hosted backend allows Microsoft to control test server selection and analytics centrally.
  • Cross‑platform parity: a web widget behaves similarly across devices and browsers, reducing fragmentation.
  • Legal and licensing: integrating third‑party engines natively may involve licensing complexities; linking to existing web integrations can be simpler.
This approach fits Microsoft’s recent pattern of surfacing web‑based utilities inside Windows and Edge while keeping the OS lighter and easier to maintain.
What this is not (and what users should not expect)​
To avoid confusion, clarify what the feature does not provide:
  • It is not a native network diagnostics engine that runs entirely on the device.
  • It does not replace packet captures, jitter analysis, or deep routing diagnostics.
  • It does not guarantee measurement parity with other test clients; differences are expected.
  • It will not necessarily help diagnose intermittent packet loss or application‑level failures.
Treat the taskbar shortcut as a starting point for connectivity questions, not as the final word.
Potential improvements Microsoft could make​
If the goal is to evolve this convenience into a more robust utility over time, Microsoft could consider several enhancements:
  • Add a native, optional measurement mode that runs a lightweight throughput test inside the OS for quick hover‑state readings.
  • Surface quick metrics on hover (current negotiated link speed vs. measured internet throughput) so users get immediate context without a full test.
  • Provide a diagnostic mode that runs multiple quick tests to detect variability, packet loss, or jitter.
  • Allow IT admins to configure the launcher behavior (default URL, whether to allow Bing or an internal enterprise test server).
  • Make the quick action choices explicit: “Open web speed test” vs “Run advanced diagnostics” so users understand the difference.
Any of these changes would move the feature from a simple launcher to a more polished diagnostic toolset.
Risks and downsides​
There are practical and perceptual risks associated with this web‑backed approach:
  • Misleading expectations: users may assume the OS is measuring line quality when in fact a browser widget is doing the work, leading to misplaced trust.
  • False negatives/positives: web tests can be influenced by browser behavior, leading to inconclusive results that frustrate users.
  • Privacy confusion: users may not realize that running a speed test launches a web service that collects IP and test data.
  • Fragmentation: different users will get different results depending on browser, extensions, and system configuration, complicating basic support interactions.
A small change in UI can produce disproportionately large effects on user behavior and support load if not accompanied by clear messaging.
Timeline and rollout expectations​
Because the control is present in Insider Dev/Beta preview builds, it is subject to the usual Windows feature flighting cadence:
  • Preview → wider Insider rings → public release. Historically, features observed in Dev/Beta flights can take months to reach general availability, and some never do.
  • Microsoft can remove, modify, or replace the control before public release.
  • Even after public release, server‑side behavior (the Bing widget) can be updated independently of the OS.
Users should not expect immediate availability for stable channels; the feature’s presence in preview builds simply signals it is under active testing.
Note: reported build numbers and internal KB identifiers seen in community captures should be treated as provisional until Microsoft publishes official documentation.
Practical recommendations for Windows users​
  • For a quick check: use the new taskbar shortcut when it appears — it’s the fastest way to get a ballpark reading.
  • For verification: run the browser test a few times at different times of day, and cross‑check with a native client (Ookla desktop app or iperf) if precise numbers matter.
  • For privacy‑minded users: be aware that the test launches a web service that will see your IP and browser metadata; consider using a privacy‑focused browser or clearing cookies if concerned.
  • For IT pros: treat the result as a first‑step; follow up with directed tests and packet captures where necessary.
Final analysis: small change, symbolic significance​
On its face, adding a “Perform speed test” shortcut to the taskbar is a modest usability tweak that reduces friction for non‑technical users trying to confirm whether their internet is performing as expected. The implementation choice — a browser/ Bing‑backed widget — is pragmatic: it’s low effort, centrally maintainable, and consistent with Microsoft’s trend of surfacing web tools from the system UI.
But the change also exposes the limits of a web‑backed approach. Accuracy, privacy, and the ability to perform repeatable, enterprise‑grade diagnostics remain the domain of native clients and specialized tools. For casual checks and fast reassurance, the taskbar launcher will be a useful addition. For anything beyond that, users and IT pros must still rely on dedicated apps and command‑line tools.
Ultimately, the feature is less about reinventing network testing and more about reducing friction. How Microsoft positions, documents, and manages that trade‑off — and whether the company evolves the launcher into a richer, optionally native diagnostic tool — will determine whether the change is merely convenient or truly consequential for Windows networking diagnostics.
Source: htxt.co.za Windows 11 may make it easier to see how fast your internet is - Hypertext
Windows 11 now surfaces a one‑click path to a network speed test directly from the taskbar — but for now it’s a shortcut to Bing’s web tool (which itself delegates to Speedtest by Ookla), and it’s only available to Windows Insiders in preview channels.
