Nolj
Xml :
<Event xmlns="Link Removed">
<System>
<Provider Name="nvstor64" />
<EventID Qualifiers="49374">3</EventID>
<Level>2</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2018-08-12T23:04:57.554687500Z" />
<EventRecordID>1585808</EventRecordID>
<Channel>System</Channel>
<Computer>WIN-65J0TFIQH9G</Computer>
<Security />
</System>
<EventData>
<Data>\Device\RaidPort0</Data>
<Data>Hitachi HDS721050CLA362</Data>
<Data>JP2O</Data>
<Data> JP1512JE1N97SK</Data>
<Data>0</Data>
<Binary>0000000005002800000000000300DEC0000000000000000000000000000000000000000000000000</Binary>
</EventData>
</Event>
This issue keeps popping up in hundreds or more on my event log,especially when I play any games or browse the internet.
I have tried changing power settings and running CHKDSK and none of them helped,also the windows memory check didn't find any problems as well.
What do I do?
What do I do?
Did you run CHKDSK /R as well? Sometimes this error is caused by Hard Disk problem.
Do you have a spare hard disk?
Remove the Nforce drivers, reboot and then reinstall them. Is a known issue.
Remove from add and remove programs, restart if asked and then on booting reinstall them.