Windows 11 desktop showing a Bing Internet Speed Test window floating over the blue wallpaper.Background​
Microsoft has quietly started testing a convenience feature that places a Perform speed test control in the network area of the taskbar. The control appears in two discoverable places: the right‑click context menu for the network (system tray) icon and as a button inside the Wi‑Fi quick settings pop‑up. Activating either control opens your default browser and loads Bing’s internet speed test widget, which reports download, upload, and latency (ping) values.
This behavior is rolling through Windows Insider preview channels — reports and build captures show the control in Canary, Dev and Beta preview builds — meaning it’s visible to testers before a public release. The Bing tool it opens has long been part of Microsoft’s web toolbox and, in the current implementation, uses the widely adopted Speedtest by Ookla infrastructure for the actual measurements.
Why this matters: quick checks vs deep diagnostics​
A speed test is one of the quickest ways to check whether you’re getting the bandwidth your ISP advertises or whether a local issue is throttling throughput. For most users the new taskbar shortcut reduces friction: instead of remembering a URL, opening a browser, and searching for a site, you can now reach a speed test from the exact UI people use to inspect connections.
That said, the implementation is currently a link to a web tool — not a native OS measurement engine — and that design decision has practical consequences:
  • The test requires a working browser and a functional HTTP path to the web tool (so it won’t help when a captive portal or severe DNS problem prevents web pages loading).
  • Results reflect the web test’s backend behavior (server selection, measurement method, number of test streams), not a Windows‑owned measurement methodology.
  • There’s no built‑in historical logging, scheduled testing, or the low‑level diagnostics network engineers rely on.
These tradeoffs distinguish a handy convenience shortcut from a full diagnostic capability.
What the taskbar test actually does​
Where you’ll find it in preview builds​
  • Right‑click the network/system tray icon and look for a Perform speed test entry in the context menu.
  • Left‑click the network icon to open the Wi‑Fi quick settings flyout; the speed test appears there as a small button next to refresh and quick actions.
What happens when you run it​
  • Windows opens your default browser.
  • The browser navigates to Bing’s internet speed test widget.
  • You click Start (the widget runs the test) and the page reports:
  • Download speed
  • Upload speed
  • Latency (ping)
  • The results display in the browser UI; there’s no in‑OS pop‑up or notification that captures or stores the numbers within Windows.
This flow is intentionally lightweight: fast discoverability at the expense of deeper integration.
How to try it (Insider builds): step‑by‑step​
  • Join the Windows Insider Program (if you’re not already a member). Use your Microsoft account and choose an Insider channel.
  • On a Windows 11 PC, go to Settings > Windows Update > Windows Insider Program and pick an Insider channel (Canary, Dev, or Beta).
  • Update to the latest preview build that includes the test (Insider updates vary; you’ll see the new UI in builds that expose the network control).
  • Once updated:
  • Right‑click the network icon in the taskbar and select Perform speed test — or
  • Left‑click the network icon, open Wi‑Fi quick settings, and click the Test internet speed button.
  • The default browser opens to Bing’s speed test. Click Start to run the measurement.
Caveats:
  • Insider channel builds can be unstable. Back up critical data and expect occasional regressions.
  • Microsoft’s rollout strategy varies; not every Insider may see the control immediately even if they’re on a channel where it’s being tested.
How accurate will the results be?​
For casual checks the Bing/Ookla combo produces reasonable and broadly comparable numbers to other popular services. That’s because the measurement uses established public servers and well‑tested algorithms. However, several factors can alter results:
  • Server selection and distance: Results depend on which test server your browser connects to; the closer and less loaded the server, the higher your throughput will appear.
  • Browser and OS overhead: Browser throttling, extensions, or background downloads on your machine can affect throughput during the test.
  • Single vs multi‑stream testing: Some services use multiple parallel streams to saturate modern connections; others don’t. This affects the reported peak throughput.
  • VPNs and NATs: If you’re using a VPN, corporate proxy, or NAT that shapes traffic, tests will show throughput to the VPN gateway or exit node, not your ISP’s raw line speed.
  • Transient congestion: A single test gives a snapshot. For reliable conclusions you need multiple runs at different times and under different loads.
For these reasons, power users and network pros still prefer dedicated tools that allow server selection, repeated tests, exportable logs, and more granular stats.
Practical comparison: taskbar shortcut vs dedicated apps​
  • Taskbar shortcut to Bing
  • Pros: Fast, discoverable, no need to remember a URL.
  • Cons: Browser dependent, no in‑OS history, no server control, no scheduled tests.
  • Speedtest by Ookla (app or website)
  • Pros: Mature backend, server selection, history, exportable results, dedicated Windows Store app offers notifications and an in‑app experience.
  • Cons: Still web‑backed for the website; app may be subject to platform policies.
  • Pros: Simple, minimal UI focused on download throughput.
  • Cons: No advanced metrics, limited controls.
  • TestMy.net and other independent tools
  • Pros: Alternative measurement methods (single stream vs multi stream), sometimes more conservative results.
  • Cons: Different methodology — not directly comparable to every other test.
  • Local measurements (iperf3, PowerShell)
  • Pros: Full control (server/client), repeatable laboratory‑grade tests, measured between local endpoints or a trusted remote test server.
  • Cons: Requires setup: an iperf3 server or a public test server, and some networking knowledge.
For power users: local and scripted tests that go beyond the taskbar​
If you need deterministic or repeatable results, use tools that run under your control:
  • PowerShell (built‑in)
  • Test-NetConnection: ping/port/traceroute diagnostics and basic latency checks.
  • Get-NetAdapterStatistics: quick counters for interface errors and traffic.
  • These are helpful for scripted checks and can be integrated into scheduled maintenance.
  • iperf3 (third‑party)
  • Run an iperf3 server on a trusted endpoint and use a client locally to measure multi‑stream throughput, jitter, and loss.
  • Best for lab‑grade comparisons and when you control both endpoints.
  • CLI scripting with scheduled runs
  • Schedule repeated tests during different times of day and log results to CSV for trend analysis.
  • Useful for verifying ISP SLAs or diagnosing intermittent performance issues.
Because the taskbar button launches a web test, results and metadata flow to the web service that runs the test (Bing’s widget and the test backend it uses). Important privacy points:
  • The web tool typically collects anonymized connection details and may log test times, ISP information, and the IP address the test originates from.
  • If the web widget delegates to a third party (such as Speedtest by Ookla), data handling is subject to that provider’s logging and privacy policy.
  • Tests run while signed into browser accounts, or while using a corporate network, may leave logs associated with those environments.
  • The taskbar shortcut itself likely sends no telemetry beyond the fact that the control was invoked, but the test page will establish network connections and exchange test data.
For privacy‑sensitive contexts, use a local iperf3 server or offline diagnostics that do not require contacting third‑party servers.
UX critique: elegant shortcut, minimal execution​
The idea of exposing internet checks in the UI where users already look for connectivity information is sound UX: the network icon is the right place for this. The implementation, however, stops short of being truly integrated.
Strengths:
  • Visibility: the button is in the network flyout where people expect quick diagnostics.
  • Low friction: a couple of clicks takes you to a test, lowering the barrier for less technical users.
  • Reuses a trusted web tool: using Bing’s widget leverages an existing UI that many people already know.
Weaknesses:
  • Browser dependency: opening a browser tab is heavier than returning a quick readout inside the OS.
  • No in‑OS results: there’s no immediate native notification or persistent log displayed in Windows.
  • Lack of provider choice: the UI routes users to Bing’s test; there’s no option to pick a different test engine or a local test server from within the menu.
  • Not helpful for severe outages: if the browser can’t reach the web test, the button is effectively useless.
Given Microsoft’s ability to integrate small utilities into Windows, a stronger implementation would either embed the engine or provide a tight OS‑level widget that can display live results without always jumping to the browser.
Security and enterprise implications​
Enterprises and IT support teams use repeatable, instrumented tests and logging to verify complaints and to diagnose issues; a single ad‑hoc browser test is rarely sufficient. Key considerations for managed environments:
  • Managed browsers with strict policies might block the Bing widget or route traffic through proxies, producing misleading results.
  • Corporate VPNs or split tunneling will change the “view” of the internet and confound comparisons to ISP line speed.
  • For auditability and SLA compliance, organizations should adopt scheduled, logged tests between controlled endpoints and avoid single ad‑hoc browser runs.
For help desks, the taskbar shortcut is a convenient entry for end users, but support teams should pair it with scripted or managed tests that record results centrally.
Recommendations for users​
  • Casual users: the taskbar shortcut is a helpful, low‑effort way to see if your connection is broadly healthy. Use it to confirm basic download/upload and ping numbers.
  • Power users: don’t rely on a single browser test. Use Speedtest apps (which provide history and server selection), Fast.com for simple throughput checks, or iperf3/Test‑NetConnection for controlled measurements.
  • Troubleshooting intermittent problems: run tests at different times and from multiple devices on the same network. Compare wired vs Wi‑Fi results and check for local noise (background updates, cloud syncs, P2P apps).
  • Privacy‑conscious users: if you don’t want test metadata shared with web providers, run local tests to a server you control.
What Microsoft could (and should) do next​
If Microsoft’s goal is to democratize quick network diagnostics while respecting the needs of power users and enterprise customers, a pragmatic roadmap could include:
  • Add a small, built‑in quick result panel so the taskbar action displays download/upload/ping inside Windows without opening a browser.
  • Offer a provider selector in network settings enabling users to pick from Bing, Ookla, Fast.com, or enterprise‑managed test endpoints.
  • Integrate lightweight history logging (locally stored and exportable) so users can see trends over time.
  • Expose an API or PowerShell cmdlets that trigger tests against specified endpoints for scripted diagnostics.
  • Provide an offline diagnostic mode that runs local network tests (ping, traceroute, LAN throughput) even if web access is unavailable.
These changes would preserve the convenience of the current shortcut while making the capability useful to a broader audience.
Caveats and what remains unverified​
  • Microsoft has not published an official timeline for public rollout of this taskbar shortcut to all Windows 11 users. The control is present in preview builds we’ve seen, but broad availability and final behavior are subject to change.
  • Whether Microsoft will eventually replace the browser‑opening flow with a native in‑OS measurement engine remains unannounced. Any speculation about future product direction should be treated as provisional.
  • Implementation details such as the precise telemetry emitted when the control is used, and whether the action will preferentially open Edge or use the user’s default browser, may change prior to public release.
The Windows 11 taskbar speed test shortcut is a welcome usability move: it places a common diagnostic action exactly where users go to inspect connectivity. For casual checks, it lowers the barrier to running a speed test and introduces non‑technical users to the idea of measuring their connection.
But the current implementation is deliberately lightweight — essentially a launcher to a web tool — and that limits its utility for power users, enterprises, and anyone who needs repeatable, auditable network measurements. The practical benefits today are convenience and discoverability; the lost opportunity is deeper integration into the OS with provider choice, local results, and logging.
As an interim step it’s useful. As a roadmap it should prompt Microsoft to consider a more integrated approach that gives both consumers and professionals accurate, repeatable, and private ways to validate network performance from inside Windows.
Source: ZDNET Windows 11 lets you run a network speed test right from the taskbar now - how to try it
Windows 11 now puts a quick internet speed check one click away in the Taskbar — but it’s a launcher to Bing’s web tool, not a native measurement engine, and that choice has real implications for accuracy, privacy, and enterprise control.
Windows desktop displaying an Internet Speed Test: 250.78 Mbps download on a blue abstract background.Background​
Microsoft quietly began testing a new convenience feature in recent Windows Insider preview builds: a Perform speed test (or Test internet speed) option that appears in the right‑click context menu of the Taskbar’s network (system tray) icon and as a button inside the Wi‑Fi quick settings panel. Clicking the control opens the system’s default browser and loads Bing’s speed‑test widget so users can run an immediate download/upload/latency check. The addition follows Microsoft’s recent pattern of surfacing lightweight utilities via web‑hosted experiences instead of building new full‑blown native subsystems into Windows. That pragmatic engineering trade‑off favors fast rollout and centralized updates, but it also means the Taskbar item is best viewed as a shortcut for fast, consumer‑grade checks rather than a forensic, auditable diagnostic tool.
What Microsoft added (Overview)​
Where the control appears​
  • Right‑click the network (Wi‑Fi/Ethernet) icon in the system tray and look for Perform speed test.
  • Left‑click the network icon to open the Wi‑Fi quick settings flyout and find a Test internet speed button near other quick actions.
What the button actually does​
  • It launches your default web browser.
  • The browser navigates to the Bing speed‑test widget.
  • The widget runs the speed test (download, upload, latency) and displays results inside the browser tab.
This UX places a very common troubleshooting step exactly where users already look when they suspect connectivity problems, which is the primary usability win here: discoverability and low friction. For casual users and first‑line support, that convenience is valuable.
Why Microsoft shipped a web‑backed launcher (and not a native tool)​
Microsoft’s decision to funnel the Taskbar control to a Bing web widget reflects several clear engineering and product trade‑offs:
  • Update agility: Web services can be modified and improved without shipping OS updates, enabling faster iteration and bug fixes.
  • Infrastructure reuse: Bing’s speed‑test widget already exists and delegates measurement to established backends, so Microsoft avoids the cost of building and managing a global measurement server network inside Windows. Multiple reports indicate Bing’s web‑hosted speed test delegates to the widely used Speedtest (Ookla) infrastructure behind the scenes.
  • Smaller OS footprint: No new native services, daemons, or telemetry pipelines needed in the OS itself — the heavy lifting happens on the web.
Those are practical reasons, but they come with trade‑offs that matter beyond the convenience story. The next sections unpack those trade‑offs.
Technical behaviour and measurement fidelity​
What the test reports​
When run from Bing’s widget, the test typically reports:
  • Download throughput (Mbps)
  • Upload throughput (Mbps)
  • Latency / ping (ms)
These are the core consumer metrics most people expect from an internet speed test. The test’s UI and results are identical to the same flow you get when searching “speed test” in Bing or launching the tool directly.
Which backend powers the measurement​
Independent reporting and community analysis show Bing’s embedded speed‑test experience commonly uses the Speedtest by Ookla engine for measurements. That means the underlying server selection, concurrency model, and measurement algorithm are likely those used by Ookla’s web client rather than a new Microsoft‑created protocol. However, the provider mapping is not guaranteed to be static — Microsoft can change the backend provider for the web widget. Treat any provider attribution as provisional until Microsoft publishes definitive documentation.
Sources of variability and why results may differ​
Browser‑launched speed tests are generally fine for quick sanity checks, but they are subject to variance caused by:
  • Browser stack and networking stack differences across browsers and extensions.
  • Server selection (geographic distance and server load).
  • Local device load, background transfers, and Wi‑Fi vs. wired connectivity.
  • VPNs, proxies, or captive portals that alter the path to the test server.
  • Transient ISP congestion and peering issues.
For enterprise or contractual validation, repeatable, auditable tests (Speedtest CLI, iperf3, router logs, or tests to a controlled server) remain the recommended approach.
Insider builds and rollout expectations​
The Taskbar speed‑test control was reported by Insiders in mid‑September preview builds, with community captures tying the UI to build families in the 26220 and 26120 lineages (examples: 26220.6682 on Dev and 26120.6682 on Beta as observed in those early reports). Insider distributions can be toggled server‑side, and features may be altered before public release — so build numbers and channel coverage should be treated as provisional. Microsoft’s modern servicing model means features discovered in Insider builds can roll out via cumulative or servicing updates independent of major version jumps, so expect broader availability to arrive via a cumulative update rather than being exclusively tied to the next biannual feature release. That’s consistent with Microsoft’s stated platform approach for Windows 11.
Privacy, telemetry and enterprise control — what to watch for​
The Taskbar button funnels users to a web tool, which raises a set of questions for privacy‑conscious users and administrators:
  • Telemetry and data collection: The web widget will necessarily communicate with third‑party or Microsoft‑operated servers to run tests. Administrators should expect IP addresses, timestamps, and performance metrics to be visible to the test backend. Until Microsoft publishes precise telemetry documentation, treat collection and retention policies as unknown and plan accordingly.
  • Default browser behavior: The control uses the system default browser — not necessarily Edge — which means browser extensions (ad blockers, privacy tools) could alter the test or its UI. Administrators and help‑desk staff should be aware that results may vary by browser environment.
  • Network egress rules: Organizations that restrict outbound traffic will need to identify and permit the relevant Bing/test endpoints if they want this flow to function. Conversely, some orgs may prefer to block it entirely and provide an internal testing endpoint.
  • Policy controls: As of the current Insider evidence there’s no published Group Policy or MDM setting specific to the Taskbar speed‑test launcher. Enterprises should watch for the addition of explicit Group Policy/MDM controls and accompanying privacy/telemetry docs before enabling the feature broadly in managed environments.
Flag: until Microsoft publishes official documentation, any statement about exact telemetry, retention, or the provider hard‑wiring should be considered provisional and subject to change.
Practical guidance — how to use the feature (for home users and support)​
  • Click the network icon in your Taskbar (system tray).
  • Choose Perform speed test from the right‑click context menu, or open the Wi‑Fi quick settings and click Test internet speed.
  • Your default browser opens to Bing’s speed test; click Start to run the measurement.
When to use it:
  • Quick sanity checks when streaming stalls, games lag, or downloads crawl.
  • Front‑line help‑desk triage to gather a baseline number from a non‑technical user.
  • A fast way to decide whether to escalate to deeper diagnostics.
When not to rely on it:
  • SLA or contractual disputes with your ISP. Use controlled, repeatable tests (Speedtest CLI, iperf3) and collect server IDs and timestamps for evidence.
Tips to get more consistent results:
  • Use a wired connection for baseline tests when possible.
  • Close background downloaders and pause cloud sync apps.
  • Run multiple tests at different times to account for transient congestion.
  • Temporarily disable browser extensions that might alter requests.
Comparison: Taskbar/Bing test vs dedicated tools​
  • Speedtest by Ookla (web or native client): Widely used, supports server selection and CLI for auditability. Good for contractual evidence.
  • Fast.com (Netflix): Minimal UI focused on download throughput; simple and fast.
  • Speedtest CLI, iperf3, router logs: Best for reproducible, auditable testing and internal network troubleshooting.
The Taskbar/Bing flow excels for convenience and discoverability but falls short on auditability, scheduled testing, and detailed metadata export. For power users and network engineers, the Taskbar button should be an entry point — not the final report.
Security and operational considerations​
  • The Taskbar shortcut requires a functional browser and a working HTTP path to the test endpoint. If the problem prevents web pages from loading (DNS failures, captive portal, or severe routing issues), the shortcut won’t help. Prepare alternate offline diagnostics for such cases.
  • Because the test is browser‑hosted, local privacy tools might block scripts or requests and skew results. Help‑desk scripts should educate users about temporarily toggling such tools when running the test for troubleshooting.
  • Administrators who need internal telemetry or wish to avoid third‑party egress should deploy or recommend internal test endpoints (iperf servers) and update triage documentation accordingly.
Risks, limitations and open questions​
  • Reproducibility: Browser tests lack the deterministic behaviors and logging of dedicated CLI tools; results should be corroborated.
  • Provider transparency: The exact backend used by Bing’s widget can change; Microsoft has not documented a binding provider contract for the test. That makes long‑term reproducibility or comparisons more complex.
  • Telemetry and privacy: The amount and retention of data collected by the web widget are not yet publicly documented; enterprises must assume standard network logs may be seen by the test backend until Microsoft clarifies.
  • Enterprise policy: There is no confirmed Group Policy or MDM control in the public Insider notes for toggling the Taskbar launcher; managed environments may need explicit controls before approving the feature.
Flag: any assertion about the feature’s long‑term behavior, provider binding, or telemetry must be considered tentative until Microsoft publishes official documentation or an announcement.
Recommendations for Microsoft (what would make this feature enterprise‑ready and power‑user friendly)​
  • Add an explicit Group Policy / MDM setting that allows administrators to disable or require approval for the Taskbar speed‑test launcher.
  • Provide provider transparency and an option for organizations to select an internal test backend (or opt out entirely).
  • Offer exportable logs (CSV/JSON) from the web widget that include test server IDs, timestamps, and raw throughput figures for auditability.
  • Consider a lightweight native diagnostic mode that can run micro‑benchmarks locally and optionally post anonymized summaries to Microsoft for quality telemetry without exposing raw IPs to third parties.
  • Publish a clear privacy and telemetry statement that spells out what is collected, how long it’s stored, and under what legal jurisdiction test servers operate.
These changes would retain the convenience benefit while addressing the legitimate needs of enterprise admins and power users.
How this fits into Microsoft’s broader strategy​
This small ergonomics change is emblematic of a larger direction: Microsoft increasingly surfaces web‑hosted utilities within Windows UI for rapid iteration and reduced OS surface area. That strategy reduces engineering overhead and speeds time to value for consumers, but it also shifts control and trust boundaries outward — from the OS to web services. Users and IT teams will need to decide whether that trade‑off is acceptable for their use cases or whether they prefer local, auditable tools for serious diagnostics.
Final verdict​
The Taskbar speed‑test shortcut in Windows 11 is a welcome quality‑of‑life improvement for everyday troubleshooting: it puts a quick, consumer‑grade measurement where users intuitively look when connectivity is suspect. For casual checks and first‑line support, it will save time and reduce friction.
However, because the control launches a browser and relies on a web‑hosted backend (commonly backed by Speedtest/Ookla), it is explicitly not a replacement for reproducible, auditable network diagnostics. Enterprises, power users, and anyone needing evidence for disputes should continue using dedicated CLI tools, internal test servers, and router logs. Microsoft should add management controls, exportable test metadata, and clearer telemetry documentation to make the convenience of a Taskbar test safely usable at scale. Until Microsoft publishes official docs that confirm backend, telemetry, and admin controls, treat all claims about exact implementation details as provisional. The Taskbar speed‑test is useful — but it’s a beginning, not the final word on bringing trustworthy network diagnostics into Windows.
Source: KitGuru Windows 11 is getting a built-in Internet speed test - KitGuru
Microsoft is quietly testing a new, built‑in internet speed test for Windows 11 that places a one‑click network diagnostic into the taskbar’s system tray and Wi‑Fi quick settings — but the convenience comes with important trade‑offs: the shortcut opens Bing’s web‑based speed tester rather than running measurements natively inside Windows.
Monitor showing a browser diagnostic with latency and speeds, plus a floating Wi‑Fi speed test panel.Background​
Insider preview activity in September 2025 reveals several modest but telling refinements to Windows 11’s networking and settings surface. Two preview builds — Dev Channel build 26220.6682 and Beta Channel build 26120.6682 (delivered as part of the KB5065782 checkpoint updates) — contain a new context menu action and a quick‑settings button labeled for running a network speed test. The discovery was highlighted on social networks by an insider account and subsequently covered by multiple technology outlets after screenshots of the new controls circulated. The official Windows Insider release notes for the builds document many general fixes and UI experiments for the Dev channel, and community reporting fills in the user‑facing details of this specific network shortcut.
The change is small in scope but significant in signal: Microsoft is continuing to fold frequently used troubleshooting tools into shallow, discoverable UI locations in Windows 11. At the same time, the implementation strategy (a browser‑launched Bing test) raises questions about what “built‑in” means when the experience depends on external web services and a default browser.
What Microsoft is testing: feature overview​
The network speed test appears in two places in the Windows 11 UI:
  • As a new entry in the right‑click context menu for the network icon in the system tray (the taskbar’s network indicator).
  • As a dedicated button in the Wi‑Fi quick settings flyout — the panel that appears when clicking the network, audio, or battery icons on the taskbar.
Activating either control opens a web page hosted via Bing that runs the speed measurement and displays latency, download, and upload numbers. The UI is effectively a shortcut: it does not present results directly inside a compact Windows dialog or widget. The current preview behavior routes the user’s default browser to Bing’s speed test page rather than executing measurements locally in the operating system.
Key identifiers and context:
  • Target Insider builds: 26220.6682 (Dev) and 26120.6682 (Beta).
  • Update KB checkpoint referenced: KB5065782.
  • Discovery method: Screenshots posted by an Insider on social platforms and hands‑on reporting from community press.
How the new speed test works (practical walkthrough)​
  • Locate the network icon in the taskbar’s system tray.
  • Right‑click the icon to reveal the context menu. A new “Run speed test” (or similarly labeled) entry appears.
  • Alternatively, click the network indicator to open the Wi‑Fi quick settings panel and tap the speed test button there.
  • The action launches the default browser and navigates to Bing’s network speed test page, which performs the diagnostics and returns metrics.
Because the test runs in the browser, the exact measurement endpoint and methodology are controlled by the web service Bing uses. In previous iterations Bing has either displayed an embedded speed test UI or deferred requests to an external backend; in practice, the user sees a web page reporting ping, download, and upload values rather than a compact, integrated Windows dialog.
Why this matters: convenience vs. native integration​
Placing a speed test where users naturally go when troubleshooting (the taskbar’s network controls) reduces friction. Most casual users don’t bookmark diagnostic tools or know Speedtest.net or Fast.com by heart; a taskbar shortcut makes performance checks discoverable.
  • Benefits:
  • Faster diagnostics for non‑technical users.
  • Reduced need to install a third‑party app just to validate ISP claims.
  • Centralizes a common troubleshooting step into Windows’ system UI.
  • Limitations:
  • The tool is not truly native: it requires web connectivity and a browser session to run.
  • Reliance on Bing’s web page means the experience may vary with browser, Bing region, and ongoing web‑service changes.
  • Enterprises with locked‑down browsers or restricted internet access may not benefit.
In plain terms: the addition improves discoverability but is functionally a shortcut to a web service, not an implementation of a local network benchmarking daemon inside Windows.
Technical and privacy implications​
Adding a quick access link to an online tool raises several technical and privacy considerations users and admins should weigh.
  • Browser mediation. Because the speed test opens a web page, browser state and extensions can influence the test. Ad blockers, privacy extensions, or corporate browser policies may block elements of the test or alter routing, producing inconsistent results.
  • External servers and measurement endpoints. A web‑hosted speed test uses remote endpoints to exchange test traffic. Which servers are selected, the geographic proximity of those servers, and routing choices all affect reported speeds. When a desktop OS delegates the selection to a web provider, users lose visibility into endpoint choice.
  • Backend providers. Historical reporting shows that search providers and browsers sometimes use third‑party backends for their “speed test” features. That means data about test timing, IP, and measured throughput may be processed by more than one company. Public reporting suggests Bing’s speed test has, in the past, used recognized third‑party engines; however, Microsoft has not published a specific technical specification for the version surfaced via the new Windows shortcut — this remains a claim that is consistent with previous behavior but not independently verified by Microsoft for these builds.
  • Telemetry and logging. Running a web‑based speed test will generate server logs on the host site (Bing) and may create additional network telemetry visible to ISPs, CDNs, and intermediary services. Corporate or privacy‑conscious users should be aware that a “one‑click” test is not purely local.
These practical realities mean that while the UI makes testing easier, it does not remove network complexity from the user’s troubleshooting workflow.
Comparison: web shortcut vs. native testing tools​
Windows users have historically used several ways to test network performance:
  • Built‑in Windows utilities:
  • ping, tracert, iperf (when installed), and PowerShell cmdlets for low‑level diagnostics.
  • Web‑based public testers:
  • Speedtest.net (Ookla), Fast.com (Netflix), and other browser‑accessible tools.
  • Dedicated desktop clients:
  • Native apps provided by testing vendors, which can sometimes circumvent browser limitations and support advanced features such as server selection, multi‑threaded testing, and scheduling.
The new Windows shortcut sits firmly in the middle: it makes web tools faster to reach but does not replicate the advantages of a native client (precise control over threads, server selection, or programmatic access). For power users, the shortcut is a convenience but not a replacement for command‑line or dedicated benchmarks.
Broader UI changes visible in the same builds​
The preview builds that include the speed test also show other settings and UI refinements that aim to simplify device management and privacy navigation:
  • Mobile devices consolidated view: The Bluetooth & devices settings page exposes a new Mobile devices section that lists paired phones in a single place and provides direct toggles for common phone‑linked features, replacing a multi‑window “manage devices” workflow.
  • Privacy & security redesign: Pages within Settings are receiving clearer headings and descriptive text to make privacy controls easier to find and understand.
  • AI background tasks page: An experimental page to manage background AI processes is present, although it’s presently unstable and prone to crashes in the preview builds. Microsoft appears to be experimenting with granularity around AI workloads.
  • Drag Tray enhancements: The Drag Tray (used for quick file sharing) shows signs of expanded capability, including additional actions like moving files between folders.
These changes indicate an incremental strategy: Microsoft is polishing Settings’ information architecture and consolidating device control while testing new features through the Insider rings.
Accessibility and enterprise considerations​
Shortcuts in the system tray and quick settings must be designed with accessibility in mind. Early previews often miss the full complement of ARIA labels, Narrator announcements, and keyboard navigability; Microsoft’s Insider notes for these builds show continuous work on Narrator improvements in parallel.
Enterprises should note:
  • Group Policy and management. Organizations that lock down browser usage or restrict outbound web traffic may find the taskbar shortcut ineffective. Administrators should assess whether the UI will create support tickets when the browser‑launched test fails due to network policy.
  • Telemetry and compliance. A browser‑based test generates logs that may be captured by corporate proxies and monitoring tools. Administrators concerned about data movement should treat the feature like any other web resource.
  • Deployment uncertainty. Insider features are experimental. Organizations should not assume this shortcut will be present in stable releases or that its implementation will remain browser‑based.
Risks, criticisms, and available mitigations​
Critics highlight that labeling a web shortcut as a “built‑in” speed test risks user confusion and may act as subtle product placement for Bing. The user experience trade‑offs include:
  • Perception of promotion. Because the click leads to Bing, some perceive the move as promotional rather than a true functional upgrade to Windows.
  • Potential for inconsistent measurements. Browser interference or extension conflicts can produce noisy data.
  • Dependence on third‑party backends. If Bing’s test uses an external vendor’s backend, any change on that vendor’s side could alter behavior or availability.
Mitigations for users and admins:
  • Continue using dedicated native tools when precise benchmarking is required (for example, iperf for controlled environment tests).
  • If privacy or enterprise policy restricts web calls, document and communicate the expected behavior of the shortcut to help desk and desktop support teams.
  • For personal use, disable problematic browser extensions before running a quick test to avoid skewed results.
  • If the shortcut is unwanted and becomes part of a stable release, expect to find administrative controls (Group Policy or Settings toggles) added in later releases; Insiders often surface a new control after user feedback.
What this does — and doesn’t — fix for everyday users​
The Windows 11 taskbar speed test reduces friction for people who need a fast, one‑click confirmation of whether their connection is broadly functional. For users who previously opened a browser and searched for “speed test,” the new placement is an improvement.
What it doesn’t deliver:
  • Native measurement that bypasses the browser and its extensions.
  • Advanced options like selecting a specific test server or scheduling tests.
  • Guaranteed uniformity across different managed or restricted environments.
  • For quick checks: Use the new taskbar shortcut (when available in your build) for a quick sanity check of latency and throughput.
  • For reproducible results: Prefer a native client or command‑line tool that lets you control server endpoints and test parameters.
  • For privacy‑minded users: Be aware that opening the test launches a web session; read the test page’s privacy policy if concerned about server logging.
  • For IT admins: Document the behavior and include it in first‑line support scripts; advise users that a one‑click test may not be available behind some corporate proxies.
If the shortcut appears in your Preview ring, test it in a controlled manner first and compare results against a known reference tool to understand local variability.
The disclosure gap and unverifiable elements​
Several technical details around the new shortcut remain opaque:
  • Microsoft has not published a formal technical whitepaper stating whether the Bing test in these preview builds uses a particular third‑party backend or a proprietary engine.
  • Reported connections to recognized speed‑test backends are plausible and consistent with historical integrations, but they are not explicitly documented by Microsoft for this change.
These gaps mean that any statement about a specific backend or precise measurement methodology should be treated as probable but not officially confirmed until Microsoft publishes explicit technical details.
How this fits into Microsoft’s broader Windows 11 strategy​
The addition aligns with a pattern: Microsoft continues to make small, discoverable improvements that surface common tasks closer to where users operate — the taskbar and quick settings. Rather than bundling a heavy new tool into Windows, Microsoft appears to be experimenting with shallow, web‑backed integrations that deliver immediate value with low product‑development cost and centralized control via web services.
This approach benefits Microsoft by enabling rapid iteration and centralized updates to the service, but it also shifts some control and dependency to online services and browser behavior. The same pattern can be observed in other areas of Windows where web‑hosted experiences are surfaced through OS controls.
Final assessment: small change, outsized implications​
The Windows 11 taskbar speed test is an incremental but telling update: it reduces friction for basic network troubleshooting and improves discoverability for a routine action. At the same time, the browser‑launched nature of the test blurs the line between native operating system functionality and web service shortcuts, with consequences for privacy, consistency, and enterprise manageability.
The feature is likely to be useful for the majority of consumers who want a quick check without downloading an app, but it will not replace tools demanded by professionals, IT staff, or users who need reproducible, controlled measurements. Until Microsoft documents the backend behavior and provides administrative controls for managed environments, organizations and power users should treat this as a convenience feature rather than a definitive diagnostic tool.
Windows 11’s test builds show Microsoft continuing to refine the OS in small, user‑focused ways that reduce friction. The new taskbar/quick settings internet speed test is a pragmatic convenience that will make basic troubleshooting easier for many users. However, because it launches a web‑hosted test (via Bing) rather than running locally, the implementation raises important questions about measurement consistency, privacy, and enterprise suitability. The shortcut is a pragmatic stopgap — useful, but not a substitute for native benchmarking tools or a replacement for full transparency about backend handling. Users and IT professionals should evaluate the shortcut within the broader context of their diagnostic needs and privacy policies while watching for further refinements as Microsoft iterates on Insider feedback.
Source: Новини Live Windows 11 adds internet speed test and redesigned settings in Insider builds
